----- Original Message -----From: Jon ElliottSent: Friday, July 01, 2011 12:14 PMSubject: [Syncro_T3_Australia] Temp gauge sender
Could someone explain how the temp gauge sender on the thermostat causes the problem that has been the subject of discussion?Is a spare parts list / book available for the Syncro?I am trying to build up a stock of parts to keep the Syncro running when problems arise on my intended trip to the north of WA. Would members care to suggest a list of spares to carry?I have had my Syncro for 12 years and through this site I am learning all sorts of information about my vehicle I didn't know before.RegardsJon E
Sent: Friday, 1 July 2011 10:54 AM
Subject: Re: [Syncro_T3_Australia] Temp gauge sender
----- Original Message -----From: Jon ElliottSent: Friday, July 01, 2011 12:14 PMSubject: [Syncro_T3_Australia] Temp gauge senderCould someone explain how the temp gauge sender on the thermostat causes the problem that has been the subject of discussion?Is a spare parts list / book available for the Syncro?I am trying to build up a stock of parts to keep the Syncro running when problems arise on my intended trip to the north of WA. Would members care to suggest a list of spares to carry?I have had my Syncro for 12 years and through this site I am learning all sorts of information about my vehicle I didn't know before.RegardsJon E
----- Original Message -----From: Jon ElliottSent: Friday, July 01, 2011 1:51 PMSubject: Re: [Syncro_T3_Australia] Temp gauge sender
Thankyou for that explanation Bob. I cannot find any reference to a different sensor for 4WD in my Bentley VW manual?RegardsJon EFrom: Bob Dale <rcdale@bigpond.com>
the temperature unit is for the emc unit its resistance reading varies with the sensed temperature which affects the fuel mixture ie cold start to hot start when it fails the resistance is outside the operating design range of the emc unit and that is why the stalling, over rich fuel mix happens,the sensor is a different one to a 2 wheel drive vwregardsbob dale----- Original Message -----From: Jon ElliottSent: Friday, July 01, 2011 12:14 PMSubject: [Syncro_T3_Australia] Temp gauge senderCould someone explain how the temp gauge sender on the thermostat causes the problem that has been the subject of discussion?Is a spare parts list / book available for the Syncro?I am trying to build up a stock of parts to keep the Syncro running when problems arise on my intended trip to the north of WA. Would members care to suggest a list of spares to carry?I have had my Syncro for 12 years and through this site I am learning all sorts of information about my vehicle I didn't know before.RegardsJon E
I can help. Send me an email to plander@optusnet.com.au
> problems arise on my intended trip to the north of WA.��Would members
> care to suggest a list of��spares to carry?
> all sorts of information��about my vehicle I didn't know before.
> Regards
> Jon E��
Sent: Friday, 1 July 2011 2:08 PM
----- Original Message -----From: Jon ElliottSent: Friday, July 01, 2011 1:51 PMSubject: Re: [Syncro_T3_Australia] Temp gauge senderThankyou for that explanation Bob. I cannot find any reference to a different sensor for 4WD in my Bentley VW manual?RegardsJon EFrom: Bob Dale <rcdale@bigpond.com>
Please don’t forget to take a screw cap for the coolant expansion tank.... Hart
Sent: Friday, 1 July 2011 2:28 PM
Spares- Ignition switch, Hall sender, alt belt, cv joint, tie wire, gaffa tape, 12v wire + connectors, fuses. I would want to be sure my cv joints, belts and cooling hoses are A1 before I leave, even if that means removing and refitting. Also oil change for engine, gearbox and diff. Just to get you started i am sure there will be more suggestions. Greg E
joe
the only way i found out about is when i was having the problem, after the nrma gave up i rang mullers in sydney and described the problem he stated that it sounds like the temp sender so i drove over in another car and got one magic but i do not know if there was a defective batch but the symptoms returned after 6 months or so changed again fixed it i always carry a spare, this unit has been in for 4-5 years.
as far as spares a full set of belts is one that i would have with me maybe a spare dist cap and rotor i think that one really has to make sure that all the hoses are servicable covers on cv joints are intact etc
bob
Jon E
regards
bob dale
Jon E
If contact to it gets dodgy, or intermittent ..
----- Original Message -----From: Jon ElliottSent: Thursday, June 30, 2011 7:14 PMSubject: [Syncro_T3_Australia] Temp gauge sender
----- Original Message -----From: Bob DaleSent: Thursday, June 30, 2011 7:54 PMSubject: Re: [Syncro_T3_Australia] Temp gauge sender
----- Original Message -----From: Hartmut KiehnSent: Friday, July 01, 2011 12:23 AMSubject: RE: [Syncro_T3_Australia] Temp gauge sender
joe
bob
Jon E
regards
bob dale
Jon E
----- Original Message -----From: Bob DaleSent: Thursday, June 30, 2011 9:08 PMSubject: Re: [Syncro_T3_Australia] Temp gauge sender
joethe only way i found out about is when i was having the problem, after the nrma gave up i rang mullers in sydney and described the problem he stated that it sounds like the temp sender so i drove over in another car and got one magic but i do not know if there was a defective batch but the symptoms returned after 6 months or so changed again fixed it i always carry a spare, this unit has been in for 4-5 years.as far as spares a full set of belts is one that i would have with me maybe a spare dist cap and rotor i think that one really has to make sure that all the hoses are servicable covers on cv joints are intact etcbob----- Original Message -----From: Jon ElliottSent: Friday, July 01, 2011 1:51 PMSubject: Re: [Syncro_T3_Australia] Temp gauge sender
Sent: Friday, 1 July 2011 5:47 PM
----- Original Message -----From: Jon ElliottSent: Thursday, June 30, 2011 7:14 PMSubject: [Syncro_T3_Australia] Temp gauge senderCould someone explain how the temp gauge sender on the thermostat causes the problem that has been the subject of discussion?Is a spare parts list / book available for the Syncro?I am trying to build up a stock of parts to keep the Syncro running when problems arise on my intended trip to the north of WA. Would members care to suggest a list of spares to carry?I have had my Syncro for 12 years and through this site I am learning all sorts of information about my vehicle I didn't know before.RegardsJon E
Scott,
There is a unit on the market that allows you to run or drive and check the value of everything that sends a signal to the ECU.
Here’s the website:
http://shoebox-electronix.com/
Syncro_T3_Australia@yahoogroups.com ] On Behalf Of Scott Daniel - Turbovans
Sent: 01 July 2011 18:15
Temp gauge sender
as I wrote earlier..
I'd love to have the ability to switch in a default value ..
for testing or self-rescue.
----- Original Message -----From: greg espositoSent: Friday, July 01, 2011 2:07 AMSubject: Re: [Syncro_T3_Australia] Temp gauge sender
The question is Scott how do you have room for food and camping gear?Greg E
hi.you should know there are two temp sensors in the thermostat housing ( not the t-stat itself )one is for the temp gauge in the dash. ( the single contact one )the other one...two contacts with a connector plug ..talks to the ecu, so the ecu knows coolant temp.That is an important input.If temp sensor is wonky...it can run rich ..or lean ..though that doesn't seem to happen.
If contact to it gets dodgy, or intermittent ..that can keep the engine from starting easily ..or running right.and it can intermittent. I have seen them where they were fine cold..but way off when hot.I have worked on a running issue a lot, when all along it was connection at that ecu temp sensor.( ideally, I would love to have a default value you just switch in , even while driving, as back up or test device. ) .my list of spare parts I carry ....how much time have you got ?surely and ecu, ( all used parts are 'known good and tested units )temp sensor II ( the ecu one )thermostatdistributor.air flow meter.cap, rotor and wires.fuel pumpfuel filter or twomain and fuel pump relaysthrottle body with properly working idle contact switch on it.valve cover gaskets.spare clutch slave cylindervarious floods ....coolant, oil, oil filter or two, brake fluid, possibly some gear oila spare new CV joint for the rear.a short outer stub axle to run in front if an axle blows out there.more than that yet.a tail light bulb or two .and especially ever component ..here's another one ..oxygen sensor ..every component that is involved with the running of the engine ..spare throttle cableparticularly parts that can keep you from being able to keep moving.perhaps not much in the way of brake parts..you can often fake it with the brakes not working completely ..so not much in the way of spares there..but all the running stuff that you'd be in a real pickle without ..those for sure.oh...and injector or two.some spare fuel hose and clamps.maybe a starter, but those are heavy to carry and you can keep moving by push starting and being careful where you shut off if you have to.ditto on clutch ..you can keep moving even if you can't release the clutch normally with the clutch pedal ..you can fake it , with difficulty ..but you can keep moving with a clutch that will not disengage.I happen to have a small factory new 65 amp alternator..I take that on trips as a back up .belts of course ,some hoses..or a box of miscellaneous hose bits and clamps.I also believe in not trying too too hard to be really exact about which spare parts.Chances are if you brought it ..that's not the one you need.so I tend to bring bailing wire, tape, vice grips...and 'patch' stuff like that too.surely a spare air filter ..even two fuel filters if you expect bad fuel at all.the list can go on forever..but I do feel a whole lot better with a spare known good example of things like distributor , air flow meter, and ecu.I just had bad cutting out on a 2.1 wbxr engine ..tried another distributor .got even worse.....with nice backfiring.tried another distributor ..still cut out. ( turn the key off and back on real fast, and she' do again. )put in another ECU .now she's running fine.(tach would drop to zero when it cut out, pointing to ignition ) .so ..apparently........intermittent ignition caused by a bad ecu.and don't forget..a spare ignition switch, the electrical part..so small, not expensive, underbuilt, and they can act up easily.it's silly not to carry one.you can even just plug it into the harness and operate it with a screwdriver .gotta have one of those along.Scott----- Original Message -----From: Jon ElliottSent: Thursday, June 30, 2011 7:14 PMSubject: [Syncro_T3_Australia] Temp gauge senderCould someone explain how the temp gauge sender on the thermostat causes the problem that has been the subject of discussion?Is a spare parts list / book available for the Syncro?I am trying to build up a stock of parts to keep the Syncro running when problems arise on my intended trip to the north of WA. Would members care to suggest a list of spares to carry?I have had my Syncro for 12 years and through this site I am learning all sorts of information about my vehicle I didn't know before.RegardsJon E
Paul Dumais
Here's hoping you didn't do too much damage. My first T3 did manage to survive the exact same situation on it's maiden voyage to it's new home. I stopped as soon as I saw steam coming out of the rear vents. The headgaskets lasted another 186K+ after the incident despite having another 200K miles already there when I bought her.
Next time, I'll read the manual.;-)
sent from my electronic leash
On Jul 1, 2011, at 4:37 AM, Paul Dumais <paul.d.dumais@gmail.com> wrote:
> Hi All
> I agree on the spare belts my water pump/alternator belt broke today on the pacific highway near Byron. I had all my tools, but my spare was in my other van. So I'll have to get a lift back there tomorrow to fox her.
> I was confused when the battery light came on and only worked out what happened after a minute as I saw the temp gauge hit 3/4's and was still climbing. I went to pull off the highway and as I did the power steering died as the broken belt must have fouled and thrown the power steering belt. The a/c belt is aril there.
> So I hope she didn't get damaged. There was lots of bubbling, gurgling noises when I popped the engine hatch. Next time see the battery light come on I'll know to stop immediately.
> Paul Dumais
> Aerospace Engineer
Like Phill suggests EM him,Im sure he will hook you up with the workshop manuals and ETKA,glovebox edition.
BenC
> hi.
> or running right.
> thermostat
> distributor.
> air flow meter.
> fuel pump
> fuel filter or two
> more than that yet.
> belts of course ,
> and don't forget..
> Scott
> www.turbovans.com
> From: Jon Elliott
> To: Syncro T3 Australia
> Regards
> Jon E
