Hi Les and others,
I havn't had time to log on to the forum for a while so it was good
to do so tonight and find a healthy discussion going on about the
merits of replacing VC's or fitting decouplers. Les's method of
driving in AWD most of the time and only using the decoupler in
situations that could stress the drivetrain makes sense to me.
It seems that unequal tyre wear could be the greatest threat, even
with a healthy VC. I haven't got round to accurately measuring my
wheels yet, but after checking the tyre pressures, I put a chalk mark
at the bottom of each tyre and drove straight ahead for about 20
metres. I found that the rear left wheel mark was slightly out
compared to the others so this requires further investigation. If
there is a difference between tyre diameters, what can be done about
it, other than buying a whole new set of tyres when they are only
part worn.
I would also like to try the rear wheels jacked up test, should this
be carried out when the VC is cold or after it heats up.
regards
andy buchan
--- In
Syncro_T3_Australia@yahoogroups.com, "Les Harris"
<leslieharris@...> wrote:
> Oh dear, this is getting to be bigger than Ben Hur!
> Yes, you are quite correct. You can run mis-matched tyres in the
circumstances you describe - if you spike a tyre or similar. With a
decoupler, the VC is taken out of the system. I does no more than
idle. If you have to run tyres of different diameters on the front
axle (or the rear axle, if it comes to that), the diff takes care of
the difference and you cannot do any damage.
> When the VC is running - that is, when the prop shaft is driving
the front wheels - it is mandatory to run the same tyre diameters and
the correct pressures
> I don't know if anyone here is running the US style decoupler. The
last time I looked, the US decoupler ran a plain bearing in the
extension housing; the German decoupler runs a needle bearing.
Needle bearings are generally superior to plain bushes.
> From: Michael Roberts
> Sent: Wednesday, April 23, 2008 6:20 PM
> Subject: Re: [Syncro_T3_Australia] Re: what decoupler to get?
> I realise that VW design the Syncro to utilise the VC and all
things working with in spec is the best option. My VC is perhaps on
the aggressive side (still trying to work out what¢s normal) but my
main thought about the decoupler are with tyre rotation. Out bush if
I spike a tyre or something and had to get a replacement this could
mess up my tyre rotation (I normally run a 6 tyre rotation) and from
what I have been hearing, having the tyre diameters all the same with
the same pressure is important. Am I right in assuming that with a
decoupler I could run a mismatch of tyre on the front with out
causing too much damage if i had too?
> So is anyone running the USA style decoupler?
> Michael
> Instant message from any web browser! Try the new Yahoo! Canada
Messenger for the Web BETA
