Concerning the diameter dimension you specify below, I wonder if BFG has
changed the tyre construction to arrive at a smaller diameter or am I
talking about a different model BFG tyre than you?
To be precise, I have 5 new BFG All-Terrain T/A LT 215 75 R15 100/97S
tyres waiting to go on the syncro. Only one so far is on a Merc 15" rim,
hence it's inflatable.
Diameter measurement of an unmounted tyre is 699mm (at middle of tyre
tread). If the measurement was taken at the tread shoulder, it would be
less than that.
Diameter measurement of an inflated tyre @ 40psi is 700mm.
It's not possible for me to misread my measurements to the tune of 9mm,
so it begs the question above.
For this BFG 700mm diameter size tyre, there are positives and
negatives.
It fits (as previously described in my earlier posts on this) underneath
the van uninflated. In fact, I'm now at the next stage of experimenting
and have today successfully fitted it underneath inflated to 40psi. I
intend monitoring this to see how things go over time, but initial tests
suggest a positive outcome.
I no longer need my rear tyre carrier, so that gets rid of some weight,
transfers the weight of the spare wheel to the front where it belongs
and I get easy access via my rear door now .... all good.
Only downside is my existing Goodyear Wrangler AT/R 215 75 R15 offer
more clearance due to their larger diameter, but these won't fit
underneath at the front so I have to carry the spare on the rear tyre
rack.
Taking all plusses and minuses into account, the BFG's offer me the best
configuration. I just have to live with a slightly smaller clearance.
> BFG A/T 215/75X15 is 70.9cms.
> The stock Australia delivered Michelin 205x14C is 481 rev/km.
> BFG A/T 215/75X15 is 464 rev/km
> Is this the information that you want?
> > Erik Hoflinger erikhoeflinger@... wrote:
> > Hi guys,
> > The new gearbox I bought from the uk is an AVU with a ratio of 6.17
so
> > around 10% lower geared than the 6p box and I'd factored this in as
I
> > wanted to put 15" tires on and ultimately bring gearing as similar
to
> > stock as I can again. What type of 15" rims are people here running
on
> > their syncros. Would prefer to buy in oz than from overseas. I know
> > someone from kombi club has 15" TKS shadows on his syncro but not
sure
> > on their load rating/ET. Anybody run larger than 215/75/15. would
give a
> > tyre height of 70cms approx? Anyone gone to the max of 74-75cms?
> > cheers,
> > erik
