Thought I would ask if anyone is selling some tires before I go out and look for new.
I'm after commercial tires for original rims (205R14). Looking for very good used, happy for tires only or tires on original rims.
I'm in Brisbane, probably not worth freighting tires in if your a long way away.
I have run Michelins (agilis) on the Syncro and my T2 before, so will most likely get them if no one has a good used set (if anyone knows a cheap place to buy these?).
I have been procrastinating on tires for a while, I have a half worn set of off road tires and given the driving I do I'm better with a good set of commercial tires and put the 4WD tires in the shed and put back on when I go out for a little fun,
I'm not fussed if tires are not worn perfectly even, I usually leave the tail shaft out (and plan to get a decoupler at some stage)
