Hi Greg,
Think very very carefully before committing to a Trakka windscreen install.
Windscreens O'Brien would be the most expensive glass installer ever.
OH&S mandates etc usually prevent customer entry into WOs workspace, so you can't monitor/make decisions on the fly.
Install of top edge is a beast. Installers will hate it and you. Ask Hartmut. His install was a total nightmare.
If in good condition, re-use existing rubber seal. Better to use the seal you know fits rather than a new seal that may well prove to be a different profile and cause serious issues with poor/gaping fit between glass and seal. Fortunately I re-used my
seal at the time, that helped a lot but was still a very hard top edge fit procedure. Tradies today hate a challenge, especially if it's not straightforward, taking too long, running behind schedule or nearly knock-off time.
What worked best for me was to order a replacement screen (full legal tint + darker top edge tint) through a mobile installer. So the two installers did the job in my garage, I was able to monitor the proceedings from go to wo, inspect opening for corrosion,
crud etc and coax them along when it came to fitting the top edge.
So for this procedure, definitely arrange to be present for the duration, to hand over the vehicle and be absent, you may well rue the day.
Good luck.
greg.navarro61@yahoo.com.au [Syncro_T3_Australia]" <
Syncro_T3_Australia@yahoogroups.com>
Date: 04/01/2016 8:54 PM (GMT+10:00)
To:
Subject: [Syncro_T3_Australia] Trakka Windscreen
Hello I have to replace the front windscreen of my Trakka and wondering if I should be aware of anything before I hand it over to the "experts" at Windscreen O Brien. With the pop top so close to the windscreen I am sure it won't be straight forward.
Also wondering if there is any maintenance that should be done in that area at the same time.
Thanks Greg N
