While we're on the topic of cv's, I've been toying with the idea of telling this story since it happened at the beginning of the year.
After 25 yrs of lusting after a Syncro, I finally bought what some forum members would know as "Norbert's Syncro" from Hamish, another member. It ended up having just the specs I wanted with both front & rear diff locks + decoupler. Overkill I was counselled, but the few times I've needed the front diff lock in my 712, 6x6 Pinzgauer, it meant the difference between getting home or not so I was happy! I tidied up a few minor things but despite being concerned by 8 cv's underneath, I thought all was OK, as I couldn't get any warning signs from the usual lock to lock etc tests.
All good so off we went for a 2000km jaunt from FNQ to Brisbane to do the Christmas thing.
On the way home I picked up a friend north of Bunderberg & we headed for Kroombit Tops for a bit of a look. The "Razorback track" to Biloela looked interesting & very suitable to finally try this Syncro out off road, although I hadn't really planned for any serious 4x4 stuff before I'd left home.
Well I was pretty impressed with the way it was handling itself over what was a pretty challenging, if not completely outrageous track. About 10km along a total of 27km we walked nice & easily down a 250-300mm rock step, but it wasn't long after that there was a distinctly ominous noise from the back. We decided that it was definitely from the left rear.
OK, stop & check and sure enough, the left axle is flopping around in the outer cv like the proverabial in a sock.
Oh dear I thought, that's not good......
Best keep going.....
That was ok till we didn't make it up the next decent hill.
After a couple of tries, we realised that only the front wheels were scratching for traction.
Another crawl underneath & sure enough, the other outer was totalled as well.
Oh dear, that's even worse......
Both rear outer cv's totalled in a gulley, 10km along a remote 27km track on a Sunday afternoon, with no hope of going either forward or back despite a few tries, we were in deepish do do!
The first shaft came out before dark & it looked like both cv's were the same.
Amazingly we had mobile reception as we were line of sight with Callide power station in the (far) distance.
A call to PO Hamish confirmed that the cv's were indeed interchangeable.
Well it's a camper so not a totally bad spot to spend the night......
Even got soap & water to help get the moly grease & dust off....
Next morning the other shaft came out & one goodish one made out of the bits & reinstalled.
Tyres let down till good & baggy & away we went.
We decided to keep going the way we were & the track actually got worse, but we managed to drive out with 2 x front & only 1 x rear drive!
I was quite relieved.......
Hamish had been busy & found that the closest chance of replacement CVs was Nth Rocky Mechanicals & indeed they had GKNs on the shelf & put other work on hold to fit them to my axle when I arrived next day.
I can highly recommend them!
The 2 that broke were not GKN by the way. I think there's a lesson to be learnt there?
Sorry this turned into a bit of an epistle, but I hope you got a smile out of it : )
Jim
