Interesting top of the line 1990 Carat model T3 for sale. Note the additional body kit and front spoiler. A brochure I have from the period says they offered the option of a lowered "sports" suspension but no Syncro otherwise I could be tempted to head North.
Melbourne
----- Original Message -----From: Roger BellSent: Sunday, August 15, 2010 11:28 PMSubject: [Syncro_T3_Australia] T3 Caravelle Carat for sale
Interesting top of the line 1990 Carat model T3 for sale. Note the additional body kit and front spoiler. A brochure I have from the period says they offered the option of a lowered "sports" suspension but no Syncro otherwise I could be tempted to head North.RogerMelbourne
On Aug 15, 2010, at 3:02 PM, "Mr Scott Pitcher" <spbconsulting@bigpond.com> wrote:
Good friend of mine has two of these (one almost completely cut up and off to the tip) and the other with a turbo charged Suby motor and recently added airbag suspension.He can lower it to within 15mm of the centrally mounted 2wd fuel tank.I will see if I can attach a photo.Cheers,Skot
----- Original Message -----From: BenT SyncroSent: Monday, August 16, 2010 8:17 AMSubject: Re: [Syncro_T3_Australia] T3 Caravelle Carat for sale
Skotty,Am I imagining it or is the side door on the 'correct' side? I don't see a door handle but the slider track is there.Looks perfect as a street sweeper. Just attach a broom under the front bumper.BenTGood friend of mine has two of these (one almost completely cut up and off to the tip) and the other with a turbo charged Suby motor and recently added airbag suspension.He can lower it to within 15mm of the centrally mounted 2wd fuel tank.I will see if I can attach a photo.Cheers,Skot
> Roger
> Melbourne
> http://www.tradingpost.com.au/Automotive/Used-Cars/Small-Medium-Family-Prestige-Cars/AdNumber=TP003404313?BackToResult=true&AdOnTop=
> What aregene berg rockers
Ratio rockers that lift the valves 1.4 times the movement of the pushrod.
,power chip
Gives more fuel and raises the rev limiter
(aprox.45% more power)
bs
and do they actually give you more power?
yes, a little bit. Also increases fuel consumption.
I was wondering about the fuel consumption. Always trade offs.
> > What are
> gene berg rockers
> ,power chip
> bs
On Aug 15, 2010, at 4:24 PM, "Mr Scott Pitcher" <spbconsulting@bigpond.com> wrote:
Ben T,All our vans are like that over here - we have the sliding track cover to both sides same as the bay window model yet only the track on the passenger side unless you can find one of those uber-rare double sliders.Actually, have you ever seen a double slider syncro before?You would be the man to know as you have a large collection and have a larger syncro audience than we get all the way down here.Cheers,Skot-----
----- Original Message -----From: BenT SyncroSent: Tuesday, August 17, 2010 9:40 PMSubject: Re: [Syncro_T3_Australia] T3 Caravelle Carat for sale
Hi Skot,Sorry for the late reply. I figured as much regarding that track. It seems RHD T3's are built similar to T2's in that there was a provision to for tracks on both sides.I must say that in all the oddball T3's I have seen, no double slider Syncros have ever flown by my radar. That's not saying there aren't any around. Most dual sliders I've encountered were transports for the likes of airports. Perhaps taxis in other countries. The likelihood of a Syncro taxi or passenger bus seems slim to none.Since you have the spot for the track, why not build one? LHD sliders are more plentiful that RHD ones. You've already got half the job done and the difficult side at that. I'm building a Tristar door into my 3-door Doka. Found myself a RHD Doka door and having the hinge B-pillar welded on. besides the latch post, everything else was there hiding under the side panel. The same is probably true on van bodies.I had this vision of using the dual slider in an unconventional way. Namely, turn one side into a 'pop-out' ala' American style RV. It's an interesting way to add width to your Syncro when at the campground. Fortunately for me, my girlfriend does not like camping. Otherwise, I might be compelled to build or have someone build such an economically impractical contraption onto a Syncro.Cheers,BenTBen T,All our vans are like that over here - we have the sliding track cover to both sides same as the bay window model yet only the track on the passenger side unless you can find one of those uber-rare double sliders.Actually, have you ever seen a double slider syncro before?You would be the man to know as you have a large collection and have a larger syncro audience than we get all the way down here.Cheers,Skot-----
> Ben,
> I just shudder at the thought of bringing an angle grinder near my
> syncro - but if I had even half your collection and a bit more time (the
> boss, work and the kids seem to take most of that away) it would have
> potential. Possibly make the syncro less rigid though and more likely to
> crack around the sliding doors after some heavy off-road fun.
> Maybe this is why VW didn't make them? Also the market for them would be
> low.
> Makes it more difficult to make a row of cupboards along one side as
> well.
> Skot
> From: BenT Syncro
> Hi Skot,
> BenT
> Ben T,
> sliders.
> Skot
The sliding door is a structural weak point in the body. It is possible to have a sliding door on each side (and VAG has produced many in the T1 and T2, possible also the T3) but it requires considerable strengthening to maintain longitudinal torsional integrity.
Ben T,
On 18/08/2010, at 8:58 AM, Les Harris wrote:The sliding door is a structural weak point in the body. It is possible to have a sliding door on each side (and VAG has produced many in the T1 and T2, possible also the T3) but it requires considerable strengthening to maintain longitudinal torsional integrity.
Ben T,
T4 also. Greg E--- On Wed, 18/8/10, Gary Cookson <gary@twentytwentyone.net> wrote: |
> T4 also. Greg E
> From: Gary Cookson <gary@twentytwentyone.net>
> Received: Wednesday, 18 August, 2010, 9:43 AM
> The T5s produced as ambulances are dual sliders too. I was looking at
> one at auction recently. The slider on the drivers side was boxed in
> inside but when you opened it all of the oxygen tanks and other
> emergency stuff was available. Quite a nifty design. I was thinking one
> would make a good camper but I have enough projects with one syncro...
> They come out of service with 190k on the clock so could be a heap of
> trouble I guess.
> Gary
> The sliding door is a structural weak point in the body.�� It is
> strengthening to maintain longitudinal torsional integrity.��
> Ben T,
> sliders.
> Actually, have you ever seen a double slider syncro before?��
> Skot
Caddy Maxi , for 400 $ xtra I got 2nd slider, cruise control, passenger side airbag. Hartis
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of greg esposito
Sent: Wednesday, 18 August 2010 11:04 AM
T4 also. Greg E
The T5s produced as ambulances are dual sliders too. I was looking at one at auction recently. The slider on the drivers side was boxed in inside but when you opened it all of the oxygen tanks and other emergency stuff was available. Quite a nifty design. I was thinking one would make a good camper but I have enough projects with one syncro... They come out of service with 190k on the clock so could be a heap of trouble I guess.
Gary
The sliding door is a structural weak point in the body. It is possible to have a sliding door on each side (and VAG has produced many in the T1 and T2, possible also the T3) but it requires considerable strengthening to maintain longitudinal torsional integrity. Les On Aug 15, 2010, at 4:24 PM, "Mr Scott Pitcher" <spbconsulting@bigpond.com> wrote:
Actually, have you ever seen a double slider syncro before? You would be the man to know as you have a large collection and have a larger syncro audience than we get all the way down here. Cheers, Skot
for $1K and bought a caravelle GL auto in good condition for the same
price - then spent $1300.00 on the brakes.
Very amusing.
Sent: Wednesday, August 18, 2010 11:21 AM
Subject: Re: Re: [Syncro_T3_Australia] T3 Caravelle Carat for sale
> A friend of mine just sold an '86 Caravelle with dual sliders for about
> 3k.
>> T4 also. Greg E
>> Â
>> trouble I guess.
>> Gary
>> Â
>> strengthening to maintain longitudinal torsional integrity.Â
>> Les
>> Ben T,
>> sliders.
>> Actually, have you ever seen a double slider syncro before?Â
>> Cheers,
>> Skot
>> Â
>> -----Â
