T3 bent push rod
So I have a 91 Syncro with bent push rods, 2.1L.
One on both sides... I think the lifters have pumped up with no where to go. So tossing up between a rebuild of existing, though the motor has sat for a while or swap/exchange for a rebuilt. Any ideas comments and rough pricing.
Hi ......xxx
Bend pushrods ? Have the engine apart ? Bend pushrods is normally a secondary event. The primary  being a seized piston , or water on a piston, a disintegrated spark plug, or something similar . To my understanding a bend rod comes never alone. So there might be more to it. I guess a bit more detail and someone could help you here...
Hartmut
Sent from my iPad
What ever happened to a real Name? ;-)
Rupert,
It is a general rule on this group to add your name to each post – plus common courtesy in any event.  This is a mutual technical support resource group, not an anonymous general blog.
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of t3syncro91
Sent: 18 March 2013 15:37
Subject: [Syncro_T3_Australia] T3 bent push rod
The name's John... thought it would have come up on the Yahoo profile...
John
John,
Oh dear, even I got that wrong!
The problem is that usernames rarely bear any hint of who the person actually is.
This is what comes up on your post email header: “on behalf of; t3syncro91 [jpcjac@hotmail.com]”
I am further handicapped by always having a flock of applications sitting in my Inbox from people whose username and actual name are quite different.  I have to play email ping pong trying to relate them!
Sent: 18 March 2013 17:34
Subject: [Syncro_T3_Australia] Re: T3 bent push rod
John
Hi,
I had a bent push rod once caused by driving over a piece of wood at speed on a dirt road, the wood was thrown up under the car bashing against the pushrod tube, which is under the engine.  This resulted in a lot of tappet noise.
Dave Beckley WA
