--- In Syncro_T3_Australia@yahoogroups.com, "Bill" <marg_bill@...> wrote:
> I've just picked up a new "temp sender" the two pin one that sends info to the cpu not the dash temp gauge. The one i've recieved is a push in type apn 029906041a. On further inspection it looks like i need a screw in type. My problem is i can't find a reference in bentler's to a screw in type. Any one shed any light. THANKS. BILL
pictured on page 19.8 in Bentley.
A chart of temp versus ohms is shown on page 24.19.
that still won't get you a part # though.
If you can order one for an 83 to 85 T3 van with 1.9 wbxr engine ..
that'll get you the right one., pretty sure.
there are a few mistakes in the Bentley manual.
one of the most glaring I know of is in the cooling system section for testing the waterboxer pressure cap ..
those 'not-that-reliable' blue pressure caps.
There picture shows pressure testing the very conventional all metal cap used on the 82 and 83 diesel vanagon.
They even tell you the adapter part number to fit the cap ..so you can use a regular pressure tester.....
When you look up that adapter number ..it's for the metal diesel vanagon van .......nothing to do with waterboxers at all.
I have had parts people not be able to look up a Temp Sensor II for a Syncro van ..
they'd come up with what you got ..the temp sensor II for a 2WD 2.1 waterboxer van.
Obviously ..
it fits the plastic t-stat housing used on 2WD 2.1 wbxr engines ..
that part will fit on your engine ..
but your aluminum t-stat housing is much better built of course.
scott
www.turbovans.com
On 3/1/2012 7:06 PM, Bill wrote:Just found a reference in Bentleys 24.49 saying push in not used in syncro vehicles but no further reference to what is used in syncro vehicles. Anyone replaced one lately. Bill
Sent: Friday, 2 March 2012 2:06 PM
Subject: [Syncro_T3_Australia] Re: Temperature sender screw in or push in.?????
Screw in and is made of copper or something similar have replaced 2 in mine so far. If you are in Sydney millers at Campsie or volksmuller at arcadia will have them. Bob dale
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Bill
Sent: Friday, 2 March 2012 2:36 PM
Subject: Re: [Syncro_T3_Australia] Re: Temperature sender screw in or push in.?????
The push in temperature sender for 2wd 2'1 wbw p/n 029 906 041a is not suitable for the 2.1 wbx in the t3 SYNCRO. The correct part is the same as the 1.9 wbxr motor part no 0 280 130 026 available from well stocked large city vw suppliers. Thanks guys much appreciated. This is particularly usefull for us country based folk who do most of our parts sourcing on phone or internet using part no's. Thanks again Bill.
--- In Syncro_T3_Australia@yahoogroups.com, "Robert Dale" <rcdale@...> wrote:
> in.?????
> <mailto:Syncro_T3_Australia%40yahoogroups.com> , "Bill" <marg_bill@>
Sent: Friday, 2 March 2012 2:50 PM
> O.k. I always wondered why they called one temp 2, got the books out and worked it out. The air temp sensor in the air flow meter is temp 1 and the push in sensor on the thermo housing is temp 2. A grid in the bentley shows resistance relative to temp for diagnosis for those two sensors. The additional sensor - blue screw in - for syncro, I cant find a grid for - help? This is the one syncro owners complain about related to rough running Bill. I assume this is the one you are trying to replace (0280130026). Greg E
> From: greg esposito <gregespo73@...>
> Â
> That last one was the push in - o/ring one. The screw in is 0 280 130 026 which is the syncro specific one. I think this is the one they call temp II. Greg E
> Â
> Whats the part number of the one you got? Temp II is 025 906 041a I think
> From: Bill <marg_bill@...>
> Â
Sent: Friday, 2 March 2012 4:36 PM
> Â
> Â
> Â
