WTB: overhead aircon complete
Hi,
If anyone has any leads for a complete aircon system, please let me know.
Picked up some SS water pipes today from  Richard in Banyo. What a great resource this list is.
Hi Mark,
Please could you give me details of SS water pipes? Probably need to change up for reliability as old plastic pipes are brittle and will crack when you least expect it.
Ryan.
Sent on the go with Vodafone
From: "mark@spe.com.au [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com>
Date: 28/4/18 3:05 pm (GMT+10:00)
Subject: [Syncro_T3_Australia] WTB: overhead aircon complete
Hi,
The set I just bought was apparently the last from a group purchase here in OZ. They were made here I believe.
You can get them from just Kampers for about $430 plus shipping. I paid about the same.
Hi Mark, just noticed that JK does free delivery on orders over 250.
On 29 Apr 2018, at 8:56 am, mark@spe.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
test
Reply via web post Reply to sender Reply to group Start a New Topic Messages in this topic (3)
Have you tried the highest rated email app?
With 4.5 stars in iTunes, the Yahoo Mail app is the highest rated email app on the market. What are you waiting for? Now you can access all your inboxes (Gmail, Outlook, AOL and more) in one place. Never delete an email again with 1000GB of free cloud storage.
Hi Mark, sorry for the slow reply, been a hectic week! Your welcome on the pipes. Yes, made here in Brisbane :)
Ryan, if there's enough interest happy to run another batch. Probably need to do ~10 sets to keep costs down. They came in at $460 a set last run.
If I do another batch I was going to look at adding a couple of drain points in the pipes to aid draining the cooling system without having to remove hoses etc. Even if you drain through the bungs in the water jackets (pain to get to on a Suncro!) it leaves a lot of coolant in the system.
I did some mucking around on my 2WD when I flushed the system late last year. The system holds roughly 17-18L. If you drain through the engine water jacket you get 10-11L out (lifting the nose of the bus). If you disconnect the heater return hose and the two long plastic pipes and bend them down to get more out, you remove 14-15L.
The theory would be to put an easily removable bung in the lowest point of the long pipes and one in the pipe between the thermostat and the water pump. This would drain most of the coolant out without needing to touch the water jacket bungs.
I have also found, provided you have a good system any debris in the system will get caught in the header tank, so easily removed and flushed out if you drain the system. I've not found any benefit (removing debris etc) draining through the water jacket on the engine. That's based on the few T3's I've worked on.
Anyway, long winded email, but if there was enough interest happy to look at a batch of 'mark 2' pipes.
As my 2WD still has the plastic pipes, I will look at doing them at some stage also.
If you have Theos details, please pass them on. I know they did have isssues with 2.5 and dropped cylider diameter little to beef up the sleeves.
My mobile 0427127128
