I have never seen a case where applying WD-40 to something didn't help it.
----- Original Message -----From: Ken GarrattSent: Monday, October 31, 2011 9:08 PMSubject: RE: [Syncro_T3_Australia] Tacho Change Over
Read the label on the can.
Date: Tue, 1 Nov 2011 09:59:15 +1100
Subject: Re: RE: [Syncro_T3_Australia] Tacho Change Over
Advertising never lies.
What would it fix?
> Re: "DO NOT SPRAY ANYTHING ON IT!"
> ........ except as I said, AFTER close eyeballing the foil for faults,
> CRC226 on the connectors! I did not suggest WD40!
> Those interested, google the specs/uses on CRC226.
> RE: "It may ....."
> Yeah and it may make it work.
> Date: Tue, 1 Nov 2011 07:32:07 +1100
> It may make it impossible to repair.
> Clean anything with a soft cloth and maybe some metho.
> > Peter,
> > It's always been a risk buying "pre-loved" (ie, near trashed)
> instrument
> > clusters sourced from afar in that the attached foil may prove to be
> > defective in some way and so may be the cause of a permanent or
> > intermittent fault/faults. In my case I feel lucky, I had no issue
> with
> > the foil, but a faulty foil is not at all uncommon, in much the same
> way
> > as finding broken plastic components of the cluster mounts and
> > instrument enclosures are not uncommon.
> > So I'd suggest a very close eyeball at the foil for faults, cracks,
> > splits and as Phill has said, double check all the connectors of the
> > foil to their individual connections. I'd be using CRC226 on these,
> just
> > to ensure best and ongoing continuity, especially now as you may be
> > having a problem in this area.
> > Also double check and CRC226 the main connector plug into the back of
> > the cluster, it can at times be problematic re-connecting it properly
> in
> > situ.
> > Cheers.
> > From: peter@coeconsult.com.au
> > Date: Mon, 31 Oct 2011 09:20:46 +0000
> > Subject: [Syncro_T3_Australia] Tacho Change Over
> > Hi all. I have checked through the posts and can't find a match
> to
> > this problem. Here we go. Sorry it is a story but the facts are
> > important here.
> > I had a nice tacho in a cluster that I got from the USA and over the
> > weekend swapped it over as I did not even have a clock in my cluster.
> > Very basic. My Syncro was built in 1988. I also had just got a proper
> > speedo with an odometer and 1 100,000 digit.
> > Install went OK and everything swapped over. Tacho working well and
> new
> > speedo OK as well. Two issues, the temp gauge not working and the
> > digital clock that initially worked, went blank. Drove to town parked
> > for about 2 hours while at dinner, then home. No problems.
> > This morning, a bit further in town. Parked for 10 minutes then took
> > off. 2 minutes later tacho needle drops to zero and engine stops, then
> > starts, then stops, keeps going then at a busy rounabout car dies.
> Same
> > sympton. Tacho needle drops then car stops. Stopped for 45 minutes.
> Car
> > starts and I fill up with petrol just in case fuel gauge a problem.
> Car
> > starts, off home and after 5 minutes, same problem. Stop start.
> Managed
> > to get home. Put Hart's vanagon syndrome connection in. Went round the
> > block. Same problem.
> > Put old instrumemnt cluster back in later today and problem went away.
> > Any thoughts from the wise heads out there. Shame because the new set
> up
> > looked really good.
> > A frustrated Peter from Port
