VW T3 Boxter front brake kit (Brembo calipers)
Hi All,
As my 2.1wbx just died its time to move some parts on.
Porsche Boxster front brake calipers Brembo’s, Wouldn’t fit with my mefros so just gathering dust.
2 x discs
braided lines
new pin and spring kit
pads are like new
brackets to suit T3’s
$1300.00ono
Am curious when you say “won’t fit with your Mefros” what size rims are they? I have 15 inch steel rims I bought form a fellow Syncro enthusiast, I also have the original 15 inch alloy wheels … no idea what they’re called, and I also have 16 inch wheels from a Tiguan. I’d love to have better brakes on the Syncro given it’s GVM, fully loaded and and ready to roll for a trip, is 2400kg.
Hi Martin,
I tried fitted them, went to fit my rims and the caliper touches the inside of the rim. it clears the inner diameter of the wheel however touches the inner. Would work if i used spacers but not keen to go down that path. I should take some measurements and draw a diagram.
I have found all the bigger brake kits only work with some alloys. Not with metro steel rims. Not enough room.
Hi Joe,
I’m interested too.
I have forged Audi alloys which seem to provide some more space than the steel rims.
If you could make some measurements that would be helpful.
Cheers Tom
Il take some measurements fellas and get back to you. I wish i could run these but im lovin the steelies at the moment.
