Windscreen Washer Nozzles
Hi to all Syncronauts. I am going to get a respray of the front of my dollar sink, or should I say Syncro camper. I want it done to a high standard and therefore will be insisting on the window coming out and the washer and wiper bits. Does anyone have any hints that I can use or pass on to my resprayer on getting the washer bits off. It looks like it might be tricky. I don't want any bits left unattended as the Port Macquarie sea air can be devastating on our beautiful machines.
Hart is also curious if there any tips for this job.
Cheers, Peter from Port
Peter,
These are very much standard parts and fittings which all panel shops deal with on a daily basis.   I doubt if it will be a problem to them.
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of anni43elli
Sent: 03 May 2011 15:05
Subject: [Syncro_T3_Australia] Windscreen Washer Nozzles
They will use a small screw driver to lever the washer nozzles as they just clip in.
Why not just throw the jets away and upgrade to these triple jets? -Seem to come with a molding between the washers.
Received: Tuesday, 3 May, 2011, 1:05 PM
> just clip in.
Then they will lose the nozzles and replace them with something from a Honda which will not fit correctly and cause rust in a few years.
