> Date: Thu, 15 Sep 2011 17:08:49 +1000
> Subject: Re: Re: [Syncro_T3_Australia] Re: Wheel Alignment
> They didn't have special shocks for the USA.
> > greg esposito <gregespo73@yahoo.com> wrote:
> > David Go Westy and generally the American market will describe them as
> > firm because VW America opted for a "soft" shock from new in all
> > vanagons. This is done to almost all cars marketed in the US. When
> > compared to the set we got in Oz they are very similar in ride but you
> > gain compression damping in the front and travel in the rear as well as
> > a better over all shock. I think they are the value for money choice but
> > maybe some other members have options for you. Greg E
> > From: David <davidleibmann@yahoo.com.au>
> > Sent: Thursday, 15 September 2011 2:57 PM
> > Subject: [Syncro_T3_Australia] Re: Wheel Alignment
> > Â
> > Hi Greg,
> > Check out the GoWesty website and they sell OME shocks for Syncros in
> > the States and they describe them as a firm ride. There Aussie made so
> > that is a big plus. Im just chekin out the options.
> > Cheers David
> > --- In Syncro_T3_Australia@yahoogroups.com, greg esposito
> > <gregespo73@...> wrote:
> > > What makes you think OME will be firm? If you want to keep it simple
> > (no mods) and get a good shock in my books thats the OME. While shock
> > absorbers play a part, firm is more about springs. Greg E
> > > From: David <davidleibmann@...>
> > > Sent: Thursday, 15 September 2011 2:41 PM
> > > ÂÂ
> > > Hi Greg,
> > > The bushes appear to be OK. No play or noises there. The van has
> > travelled 197000 km and we hope to have it for a long life. Renewing the
> > suspension is on my list. Its used as a family camper so I think
> > replacing the shocks with Sachs should suffice. OME and others will be
> > too firm. Can you recommend any other shock that will give a comfortable
> > ride?
> > > Thanks David
> > <gregespo73@> wrote:
> > > > David, when a tyre leans in at the top it is negative camber. While
> > a number of issues can cause this, the first thing I would check is your
> > upper arm bushes. The easy way to do this is to squat down facing the
> > wheel (side of car), place both hands on top of the tyre and pull and
> > then push repeatedly. If you feel a noticable clonk or you have heard a
> > lot of creaking in your front suspension you need new bushes. Spending
> > money on aligning a worn suspension system is wasting money. How many
> > kms on your bus? How long are your keeping it? Greg E
> > > > From: David <davidleibmann@>
> > > > Sent: Thursday, 15 September 2011 12:15 PM
> > > > Subject: [Syncro_T3_Australia] Wheel Alignment
> > > > ÂÂÂ
> > > > Hi Guys,
> > > > I`ve had my 91 Syncro for a month. The front tyres were massively
> > worm (Toe in) on the original treads. I replaced all 4 tyres ( Toyo HO8)
> > last week and the tyre dude said the drivers tyre was too far forward
> > and it needed a wheel alignment. Looking at the front tyres this morning
> > it appears I still have toe in and tyre wear inner front. It feels as if
> > the front tyres cave in too much. I rang and booked to get the alignment
> > rechecked tomorrow. Im confused with the different info out there on
> > alignments with Syncros. Can anyone point me in the right direction.
> > > > Cheers David
> <*> To visit your group on the web, go to:
> <*> Your email settings:
> <*> To change settings online go to:
> (Yahoo! ID required)
> <*> To change settings via email:
> <*> To unsubscribe from this group, send an email to:
> <*> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
CC: davidleibmann@yahoo.com.au
Date: Wed, 14 Sep 2011 21:14:28 -0700
Subject: Re: [Syncro_T3_Australia] Wheel Alignment
----- Original Message -----From: Les HarrisCc: 'David'Sent: Wednesday, September 14, 2011 7:55 PMSubject: RE: [Syncro_T3_Australia] Wheel AlignmentOK, found it without interrupting the compression process.
Sent: 15 September 2011 12:36
David,
I will send the correct alignment specs to you direct.
Do NOT take any notice of any alignment place that tells you that the 2WD and 4WD alignment is the same.
You will have to print this out and take it with you. I have yet to hear of any alignment place that has these figures.
They are taken from the VAG workshop manual, page 44.5
I can’t access it at the moment because the computer is compressing the drive that this file is on and I can’t interrupt it.
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of David
Sent: 15 September 2011 12:16
Hi Guys,
I`ve had my 91 Syncro for a month. The front tyres were massively worm (Toe in) on the original treads. I replaced all 4 tyres ( Toyo HO8) last week and the tyre dude said the drivers tyre was too far forward and it needed a wheel alignment. Looking at the front tyres this morning it appears I still have toe in and tyre wear inner front. It feels as if the front tyres cave in too much. I rang and booked to get the alignment rechecked tomorrow. Im confused with the different info out there on alignments with Syncros. Can anyone point me in the right direction.
Cheers David
Sent: Thursday, 15 September 2011 5:08 PM
> greg esposito <gregespo73@yahoo.com> wrote:href="mailto:davidleibmann@yahoo.com.au" ymailto="mailto:davidleibmann@yahoo.com.au">davidleibmann@yahoo.com.au>
> From: David <
> To: Syncro_T3_Australia@yahoogroups.comon aligning a worn suspension system is wasting money. How many
> Â
> Hi Greg,
> Cheers David
> > ÂÂ
> > Hi Greg,
> ride?
> > Thanks David
> money
> kms on your bus? How long are your keeping it? Greg Efront tyres this morning
> > > ÂÂÂ
> > > Hi Guys,
> it appears I still have toe in and tyre wear inner front. It feels as if------------------------------------
> > > Cheers David
Yahoo! Groups Links
> Is this write up under shocks in syncro org wrong?
> http://www.syncro.org/suspension.html#Shocks
> From: "plander@optusnet.com.au" <plander@optusnet.com.au>
> as
> but
> > Hi Greg,
> > Cheers David
> > absorbers play a��������������������part,��������������������firm is more about springs.
> Greg E
> > > Hi Greg,
> comfortable
> > ride?
> > > Thanks David
> While
> your
> a
> > > > Hi Guys,
> HO8)
> morning
> if
> alignment
> > > > Cheers David
> ���� ���� http://docs.yahoo.com/info/terms/
> Scott,Yes I'd love to learn how and carry out for myself an alignment check, if you have a home handymans procedure I could follow. My garage floor is level and flat.
> My syncro still pulls to the left, regardless of road camber or not, even after my VW service people had a go at it, still didn't get it right, I know they lost money trying. To be fair, I think with a new set of tyres may eliminate one cause of pulling to the left, although again, my tyre wear looks pretty even.
> Cheers. TIA.Ken
> CC: davidleibmann@...
> From: ScottDaniel@...
> If anyone can interpret that toe graph ..
> let me know.
> and ..if anyone who has a flat level surface to part their Syncro
> on,
> and wants to check and adjust the front toe, check and adjust front camber
> and check front castor using quite adequate 'shad tree mechanic'
> methods..
> in inches btw, not degrees ...
> let me know, and I'll tell you how.
> You can at least check your front alignment to find out if it's in
> the ballpark..
> and with patience and persistence, even get your front alignment where it
> belongs.
> personally, I think letting any tyre store near my van or sycnro is a very
> risky thing to do.
> Scott
> turbovans.com .com
> From:
> Les Harris
> Cc: 'David'
> PM
> Alignment
> Alignment
> David,
> I will send the
> Do NOT take any
> the same.
> You will have to
> They are taken from
> I can't access it
> on and I can't interrupt it.
> From:
> To:
> Alignment
> Hi
> Guys,
> Cheers
> David
Date: Thu, 15 Sep 2011 09:39:10 +0000
> Cheers. TIA.Ken
> let me know.
> on,
> methods..
> the ballpark..
> belongs.
> risky thing to do.
> Scott
> turbovans.com .com
> From:
> Les Harris
> Cc: 'David'
> PM
> Alignment
> Alignment
> David,
> I will send the
> Do NOT take any
> the same.
> You will have to
> They are taken from
> I can't access it
> From:
> To:
> Alignment
> Hi
> Guys,
> Cheers
> David
Will have the tiles all lined up for you. Suggest will do yours first and than mine.......
Hartmut
Sent: Thursday, 15 September 2011 8:14 PM
Subject: RE: [Syncro_T3_Australia] Re: Wheel Alignment
Eddie,
Nice find .... interesting read.
Put this on my todo list. Thanks.
Hey Ken, google "vanagon diy wheel alignment " and click on to the one in the Samba. There is a step by step guide & it worked a treat for my syncro and my 2wd.Hope this helps , Eddie.
> Cheers. TIA.Ken
> let me know.
> on,
> methods..
> the ballpark..
> belongs.
> risky thing to do.
> Scott
> turbovans.com .com
> From:
> Les Harris
> Cc: 'David'
> PM
> Alignment
> Alignment
> David,
> I will send the
> Do NOT take any
> the same.
> You will have to
> They are taken from
> I can't access it
> From:
> To:
> Alignment
> Hi
> Guys,
> Cheers
> David
Date: Thu, 15 Sep 2011 20:42:20 +1000
Hartmut
Eddie,
> Cheers. TIA.Ken
> let me know.
> on,
> methods..
> the ballpark..
> belongs.
> risky thing to do.
> Scott
> turbovans.com .com
> From:
> Les Harris
> Cc: 'David'
> PM
> Alignment
> Alignment
> David,
> I will send the
> Do NOT take any
> the same.
> You will have to
> They are taken from
> I can't access it
> From:
> To:
> Alignment
> Hi
> Guys,
> Cheers
> David
Agree, coffee first....Hartmut
Sent: Thursday, 15 September 2011 11:07 PM
Hartmut,
Heh I'm not sure now of the priority order of the ToDo list projects for our fleet of syncros.
Like the engine, the clock, the engine timings, wheel alignments, grab handle, compression checks, R&R the shocks, making the coffee. Anything else?
Lets start with the coffee, the rest'll fall into place ....
A few days? Maybe a week tops?
Hartmut
Eddie,
> Cheers. TIA.Ken
> let me know.
> on,
> methods..
> the ballpark..
> belongs.
> risky thing to do.
> Scott
> turbovans.com .com
> From:
> Les Harris
> Cc: 'David'
> PM
> Alignment
> Alignment
> David,
> I will send the
> Do NOT take any
> the same.
> You will have to
> They are taken from
> I can't access it
> From:
> To:
> Alignment
> Hi
> Guys,
> Cheers
> David
