viscouse coupling
Can someone give me the outside dimensions (diameter and length) of
the viscouse coupling. I wish to use it in another vehicle. thank you
Paul
Paul,
Contact Mike Plompen (http://www.busman.be/).  Mike sells reconditioned viscous couplings and might be able to give you the dimensions.
Sent: Thursday, August 07, 2008 8:33 PM
Subject: [Syncro_T3_Australia] viscouse coupling
Paul
Gday Paul,
Just measured my old VC on the workbench.
It's 144mm in diameter plus it has a welded on 18x9mm piece of metal
(locator key)on the circumference that adds another 2mm.
The length is 135.5mm.
--- In Syncro_T3_Australia@yahoogroups.com, "powerbandpowerband"
> Paul
--- In Syncro_T3_Australia@yahoogroups.com, "Ken" <unclekenz@...>
wrote:
>Thank you Ken for taking the time to measure the coupling for me.
You may be woundering why I need one. I have a customer who is
getting me to build a 2 wheel drive motorcycle & sidecar, i.e, when
the rear wheel spins the sidecar wheel starts to drive. Paul
> Gday Paul,
metal
of
thank you
> > Paul
