Regards Richard.
Regards Richard.
On 19/05/2011, at 1:26 PM, richardnicholls74 wrote:Hi everyone i am after some recommendations regarding too fitting 15 inch rims to my syncro.....i do have the tyres ready to go these are hankooks Z36 215/15-100 tread pattern similar to the dunlop adventurer, i believe merc steel rims are the go? any model in particular? 280-190??? also what about t4 t5? or merc vito? any suggestions would be muchly appreciated
Regards Richard.
Mercedes are too lightweight.
Mefro steel are good and can be bought from Germany.
Most wheels will need special nuts.
> muchly appreciated
> Regards Richard.
Some T4 wheels will fit, my syncro came with T4 wheels but the offset wasn't great (still got these in the shed if anyone wants them).
Also got a spare set of 5 Merc Steel wheels, offset 31, really like the look of these on the syncro.
I'm now runnnig mefro's.
unfortunately I'm in Perth and I guess your not.
--- In Syncro_T3_Australia@yahoogroups.com, "richardnicholls74" <richardnicholls74@...> wrote:
> Regards Richard.
He has had them on for about 8 years with no issues and has been down a few fairly rough tracks also with no issue.
On 19/05/2011 1:46 PM, plander@optusnet.com.au wrote:T4/5 do not fit.
> muchly appreciated
> Regards Richard.
>Richard.
> I thought Mercedes used conical nuts, guess I'm wrong, maybe there's a difference between alloy and steel.
> --- In Syncro_T3_Australia@yahoogroups.com, "richardnicholls74" <richardnicholls74@> wrote:
> > Regards Richard.
>Dang the mercs sound good for now! save the pennies for a set of mefros for later....yep the only probs i,m in Victoria!!! thanks for the info much appreciated.
>Richard.
> Merc steels will fit but there seem to be two types with different offsets. You want the ones with 31 offset rather than 45 or so. From a C class i believe.
> If you search through the forum under Merc rims I've put the part number up in previous posts.
> You really need to change to tapered wheel nuts to match rather than the conical VW ones.
> Gary
> > Regards Richard.
>Thanks for that gary will follow up.
>Thanks for the info Phil...are mefros expensive to purchase and to import?
> T4/5 do not fit.
> > muchly appreciated
> > Regards Richard.
>Richard
> My dad managed to fit VW T4 steel 15 inch rims to his syncro no problem.
> The only issue was the black plastic caps needed to be hole sawed to
> allow the rear hub nut to protrude through.
> Skot
> On 19/05/2011 1:46 PM, plander@... wrote:
> > T4/5 do not fit.
> > Phill
> > would be
> > > muchly appreciated
> > > Regards Richard.
>Cheers Skot thanks for the info
(Some T4 wheels will fit, my syncro came with T4 wheels)
They must have had the centres machined.
> Thanks for the info Phil...are mefros expensive to purchase and toNo, a few people on the forum have done it.
> import?
The T4 wheels that came on mine are steel and I don't think they were centre bored, but horrible 40 something offset.
> Mercedes use ball taper nuts. They are a 12mm radius and VW use 14mm.
Michael Hutchinson, Townsville, 88 Syncro, Manx buggys all powered by SUBARU!!!!!!!
At least some Mercedes steel wheels, maybe just some, use 14mm, mine certainly do. Agree Merc alloys are predominately 12mm. I've two sets of merc alloys in the shed if someone's intrested.
Hi Richard. A few of us bought sets of mefro 15” wheels from Germany in a group buy. They are fabulous and you can get very nice VW centre caps that fit well. The company also sold us new nuts as well
Check out the message history on the site and you will see the thread for the purchase and photos.
Cheers, Peter from Port (Macquarie)
On 19/05/2011, at 10:19 PM, Peter Coe wrote:Hi Richard. A few of us bought sets of mefro 15” wheels from Germany in a group buy. They are fabulous and you can get very nice VW centre caps that fit well. The company also sold us new nuts as well
