Tyre Placard.
Dear Ben ,
I think the diameter of my tyres is 27.75" but the Cooper web site would verify for this size H/T. I haven't experienced any clearance problems (I DON'T have the 16" trailing arms) but I couldn't get the chains on the back when I had the 75 series tyres. I've only tried them on with the new 70 series tyres -haven't had cause to use them in earnest yet. As far as drivability goes I think it has become more driveable as the smaller tyre profile has masked the gap between 2nd and 3rd gear that I was more concious of when running the 75 profile tyres. It is reving harder though at 100 K. However I have always thought my 2.1 wasserboxer goes quite well and easily stays with other traffic but perhaps I'm getting old and anything seems fast when it replaced a T2 Kombi.
--- On Thu, 10/12/09, bencroft96 <bencroft96@yahoo.com> wrote:
Subject: [Syncro_T3_Australia] 16 inch wheels
Received: Thursday, 10 December, 2009, 8:41 PM
Roger,do you know the diameter of your tyres?Do you have any clearance probs?I just wonder if we had of gone to the 75 series,would we be scrubbing,on lock.How is the drivability of your bus?Acceleration, uphill etc?
--- In Syncro_T3_Australia @yahoogroups. com, Roger Bell <bellrmit@.. .> wrote:
> Hi Fellows,
> I'm currently running 215/70R16 Cooper Discoverer H/T Tyres on the VW 51/2" x 16 rims. I bought 4 almost new tyres from someone who changed the original rims on a Toyota Hilux plus 2 new ones to give me 6 to circulate with 2 spares.I went for the predominately road tyre with the lower 70 profile as I find the majority of my driving is on bitumen and I was looking for something relatively quiet, longlasting with reasonable grip and roadholding. Ideally I would also have an aggressive set of mud tyres for going off road but I compromise by carrying chains if I am going somewhere really muddy.
>  I previously had Hankook Dynamic RF04 which was a block pattern 80/20 all terrain tyre with a slightly higher profile but narrower section (205 x 75). I got about 60,000kms circulating the 6 of them. I haven't found too much trouble getting the tyres I want with the 16" rims but I would have more options if they were 6" wide instead of 51/2" The slightly lower profile of the current tyres also means I can fit the chains on all wheels whereas before I only had enough clearance for the front wheels.
> You can see from my postings I am a little old lady who only uses the syncro to go to church on Sundays.
> Cheers
> Roger
> PS I have my original 14" rims/tyres/hubcaps advertised on the www.kombiclub. com site as I found I haven't used them.
> --- On Thu, 10/12/09, Gary Cookson <gary@...> wrote:
> From: Gary Cookson <gary@...>
> Subject: Re: [Syncro_T3_Australi a] Re: Tyre Placard.
> Received: Thursday, 10 December, 2009, 7:04 PM
> Ben, I'm jumping in and answering on Roger's behalf. He has a set of genuine VW 16" steel wheels. The sort that were fitted to the factory 16 Syncros.
> Not many of them in Aus i imagine, they fetch a fair bit over in Europe.
> Not sure what tyres they are though.
> What rims are you running?
> Gary
> On 10/12/2009, at 9:44 PM, bencroft96 wrote:
> Hi Roger,Do you have 16 inch wheels?Can you tell us what rim they are?What tyres do you run?I have recentley put Yoky A/Ts Tyres onboard,and have nothing but praise for the package.My vehicle is better than it ever has been.Buying tyres for 16 inch tyres was a major drama.
> --- In Syncro_T3_Australia @yahoogroups. com, Roger Bell <bellrmit@ .> wrote:
> > Les,
> > This is my original 14"  wheel foil sticker which seems to be the same as yours in style and location. The 16" one was demanded and added when the original owner also purchased  factory 16" wheels.
> > I agree my musings on the reason for the wording on Ben's sticker was pure speculation.
> > Cheers
> > Roger
> > --- On Thu, 10/12/09, bencroft96 <bencroft96@ ...> wrote:
> > From: bencroft96 <bencroft96@ ...>
> > Subject: [Syncro_T3_Australi a] Re: Tyre Placard.
> > Received: Thursday, 10 December, 2009, 4:58 PM
> > Hello all,as my computing skills are next to zero, one day I will be able to send photos.I am not the only one who has this sticker though.Phill, you know were I will be on monday.Maybe you could come and take some photos.
> > --- In Syncro_T3_Australia @yahoogroups. com, "Les Harris" <leslieharris@ ...> wrote:
> > > Roger,
> > > Without knowing the origin of the sticker on Ben's Syncro, we are just
> > > speculating. I owned several Type 3s but have no recollection of the tyre
> > > placards on them. Ben's sticker covers 5 ½ " and 6" rims, so would cover T3
> > > 2WD as well as AWD. The last characters "T-2+5" are a puzzle on their own.
> > > I have attached another pic of the placard on my Syncro, showing that it is
> > > in the same place as Ben's â€" left hand A pillar immediately under the door
> > > check link.
> > > Ben,
> > > Is it possible for you to post a picture of your sticker? It might ring a
> > > bell with someone, either here or overseas. As you say, you can't be the
> > > only one with it. Mine is an aluminium foil sticker. Is yours foil or
> > > paper?
> > > Could I ask everyone to take ten seconds to look at their own Syncro?
> > > Les
> > > _____
> > > From: Syncro_T3_Australia @yahoogroups. com
> > > [mailto:Syncro_ T3_Australia @yahoogroups. com] On Behalf Of Roger Bell
> > > Sent: 10 December 2009 00:12
> > > Subject: RE: [Syncro_T3_Australi a] Re: Tyre Placard.
> > > I remember my brother had a square back type 3 VW in the 70's that had
> > > original equipment 6ply tyres -hardly a necessity given its weight/load
> > > capacity. The explanation he was given was they were just that bit more
> > > expensive to make the local content reach the desired percentage. I am sure
> > > all our syncros were fully imported but there could have been some similar
> > > loophole in tariffs as they shuttled between Germany and Austria in the 80's
> > > which gave an advantage to lesser spec tyres and hence the placard.(There' s
> > > no such restriction on my foil ones for 14" and 16" wheels.)
> > > On the other hand this speculation may be just that- idle erroneous
> > > speculation on my part which wouldn't pass Les's first test of verifyable
> > > engineering knowledge..
> > > Don't they reckon if you are wondering whether there has been a conspiracy
> > > or a cockup always go for the cockup!
> > > Cheers
> > > Roger
> > > --- On Wed, 9/12/09, Les Harris <leslieharris@ ...> wrote:
> > > From: Les Harris <leslieharris@ ...>
> > > Subject: RE: [Syncro_T3_Australi a] Re: Tyre Placard. [1 Attachment]
> > > Received: Wednesday, 9 December, 2009, 6:37 AM
> > > Ben,
> > > Attached is a pic of the tyre placard on my Syncro. This bears a VAG number
> > > and can reasonably be presumed to be the original placard fitted by VAG.
> > > Regarding the cautionary aspect of the placard on your vehicle, I would have
> > > to dig through the ADRs for the period to see if it is ADR related.
> > > Going back a bit earlier in VAG history, the owners handbooks for new
> > > Beetles always carried a section on tyres which stated (fahrvergnugen
> > > notwithstanding) that high speed driving was the enemy of long tyre life.
> > > Given the level of tyre technology at the time, this was reasonable. I
> > > wonder if the placard on your Syncro is a continuation of this earlier time.
> > > Les
> > > _____
> > > From: Syncro_T3_Australia @yahoogroups. com [mailto: Syncro_T3_Australia
> > > @yahoogroups. com ] On Behalf Of bencroft96
> > > Sent: 08 December 2009 22:28
> > > The tyre placard is a sticker that is just under the nsf check strap,it
> > > reads.
> > > RECOMENDED COLD TYRE IFLATION PRESSURE
> > > Tyre-185 R-14c Rim-5 1/2 Jx14
> > > FRONT 300kpa REAR 370kpa
> > > Tyre-205 R-14c Rim-6Jx14
> > > FRONT 250kpa REAR 300kpa
> > > WHEN FITTED WITH THESE TYRES,THIS VEHICLE SHOULD NOT BE DRIVEN FOR PROLONGED
> > > PERIODS AT HIGH SPEEDS. T-2+5
> > > I do have an Atco compliance plate with build date 6/89,rivited on osf,under
> > > check strap.
> > > Maybe this warning has to do with the different tyre pressures front to
> > > rear?I cant be the only one with it though.
> > > <http://au.mc531. mail.yahoo. com/mc/compose? to=Syncro_ T3_Australia% 40yahoogro
> > > ups.com> @yahoogroups. com, "bencroft96" <bencroft96@ ...> wrote:
> > > > Hang on guys,Ill go down and have a good look at it
> > > _____
> > > See what's on at the movies in your area. Find out now
> > > <http://au.rd. yahoo.com/ movies/mailtagli ne/*http: /au.movies. yahoo.com/ sessio
> > > n-times/> .
> > ____________ _________ _________ _________ _________ _________ _
> > Win 1 of 4 Sony home entertainment packs thanks to Yahoo!7.
> > Enter now: http://au.docs. yahoo.com/ homepageset/
> See what's on at the movies in your area. Find out now: http://au.movies. yahoo.com/ session-times/
Win 1 of 4 Sony home entertainment packs thanks to Yahoo!7. Enter now.
> This gets curiouser and curiouser. Mine was Ateco delivered and had
> 6�������� rims. Could the 5 ���� ������� have been fitted to the early round
> headlight Syncros?
Yes.
> PS: Your Plain Text emails frequently scramble part of the text. Have
> you considered using HTML?
I'm using reply.
Just had a call  in regard to a 92 Syncro Camper 1992 built ,  2.1 Oettinger WBX, Dual batt. Set up, bullbar, etc etc maybe worth  a look  $ 8000.-   Ring Stephen  0400 356 057
This one was one of the very last ones built
hartmut
Most email programmes have options for text and formatting. Plain text is
the default setting for many of them but, as you can see below, cannot cope
with much more than the basics. When you use the default reply function, it
is unable to recognize parts of the original email.
Have a look at the settings available to you and you should be able to clean
it up quite a lot. In this instance, I have used the default reply
function, so is using your Courier New font. My email programme is Outlook,
in which all parameters can be set.
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of
plander@optusnet.com.au
Sent: 11 December 2009 06:11
Subject: Re: [Syncro_T3_Australia] Re: Tyre Placard.
> 6� rims. Could the 5 ½ “ have been fitted to the early
round
> headlight Syncros?
Yes.
I'm using reply.
Yahoo! Groups Links
Les,
I am not using an email program. I just use the web.
On another subject, how do I send attachments when using the syncro forum?
> Phill,
> is
> cope
> function, it
> clean
> Outlook,
> > 6����������������� rims. Could the 5 ��������� ���������������� have been fitted to the
> early
> round
> > headlight Syncros?
> Yes.
> I'm using reply.
hi all just spoke to stephen [xtelstra traka]soonds interesting he siad the motor was 120hp?iasume this is not standard, i hope to get photos shortly anyone got ideas about motor thanks andy
> hartmut
Andy, the engine is an original Oettinger 4 WBX Oettinger also produced the 6cyl WBX with 160 hp (I think) these engines were original VW developments but because VW never went ahead
With them the designs were handed over to Oettinger. When I visited the Factory with Graham Lees in 1989 we saw a 6 cyl installed into a brand new Beetle ! This car was for the Prince of Monaco.
If this engine is in good nick it indeed is a rare find . Good Luck Hartmut
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of andysherriff@ymail.com
Sent: Monday, 14 December 2009 11:21 AM
Subject: [Syncro_T3_Australia] Re: Xtelstra Trakka
> hartmut
Group,The last numbers on my placard was a typo,it does read t2-5s.
> Les,
> > Les Harris <leslieharris@...> wrote:
> > Phill,
> > is
> > cope
> > function, it
> > clean
> > Outlook,
> > Les
> > plander@...
> > early
> > round
> > > headlight Syncros?
> > Yes.
> > I'm using reply.
> > Yahoo! Groups Links
There was a guy in Sydney building Oettinger 4 WBX engines so there must be a fair few around. I think that they were 2.5 litres and required 98 fuel which was not available back then. They lowered the compression buy machining the heads with a hammer and chisel.
A lot of people say that they have Oettinger 4 WBX engines, but they are really just DJ pistons in the MV engine (Which is a good upgrade).
> produced
> new
> Hartmut
> shortly
> <mailto:Syncro_T3_Australia%40yahoogroups.com> , "Hartmut Kiehn"
> Oettinger
> > hartmut
Is DJ the brand?
--- On Mon, 14/12/09, plander@optusnet.com.au <plander@optusnet.com.au> wrote:
From: plander@optusnet.com.au <plander@optusnet.com.au>
Subject: Re: RE: [Syncro_T3_Australia] Re: Xtelstra Trakka
Received: Monday, 14 December, 2009, 11:27 AM
> produced
> new
> Hartmut
> [mailto:Syncro_T3_Australia @yahoogroups. com] On Behalf Of
> andysherriff@ ymail.com
> Subject: [Syncro_T3_Australi a] Re: Xtelstra Trakka
> shortly
> <mailto:Syncro_ T3_Australia% 40yahoogroups. com> , "Hartmut Kiehn"
> Oettinger
> > hartmut
There were basically 2 2.1 engines available in the Transporter.
The MV (engine code) was low compression and the DJ had high compression.
We had the MV (70kW) which was made for third world fuel.
The DJ engine requires 98 RON and is 82kW.
> Is DJ the brand?
> > produced
> > new
> > Hartmut
> siad
> > the
> > shortly
> > Oettinger
> > > hartmut
> _________________________________________________________________________
> _________
> Enter now: http://au.docs.yahoo.com/homepageset/
