Has anybody out there in t3 syncro land by any chance have a cargo
barrier they want to sell? I have to resort to using my syncro for
work rather than play so I'd like to stop any stray tools from
becoming potential missiles aimed at me.You can post your message on
the syncro t3 users goup site or email me directly. Also any info on
where to get a new one would be greatly appriciated. Thank you, Eddie
Bergodaz. By the way ,just got my 2.1 wbx recoed complete with hi
compression pistons & barrels and I must say I am no longer interested
in any suby, or any other type of conversion,this engine goes like a
dream.
Hi Guys,
I am sure you will find that the high compression pistons are the 'dome topped' pistons
that were factory fitted to the DJ series engines.
This series engine was quite common in Europe and produces 112hp as opposed to the 95
that the MV (and SS?) engine makes.
I may be wrong but I don't think that the DJ engine appeared in in Aus.
People in the UK run the DJ engines with normal ignition timing if using 98 octane fuel, or
back the timing off to 5 deg if using 91 octane. The engine is powered by an earlier engine
management system called Digijet whereas the later MV engines used the Digifant system.
Don't ask me what the difference is though!! :-)
These pistons are readily available in Europe. I know that Justcampers (UK) sells them -
Google justcampers to find them.
These pistons would produce a pretty handy engine if coupled with an ECU chip from Boris
at VVDS along with the high ratio rockers he recommends to be installed to make the best
of the chip, plus a free flowing air intake and exhaust.
There is a guy in the UK building wasserboxers using DJ pistons and dual carby setups for
folk who want to upgrade their 1.9 (lack of) power plants and apparently they are pretty
good too.
I am sure you could get up to 130 HP with the above, maybe more with bigger valves in
the heads. Then if you could hunt out a 2.3 (or even better a 2.5) Oettinger crank and
you'd be giving us Subie powered fellas a real run for our money!
HTHs
Andy
Ceduna.
You are correct Phil.
My first Syncro had a DJ engine in it with the timing at 5 degrees
and it had no more power than my MV engined bus.
Also, I think I asked you this question a few years ago but just in
case you have since found an answer - how many Syncro's
were sold in Australia and how many were to Telstra?
Andy.
