Thanks in anticipation.
Yurik
----- Original Message -----From: Yurik OrlowskySent: Saturday, March 14, 2009 4:34 PMSubject: [Syncro_T3_Australia] Wanted a T3 towbarIn April I am heading off to Melbourne and on the return journey to Perth I plan to tow a trailer for my son who is being relocated. A towbar installation is needed and if one is available for purchase in either Perth or Melbourne I could come directly for pickup.
Yurik
Dear Yurik,
I have a 2nd hand Hayman Reece one which I originally intended fitting but can't work out how to do it without removing the exhaust system.Les is basically right there are better designs. I paid $100 for it and have cleaned it up and repainted it but would be negotiable either on price or alternatively any information on whether it is indeed possible to fit without disturbing my exhaust system. I did of course remove the rear bumper before attempting the installation. I can send photos of the tow bar if you are interested.
Melbourne.
--- On Sat, 14/3/09, Yurik Orlowsky <yuriko@iinet.net.au> wrote:
Hi Les,
Thanks for the photos of your designed towbar. I like its simplicity and the way it incorporates mounting holes for the Trakka Al bumper. The underslung cross bar and tongue lowers the tow ball which would be an advantage for a syncro particularly for my higher 16” syncro. If time permits, I would like to make one to your design – trust you will release copyrights on this.
Regards.
Yurik
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Les Harris
Sent: Saturday, 14 March 2009 2:59 PM
Subject: Re: [Syncro_T3_Australia] Wanted a T3 towbar
Yurik,
The only one I have seen for the T3 was made by Hayman Reese and would severely embarrass Heath Robinson. Needing to tow a boat, I made my own. It attaches to the chassis rails using the same mounting points as the stock bumper. It is the direct opposite of the HR device. Mine has four parts and will tow a D9. Theirs has a thousand parts and frightens me to look at it.
See attached pics.
Yurik
Dear Yurik,I have a 2nd hand Hayman Reece one which I originally intended fitting but can't work out how to do it without removing the exhaust system.Les is basically right there are better designs. I paid $100 for it and have cleaned it up and repainted it but would be negotiable either on price or alternatively any information on whether it is indeed possible to fit without disturbing my exhaust system. I did of course remove the rear bumper before attempting the installation. I can send photos of the tow bar if you are interested.CheersRogerMelbourne.
--- On Sat, 14/3/09, Yurik Orlowsky <yuriko@iinet. net.au> wrote:
Subject: [Syncro_T3_Australi a] Wanted a T3 towbar
Received: Saturday, 14 March, 2009, 1:34 PMIn April I am heading off to Melbourne and on the return journey to Perth I plan to tow a trailer for my son who is being relocated. A towbar installation is needed and if one is available for purchase in either Perth or Melbourne I could come directly for pickup.
Yurik
Hi Roger,
Thanks for your response. I am particularly interested in the towbar Les designed but may be pressed for time to manufacture it. If the Hayman Reece one was a simple bolt on type I would be interested in it even though its design may be questionable. I would appreciate you sending some photos.
Yurik
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Roger Bell
Sent: Monday, 16 March 2009 12:30 AM
Dear Yurik, I have a 2nd hand Hayman Reece one which I originally intended fitting but can't work out how to do it without removing the exhaust system.Les is basically right there are better designs. I paid $100 for it and have cleaned it up and repainted it but would be negotiable either on price or alternatively any information on whether it is indeed possible to fit without disturbing my exhaust system. I did of course remove the rear bumper before attempting the installation. I can send photos of the tow bar if you are interested. Cheers Roger Melbourne.
----- Original Message -----From: Yurik OrlowskySent: Monday, March 16, 2009 11:48 AMSubject: RE: [Syncro_T3_Australia] Wanted a T3 towbar
Hi Les,
Thanks for the photos of your designed towbar. I like its simplicity and the way it incorporates mounting holes for the Trakka Al bumper. The underslung cross bar and tongue lowers the tow ball which would be an advantage for a syncro particularly for my higher 16 syncro. If time permits, I would like to make one to your design trust you will release copyrights on this.
Regards.
Yurik
----- Original Message -----From: Les HarrisSent: Monday, March 16, 2009 12:17 PMSubject: Re: [Syncro_T3_Australia] Wanted a T3 towbar
Yurik,I have drawings for it and it is simple but very strong. I will did them out and see what form I can use to send the to you. I had mine gal dipped for durability. Since it was a vertical immersion dip, I provided holes so that the cross tube is fully coated on the inside.Les----- Original Message -----From: Yurik OrlowskySent: Monday, March 16, 2009 11:48 AMSubject: RE: [Syncro_T3_Australi a] Wanted a T3 towbar
Hi Les,
Regards.
Yurik
>Les
> Hi Roger,
> designed but may be pressed for time to manufacture it. If the HaymanReece
> one was a simple bolt on type I would be interested in it even thoughits
> design may be questionable. I would appreciate you sending somephotos.
>but
> Regards
> Yurik
> Dear Yurik,
> can't work out how to do it without removing the exhaust system.Les isor
> alternatively any information on whether it is indeed possible to fitbumper
> before attempting the installation. I can send photos of the tow barif you
> are interested.Perth I
> Cheers
> Roger
> Melbourne.
> --- On Sat, 14/3/09, Yurik Orlowsky yuriko@... wrote:
> From: Yurik Orlowsky yuriko@...
> plan to tow a trailer for my son who is being relocated. A towbarPerth
> or Melbourne I could come directly for pickup.Take a
> Yurik
> look<http://au.rd.yahoo.com/galaxy/mail/tagline2/*http:/au.docs.yahoo.com/ma\
> marterinbox> .
----- Original Message -----From: KenSent: Monday, March 16, 2009 5:27 PMSubject: [Syncro_T3_Australia] Re: Wanted a T3 towbar
Gday Yurik,
I'd be going with something like what Les has designed if I was you,
perhaps with the variation of ascertaining the strength of the
"swan-neck" that holds the toe ball, dependant upon the weight of the
trailer and load you have in mind, as opposed to a light boat Les uses
his for. I reckon fitting the HR for the first time could prove quite
"interesting" . ............ ...... help!!
--- In Syncro_T3_Australia @yahoogroups. com, "Yurik Orlowsky"
<yuriko@...> wrote:
> I have the Hayman Reece on my Takka van also, obviously with theThe problem is that the HR was never designed for a syncro.
> original 14" wheels, the ball height isn't too bad. With 15-16" wheels,
> starts to be problematic.
> Les Harris <leslieharris@optushome.com.au> wrote:The HR is rated at 1000kg.
> Ken,
> Tain't exactly light - it's a 15" Haines Hunter half cab with 70 HP Merc
> and a lot of on-board equipment. It's a heavy hull but very seaworthy.
> It punches its way through some steep swells with ease and stability.
> Haven't weighed it.
> If my memory is still working, the point of minimum strength was well
> over 5 tonnes, not as excessive as it might appear given that shock
> loads have to be taken into account, but it has a very comfortable
> safety margin to a towing mass that equals the Syncro mass. The ball
> would probably shear at less than that.
wheels,
> The genuine towbars are a different height for 2wd and syncro.
> mmmm ..... interesting.
> so if the genuine syncro towbar is lower, would that bar reduce the exit
> clearance underneath, compared with my HR?
> wheels,
clearance underneath, compared with my HR?Ken,See attached pics of Syncro tow hook. As you can see (or not) the bar is completely concealed behind the bumper. However, the tow hook is what might present a clearance concern. The hook is attached with 4 bolts which does not appear to be designed for easy temporary removal.I have a US made receiver hitch which mimics the construction of the hitch above but it has a 2" receiver instead of the hook. It still extends slightly below the bumper line but the tow ball assembly can be slid out by removing a large pin when not in use.Cheers,BenT
Dear Yurik,
Have got round to taking some photos which are attached. Its picked up a bit of rust since I painted it supposedly with rust resistant paint. I looked closely at the Hayman Reece plate on it and it says "suit VW Kombi 1982" "Hayman Reece model 757" It certainly came from a T3 but from memory was probably a 1.9l 2wd van. I thought I had foolishly thought that a T3 towbar was a T3 towbar but I looked on their current site www.haymanreece.com.au and under products for VW they list "1982-9/1992 Kombi Transporter 2WD 4WD " 2 models(neither 757) with respective RRP of $411 and $514 both with the same 1000/80 kg rating/ball weight. In their mind 1 size seems to fit all T3's which is what I assumed.
I would prefer to have a tow bar on my vehicle but perhaps its absence is why its still on the original clutch at nearly 200,000K. I won't do anything more about again trying to fit it to mine until after you come over and won't be fussed whether or not you choose to take it; can get Les's option fabricated; get a more suitable offer; choose to get a new Hayman Reece one fitted from the WA agent before you go or import a European style hook from Europe or BenT Syncro USA.
I live about 3kms from the Melbourne CBD and would do my best to help you fit it if you ended up wanting mine.
Gary -if you are reading this do you mean the blue roundheadlight 1.9l? Caravelle in Fenwick St? I did have a hard look at this on the street but still have the problem that with the bumper off mine and the towbar pushed up towards where it should be, it is still blocked from getting "home" by the exhaust. I see Hayman Reece have one of their agents in Sydney Rd perhaps I will ask them or the VW wrecker I bought it from if they will fit it if Yurik doesn't want it. Cheers
--- On Mon, 16/3/09, Yurik Orlowsky <yuriko@iinet.net.au> wrote:
Regards Yurik
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_ T3_Australia@ yahoogroups. com] On Behalf Of Roger Bell
Dear Yurik,Have got round to taking some photos which are attached. Its picked up a bit of rust since I painted it supposedly with rust resistant paint. I looked closely at the Hayman Reece plate on it and it says "suit VW Kombi 1982" "Hayman Reece model 757" It certainly came from a T3 but from memory was probably a 1.9l 2wd van. I thought I had foolishly thought that a T3 towbar was a T3 towbar but I looked on their current site www.haymanreece. com.au and under products for VW they list "1982-9/1992 Kombi Transporter 2WD 4WD " 2 models(neither 757) with respective RRP of $411 and $514 both with the same 1000/80 kg rating/ball weight. In their mind 1 size seems to fit all T3's which is what I assumed.I would prefer to have a tow bar on my vehicle but perhaps its absence is why its still on the original clutch at nearly 200,000K. I won't do anything more about again trying to fit it to mine until after you come over and won't be fussed whether or not you choose to take it; can get Les's option fabricated; get a more suitable offer; choose to get a new Hayman Reece one fitted from the WA agent before you go or import a European style hook from Europe or BenT Syncro USA.I live about 3kms from the Melbourne CBD and would do my best to help you fit it if you ended up wanting mine.
Gary -if you are reading this do you mean the blue roundheadlight 1.9l? Caravelle in Fenwick St? I did have a hard look at this on the street but still have the problem that with the bumper off mine and the towbar pushed up towards where it should be, it is still blocked from getting "home" by the exhaust. I see Hayman Reece have one of their agents in Sydney Rd perhaps I will ask them or the VW wrecker I bought it from if they will fit it if Yurik doesn't want it.CheersRoger
Received: Monday, 16 March, 2009, 9:03 AMHi Roger,
Yurik
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_T3_Australia@ yahoogroups. com] On Behalf Of Roger Bell
Subject: Re: [Syncro_T3_Australi a] Wanted a T3 towbar
Dear Yurik,
Melbourne.
YurikStay connected to the people that matter most with a smarter inbox. Take a look.
