weeks.
I have need of a towbar for the Syncro and the only commercially
available bar is about the worst design one could imagine. It is so
illogical that I can't understand why they ever did it that way.
The T3 has a perfectly good set of mounting points available, and
that is where the original bumper mounts to the body rails. (The
Telecom Syncros used the same points and this was a very sturdy bar.)
I designed a towbar that mounts from those points and permits the
original bumper to be used. In my case, I have the Trakka
conversion which came with a deep aluminium bumper, so I continue to
use it.
I have posted a set of pics of the new bar. If anyone wants to have
one built, I will send them the drawings. This cost about $300 for
material, machining and assembly, and the galvanizing cost $75. For
$375, I have a towbar whose fail load at the weakest point is above
ten tonnes.
Les Harris
Australian Syncronauts
