Whiteline UCABushes
Hi group. Received my UCAB kit from whiteline the other day. The kit consist of an outer shell , a middle rubber bush and an inner steel bush. The outer shell and middle bush fit together snuggly, but the inner and middle bushes have a bit of play. Difference between internal and external diameters is .5 mm. The guys at Whiteline seem to think that it will tighten up when pressed into the arm , but I'm not so sure. Has anyone had experience with these bushes or anyone with advice. Thanks , Eddie.
I have had experience with this company.
I would buy them from SA which has had many years R & D.
What sort of experience Phil?
They needed to make sway bars for Golfs and I had a Golf 1 and 2 with factory bars. They sort of copied them but designed them to be easier to make. No testing and using some parts from from other cars they were never going to work well. close enough is good enough with them.
