windscreen washer pump
Hello all
I need to replace my windscreen washer pump and wondered if anyone knows of a local source. Also wondering if any one has replaced the rubber filler boot on top of the windscreen washer bottle . I checked 2 US suppliers and Just Kampers and could not see it listed.
Thanks for your help. Greg
This guy is wrecking one.
http://forums.kombiclub.com/showthread.php?42945-T3-Parts-For-Sale
They can usually be fixed as they stop working due to lack of use. Squirt some WD40 or similar into the pump inlet and try blowing in it.
> Greg <greg_navarro95@yahoo.com> wrote:
> Hello all
Phil,
Unless you are a member this link wont work.
Anyway here is Luckyphils listing in breif:
Hi All I have the following Parts from a 1989 T3 Caravelle for sale
Rear washer bottle with motor $10
Anything else you are interested in let me know
All items pick up or plus postage.
Phil 0403 999 089
> Hello all
Thanks Scott and Phil. G
--- In Syncro_T3_Australia@yahoogroups.com, Mr Scott Pitcher <spbconsulting@...> wrote:
> Phil,
> Phil 0403 999 089
> Skot
> > > Greg <greg_navarro95@... <mailto:greg_navarro95%40yahoo.com>>
> > wrote:
> > > Hello all
> > knows
Hi Greg,
The only source I could find for the rubber grommet was Van Cafe. I bought one from them in August this year ...
I agree with Philll. Work on freeing up the old pump first or go to a wreckers for a working used one or else the only new solution seems to be ...
While you're at it, consider the following:
The following 0-Ring is the correct seal for either the flywheel or the Air Flow Meter (fits well into a squarish shape - how many people replace this squashed seal?) ...
This bundle-o-seals should arrive just in time to make a nice Christmas present!
Date: Sun, 2 Dec 2012 12:34:30 +0000
Subject: [Syncro_T3_Australia] windscreen washer pump
Hello all
Thanks Ken, big help. Greg
> Hi Greg,The only source I could find for the rubber grommet was Van Cafe. I bought one from them in August this year ...Goto: http://www.van-cafe.com/home/van_1223689737929/search?keywords=251.955.489&x=0&y=0
> I agree with Philll. Work on freeing up the old pump first or go to a wreckers for a working used one or else the only new solution seems to be ...Goto: http://www.van-cafe.com/home/van_1223689737929/page_65_1069/windshield_washer_motor_-_front.html
> While you're at it, consider the following:Goto: http://www.van-cafe.com/home/van_1223689737929/search?keywords=N.013.829.3&x=47&y=19Goto: http://www.van-cafe.com/home/van_1223689737929/search?keywords=N.901.061.01&x=36&y=20Goto: http://www.van-cafe.com/home/van_1223689737929/search?keywords=N.020.290.1&x=41&y=19Goto: http://www.van-cafe.com/home/van_1223689737929/search?keywords=111.905.261&x=0&y=0
> The following 0-Ring is the correct seal for either the flywheel or the Air Flow Meter (fits well into a squarish shape - how many people replace this squashed seal?) ...Goto: http://www.van-cafe.com/home/van_1223689737929/search?keywords=021.105.279&x=30&y=23
> From: greg_navarro95@...
> Hello all
