My drivers side window washer is not working. How do I get to it so I can see what is going on? Can I get to it from inside the cabin? Or from through the front top grille?
any hints would be greatly appreciated.
These things are a pig of a job and to properly access you need to remove the dash which is a daunting task.
If you dont have water leaking into the cab when using them, you probably just have a blocked nozzle.
Cleaning the nozzle out with a needle usually does the job.
Have had that problem. The needle usually works like Scott said. I had a bird poop right on the nozzle a couple of weeks ago.
