Thank's Andy,
So many times on this forum members ask for advice and we never get to hear the outcome. We can all learn from other people's experiences instead of reinventing the wheel.
Just as a reminder. If there is an indication of low coolant, the temperature gauge will also rise although the coolant temperature may be normal.
> raredownunder <rafear@internode.on.net> wrote:
Thanks for everyone's advice.
By the time Tony got here this morning he had already added some of the local water to top
up the reservoir. This is unfortunate as the tap water in Ceduna is very corrosive so I
recommended to him that he flush the system ASAP when he gets home.
There were no obvious leaks in the system, and the bus has an after market VDO coolant
temperature gauge in addition to the factory fitted one. The temperature in the bus was
sitting at a relatively constant 80+ish. I suspect the slight rise in the gauge yesterday
was related to the 140kph speed of the bus rather than any problem with the cooling system!
Anyway, the reservoir was full (even at high engine revs) and with no other obvious faults,
Tony and I came to the same conclusion that you mentioned Phil - the sensor is probably
dirty. He was very keen to try to reach Norseman today so he headed off mid morning with
some distilled water and one eye constantly on the temperature gauges.
It is a lovely van that has obviously been well nurtured and loved, and had many useful
modifications/additions made to it. And so clean - made me embarrassed to show Tony ours!
Regarding the original problem, it appears that Alf was right on the money - o-rings to the
injectors.
Tony highly recommends the mechanic in Whyalla, which may prove a useful contact for those
heading across the country and have a problem half way.
Hopefully we will here from Tony within a couple of days with him having made it safely home
without further mechanical problems.
Andy.
