Van-Cafe Easy Shift Kit mod for Syncro.
Gday ALL,
In case anyone has had a problem with this modification as I did, in
particular, losing the reverse/growler gears lock-out feature, which
you need so you don't accidently slip into either of those gears.
The right fix was to shorten the supplied special machined spacer
sleeve that slides down the gear shaft. I reduced the length by 5mm.
(square bottom end)
My lock-out works perfectly again. Any questions, feel free. Cheers.
