That’s the sort
of thing that I hope to find. A complete coolant change would need
7 litres of concentrate. The handbook specifies 40% min coolant; that is
G11 and I don’t know if the 12+ would be any different.
To repair the stripped
exhaust stud thread, I had to remove the coolant pump pipe and I have to
replace the amount so lost. In hindsight, I could have re-used the
coolant that I caught when I removed the pipe.
I used the last of the
12+ that I had in stock to top up what I had drained and I didn’t have
enough to achieve the 40% so probably the quick solution is to get the 1.5
litre contained from the nearest VW dealer to get the ratio right and then look
for a cheaper source.
[mailto:Syncro_T3_Australia@yahoogroups.com]
On Behalf Of Ken Garratt
Sent: 07 October 2011 10:59
Re: Thermostat and Coolant
Les,
Try getting pricing for 5 litre containers of G12 Plus, it should be cheaper
than at the per 1.5 litre bottle rate.
