to replace a manual steering rack in a 1982 vanagon
dobson_hamish@yahoo.com.au
0448674617
hamish dobson
bribie island
0448674617
hamish dobson
bribie island
On 7/17/08, hamish dobson <dobson_hamish@yahoo.com.au> wrote:to replace a manual steering rack in a 1982 vanagon
0448674617
hamish dobson
bribie islandHamish,You can substitute hoses for the hardlines. They will also be much easier to install. Most hydraulic hose shopsshould be able to fabricate these for you. One side is low pressure so much easier to get. Most auto parts storesshould have that.In addition to the above items, you will need a slightly different steering shaft. That is the piece that goes from.The one from the PS system is slightly shorter and has a different coupling. in a pinch, you can get your old onecut and rewelded to fit. I found it much less expensive to buy the used parts. If you use the hardlines, you will alsoneed the hoses that go fromt eh hardlines to the pump and reservoir. Speaking of which, you will need the reservoiras well.Of course, I am in an area where parts for t3's are more plentiful (California). I am not familiar with auto parts storesor supply systems in OZ. I can help you get most of these parts in the US if you have trouble finding them locally.there. the only part I can no longer get here are RHD powersteering racks. my parts dealer only had a few that weremistakenly sent here. remember, we drive mostly LHD cars.=)I've done this converrsion twice with more than satisfactory results even w/o adding the relays to adjust idle when thepump engages.cheers,BenT
Hi there Andy - any progress on the avaliability of teh powersteering rack ?
Hamish
0448674617
Gidday Hamish,
I will have a perfectly functioning power steering rack available
within (I hope) a couple of months, but no other parts.
Please pmail me if you might be interested.
Andy.
Ceduna SA.
