Last year before my annual mid coast holiday,I replaced my torn front CV boots.The original VW are a rubber boot,the replacement are a plastic type.I replaced both inner and outer boot.I mixed up an oil inhibitor and repacked new grease in the CVs as best as possible.I used new boot clamps and used the proper tool to tighten them.
Mid way through this year whilst on the beach,I heard cluncking from my front CVs.I immediatly chased down the ''last ones",lobro genuine front outer CVs.I havent had a chance to fit them yet.They cost a packet.
Today,I decided to pull the boots back,to pack some more grease into the CV(with the hope it would fix the clunking,works on T2 in the rear),when I did so, dirty muddy water flowed out of the passenger side.
The only water crossings I have done was when Pt Plomer was under water last Christmas.
I guess the point that I am trying to make is that if you cross water,when you get home ,drain oils(which I did),and pull back the CV boots and check them.DO NOT trust that water will not get in there if your boots look all right.
It would be very easy to stuff brand new and very expensive CVs in one trip.This would of happened to me if I had of replaced the CVs before my trip last year.
I will replace my CVs next Monday,I have been told that it is a real fun job,thats why I have been putting it of.
