Hi Hartmut, Graham and ALL,
Pleased to report I arrived back home from the Old Bar Festival on Friday last ... a pleasant 12 day leisurely round trip with no hiccup of real note. Touch wood?
Given recent experiences by some, I can only emphasise the importance that negative wire grounds play in so many aspects of our syncros proper function .... or inconvenient failure.
Perhaps in the past we all have been guilty of looking first elsewhere for the solution to a malfunction when in fact the culprit can simply be one of many negative wire grounds that have been overlooked in terms of preventative maintenance. I'm thinking
this issue should really be a FIRST port of call in fault diagnosis ... not near last.
For example, in order of recent occurrences ...
Graham set out for Old Bar but had to turn back home when the cooling system spat the dummy because the radiator fan was simply not working at all. The culprit, once found, was a bad (oxidised/rusted) chassis
grounding cluster that the fan negative wire was connected to ... adjacent LHS of the fuse box.
Hartmuts Tristar unexpectedly spat the dummy halfway home to Port Macquarie with black exhaust smoke and loss of power. Limped home slowly and in the process, spat out lots of wasted fuel. Main culprit was a bad ECU negative wire ground.
At Port Macquarie, I experienced out of the blue a not dissimilar but lesser issue. It concerned the 12vdc positive cable that supplies a charge current
from the 240vac 30 Amp charger to the camping battery. The charge current in the cable was being blocked from reaching the battery by a failed/degraded inline fuse holder.
So for me, having learnt of Grahams finding, I immediately dropped my glovebox, lowered the fusebox and eyeballed the two grounding clusters that connect fourteen negative cables to chassis ground. Pulled all the wires, cleaned the terminals to the wires,
cleaned the two grounding clusters and gave a lick of dialectic grease to all mating components and reinstalled. It occurred to me I had never ever serviced this area before!
As for Hartmuts ECU negative ground, well I know I've previously cleaned and lubricated mine several years ago so touch wood, should still be OK.
So please, be sure to take the time to check out all your ground connections. Could well avoid an untimely failure some time soon.
For those who've not yet found it in the Syncro Forum files section, here reproduced below is a reminder checklist from PK of TODO items worth addressing any time soon, not a complete list but a very good start ...
Here is list of causes / fixes for any unpredictable behavior & not in any real order.
01. faulty plugs
02. faulty plug leads (only genuine VW OEM copper)
03. faulty distributor cap
04. remove / clean all sensor connections
05. remove / clean all ground connections
06. add capacitor across pins 2 & 3 Air Flow Meter (AFM).
07. Add earth wire to AFM case.
08. faulty O2 sensor
09. faulty temp 2 sensor
10. faulty Hall sender
11. remove / clean ECU main connector.
12. test sensor continuity to ECU
13. faulty fuel regulator
14. faulty fuel filter
15. check fuel pressure
16. check vacuum
17. check timing
18. carbon build up on valves
19. Air Flow Meter carbon track worn, move.
20. Faulty fuel pump relay
21. Faulty ECU power relay
22. Faulty coil & /or connections.
23. & a few other things I haven't thought of.
PS. The Old Bar Festival 2017 record attendance challenge beat the previous record by approx. 50 kombis!
It was also quite exciting joining the huge congo line of kombis in the return run between Old Bar and Taree.
Finally, attached is a pic of the OB syncros that played hide and seek with the local "officionados". Fun times indeed! Thank you to all those who joined the freecampers group. We must
all do it again sometime soon!
From: Syncro_T3_Australia@yahoogroups.com <Syncro_T3_Australia@yahoogroups.com> on behalf of Hartmut Kiehn hartis@live.com.au [Syncro_T3_Australia]
Sent: Wednesday, 4 October 2017 11:00 PM
To: Syncro Group
Subject: [Syncro_T3_Australia] Trip home
To my T3 friends who taken care of the tristar and its driver (me) when the MV got very ill on trip back home from Old Bar to Port a huge Thank You. Dont really know what i could have done without the shield from the rear. Especially when the trucks started
honking not happy having to go 50kmh through black smoke of unburnt fuel...
Richard and Arne thank you so much for all your knowledge sharing and Arne giving a full day of help to get the MV revving again.
We changed cat con sensor, no2
Sensor, temp sensor, AFM for a new one, checked the system for water leaking into engine because of the steam blowing from exhaust ....
All of the above where of some help but the real break through came when Arne started to clean every single one ground connection including the ECU. He used emery paper cleaning them until shiny and that changed it back to normal...
Did a test run today with Ken as an observer...all seems to be functioning again. Would have made Les very proud.
