4.86 ratio
Hi all.
What is the better final ratio 4.86 or 5.43. And What are the
advantages of a 4.86 in all aspects road & off road????
The 4.86 gives a higher road speed per thousand RPM, which is good for bitumen road travelling.  The 5.43 gives a lower road speed per thousand RPM, which is better for secondary gravel roads, fire trails and the like.  To the best of my knowledge, all Australian delivery Syncros came with 5.43.  The change-over cost is formidable - around 1200/1300 per ring and pinion set - plus the installation,  and you need two sets.
Sent: Thursday, February 08, 2007 3:47 PM
Subject: [Syncro_T3_Australia] 4.86 ratio
Hi all.
I hear what u are saying. Is it any cheaper if u have a rear gearbox
with the 4.86 already lined up and on its way? I have been told by
LONG ENTERPRISES
VW Transaxle Specialist
http://www.longenterprises.com
in the USA that the 4.86 was and is the stronger of the ratios?? And
also if u had your choice, which would u use??
Is this 4.86 diff ratio a good fit to 15inch rim and tyre or do/can i
go higher to the 16 inch version without modifications???
need two sets.
> From: syncrosity4now
> Hi all.
Here’s a link to gearbox ratio’s : http://busman.be/pagina53aaa.html
The shortest ratio is 4.57 making the car real fast. That one came only on 14 inches.
Quite some petrol 16ers had the 4.86 ratio, giving the car a top speed of 141 km/h, that is, if you’ve got enough power and if the car’s not too heavy.
The longest ratio on a 16inch is 6.16. They only put these in 1600TD’s. Top speed is 116km/h, cruising speed… about 90 km/h. Put these boxes in a 14 inch and they will increase your torque at the wheels dramatically, making your G gear very short which is great for offroading. On the highway this setup will be a nightmare. Your top speed will drop a lot, might be something like 90 km/h in a 14 inch with a cruising speed of 90 km on the highway, don’t know if anyone did something like that. But for offroading it should be fantastic.
I will be putting such a 6. 14 inch 1600TD later this year.
Don’t know what you mean with “strong” though. If it comes to stronger gears Australia is the place to be. As far as I know only albino gears in Australia makes stronger gears for the 3rd and 4th gear that’s where you need it, especially if one puts in a stronger than standard engine. And when doing so one should also put in the SA oiling plates.
Mike Plompen
Van: Syncro_T3_Australia@yahoogroups.com [mailto: Syncro_T3_Australia@yahoogroups.com ] Namens syncrosity4now
Verzonden: donderdag 8 februari 2007 11:13
Aan: Syncro_T3_Australia@yahoogroups.com
Onderwerp: [Syncro_T3_Australia] Re: 4.86 ratio
LONG ENTERPRISES
http://www.longente rprises.com
go higher to the 16 inch version without modifications? ??
--- In Syncro_T3_Australia @yahoogroups. com, "Les Harris"
need two sets.
> Subject: [Syncro_T3_Australi a] 4.86 ratio
> Hi all.
Ok So all in all the 4.86 should be very good in the bush and highway
with 15 inch rubber/rim.
What about an oil cooler, i have had this mentioned to me at various
times??
Not really caring about the top speed 105-120 should be sufficent when
cruising and overtaking, just looking for a decent amount of torque in
the rough stuff.
--- In Syncro_T3_Australia@yahoogroups.com, "Mike" <borzeken@...> wrote:
> Here's a link to gearbox ratio's : http://busman.be/pagina53aaa.html
only on
> 14 inches.
speed of
> 141 km/h, that is, if you've got enough power and if the car's not too
> heavy.
1600TD's. Top
> speed is 116km/h, cruising speed. about 90 km/h. Put these boxes in a 14
making
this
on the
> highway, don't know if anyone did something like that. But for
offroading it
> Don't know what you mean with "strong" though. If it comes to
stronger gears
> Australia makes stronger gears for the 3rd and 4th gear that's where you
And when
> Mike Plompen
> [mailto:Syncro_T3_Australia@yahoogroups.com] Namens syncrosity4now
> LONG ENTERPRISES
> http://www.longente <http://www.longenterprises.com> rprises.com
<mailto:Syncro_T3_Australia%40yahoogroups.com>
> need two sets.
> > To: Syncro_T3_Australia <mailto:Syncro_T3_Australia%40yahoogroups.com>
> @yahoogroups.com
> > Hi all.
Hi,
My advice - please undertake careful research on this subject before you commit to any
changes in the ring and pinion sets, especially if you also intend to run taller tyres and
doubly so if you intend to remain using the original VW engine.
I wouldn't tell any one that set up "X" is wrong but you must make sure you know the end
results that you will achieve are suitable for your intended application - and everyone is
different in this regard.
My belief (and I stress MY) is that a set up that included 4.86 ratio R&P's, tall tyres and the
VW wbxer would struggle along a highway and would not have a very low 'crawler' speed
for off road use. Of course the actual gear ratios will also have an affect on the end result.
However, I have not read much on this for a couple of years so I may have my facts wrong.
Someone else wish to make comment..........
I would suggest that you use the gearbox calculator in the files section of this site and
search on the US Yahoo Syncro site for years worth of R&D on exactly this topic. You are
obviously going to spend considerable time, money and effort on your van and this is the
type of work you want to get right first time.
Andrew (OzSyncro) had some problems when he changed his 4th gear and may have some
useful input. (Are you out the Andrew?)
Good luck and keep asking questions!
Andy
Ceduna.
Thanks for the input but i am semi comitted to going with the 4.86
ratio as i have arranged to have it shipped from Germany and well it
comes with the all important diff locks, so i think i only need to
delve into the front gearbox and make the necessary changes???
Other than this i will be keeping the 15inch rim and tyre combo. So
hopefully it wont make it too much of a handful, in the on road/off
road application.
But i am only learning so i will listen intently and observe all input.
As for "semi comitted" i bought the Syncro off ebay, got it cheap and
well got the gearbox just as cheap even with freight and import and
the gearbox is kaputt according to Rudi, so i had to do it one way or
another just to get mobile and as the gearbox i have just bought has
only 110 thousand K's on it i intend on using it, Hopefully???
Yes it will cost me to have the front ratio replaced, but hopefully
not too much, seem to be having some luck with my Syncro, so far....
Andrew
92 Transporter Syncro
--- In Syncro_T3_Australia@yahoogroups.com, "raredownunder"
<rafear@...> wrote:
> Hi,
you commit to any
low 'crawler' speed
this topic. You are
van and this is the
may have some
> Andy
> Ceduna.
Don’t forget that when you put on your larger tires your top speed will increase (that is, if you look at gps speed off course) IF the engine can pull it.
That depends on what engine you have, how many horses are still alive, what tire profile you are driving, what kind of rubbish you transport on the roof J. and what’s your car’s weight.
And, also, when you put on these larger tires your speed in G will increase a lot as well PLUS the torque will be considerably lower because of the larger tires you will be putting on  !
So you can’t have the best of both worlds : a high top speed and lots of torque down low, unless you get yourself a gearbox with the biggest ratio and then making the 3rd and 4th gear way longer. Therefore you will definitely need a strong engine as you will have huge gaps between 2nd and 3rd and 3rd and 4th gear. On the other hand, putting in a very powerfull engine to close these gaps will make your engine suffer a lot. A huge increase in torque will harm your gearbox more when the gears are spread widely then when they follow one another very short, meaning : an alternative engine that gives 220Nm at 4000 rpm will harm more if you change the gearbox allowing the car to make a top speed of 150 km/h then when you alter the gearbox giving it a top speed of 120 km/h. Either way, stronger 3rd and 4th gear would we recommended with a engine setup like that.
One more thing, HP’s is what you need for high top speeds, NM’s torque you need for having power to pull and to perform offroad. When tuning an engine it’s often a choice : either you tune it to get more HP’s out of it, either you tune it to get more torque. Same goes for exhaust tuning like spaghetti exhausts.
But you’re working in the right direction. You will get a bigger difference in performing at a lower cost by changing the ratio’s (tire size also being part of ratio changing) then when trying to do the same with swapping engines or putting on turbo’s, intercoolers, compressors etc.
Oil coolers are cool J They will make your engine last longer.
Mike plompen
www.busman.be
www.wbx6.com
Verzonden: donderdag 8 februari 2007 11:43
times??
the rough stuff.
href="http://busman.be/pagina53aaa.html">http://busman. be/pagina53aaa. html
only on
> 14 inches.
speed of
> heavy.
1600TD's. Top
making
this
on the
offroading it
stronger gears
And when
> Mike Plompen
> Van: Syncro_T3_Australia @yahoogroups. com
> [mailto:Syncro_T3_Australia @yahoogroups. com]
> Aan: Syncro_T3_Australia @yahoogroups. com
> Onderwerp: [Syncro_T3_Australi a] Re: 4.86 ratio
> LONG ENTERPRISES
href="http://www.longenterprises.com">http://www.longente rprises.com> rprises.com
<mailto:Syncro_ T3_Australia% 40yahoogroups. com>
> need two sets.
> > To: Syncro_T3_Australia <mailto:Syncro_ T3_Australia% 40yahoogroups. com>
> @yahoogroups. com
> > Hi all.
Yes i am aware of all this to a certain point, as for modifications to
the enginre the only thig i may do at present is give throw on some
1.25 ratio rockers and a decent high flow cat and muffler system oh
and som 4 prong spark plugs if i can find them(havent looked yet).
So as to the gearbox i am hoping by keeping it relatively stock and
keep it standard except for maybe for a heavy duty 3rd 4th. And at
some stage a decent heavy duty diff set.
So by matching my gearbox ratios and tyres and keeping it relatively
stock i seem to be making some headway and choosing the right path. My
motor is a 2.1ltr so i am fairly confident it will take the load of 15
inch tyres and a 4.86 diff ratio. Not really caring about top speed as
we all know it counts for nothing in the bush, so i am more so going
for a finer balance.
> Don't forget that when you put on your larger tires your top speed will
engine can
> pull it.
alive, what
the roof
> :-). and what's your car's weight.
increase
> So you can't have the best of both worlds : a high top speed and lots of
ratio
2nd and
you change
when you
stronger
> One more thing, HP's is what you need for high top speeds, NM's
torque you
engine
> it's often a choice : either you tune it to get more HP's out of it,
either
spaghetti
> exhausts.
> But you're working in the right direction. You will get a bigger
difference
> in performing at a lower cost by changing the ratio's (tire size
also being
> engines or putting on turbo's, intercoolers, compressors etc.
> Oil coolers are cool :-) They will make your engine last longer.
> Mike plompen
> www.busman.be <http://www.busman.be/>
> www.wbx6.com <http://www.wbx6.com/>
> times??
> the rough stuff.
> <http://busman.be/pagina53aaa.html> be/pagina53aaa.html
> only on
> > 14 inches.
> speed of
> > heavy.
> 1600TD's. Top
in a 14
> making
> this
> on the
> offroading it
> stronger gears
where you
> And when
> > Mike Plompen
> > _____
> @yahoogroups.com
> @yahoogroups.com
> > LONG ENTERPRISES
> > need two sets.
> > @yahoogroups.com
> > > Hi all.
The 2.1 is no ball of fire but that's what most of us use.  There's not a lot of point trying to up the power of it because the cost benefit ratio is miniscule.  The standard 2WD T3 has 4.86 and the Syncro runs quite well on the same ratio.  The wheel size comes into it, but it is the tyre size that determines the revs per kilometre and in turn the distance travelled, not the rim diameter on its own.  You lose a bit of flexibility off road, particularly in the lower gears but it wouldn't bother a competent driver.  The 6+ ratios are strictly full time off road stuff.  On normal roads, they turn the Syncro into a mobile chicane.  The Albins 3/4 gear set is of a higher ratio - higher road speed per 1000 RPM.
If you want to significantly improve the power/torque, you should consider going Subaru, particularly the 2.5.  It costs, but worth it in the end.  Several members of this group have done it.
Remember that you will have to get a 2WD T3 speedo if you change the front diff ratio.
Sent: Thursday, February 08, 2007 10:59 PM
Subject: [Syncro_T3_Australia] Re: 4.86 ratio
Hey i got a standard T3 caravelle box down stairs, 85 model, can i use
the ring and pinion from this box and insert into the front end???
front diff ratio.
> --- In Syncro_T3_Australia@yahoogroups.com, "Mike" <borzeken@> wrote:
> Recent Activity
> a.. 2New Members
> b.. 9New Photos
> Visit Your Group
> SPONSORED LINKS
> a.. Syncro
> b.. Vw syncro
> c.. Braun syncro
> d.. Syncro system
> e.. Volkswagen jetta
> Yahoo! News
> Politics debate?
> Get the latest
> political news now
> Business News
> Hot Headlines
> Get localized news
> for your area.
> Yahoo! Groups
> Start a group
> in 3 easy steps.
> Connect with others.
> front diff ratio.
2WD speedo will not work as it is driven off the front wheel. (1:1 ratio)
I think the diff ratio may not be that important to top speed as I think that the gear ratios may be different. (Not sure, I will have to check that one)
HI Les,
I think you’re wrong about the 2wd speedo.  As I recall, the 2wd van drives its speedo off the LH front wheel, unlike the syncro, which drives of the back of the front diff.  The 2wd speedo ratios are completely unrelated to diff ratios (and I think about 2:1 different to syncro speedos.)  Alternate speedo drive gears are available (not sure how easily) for syncros, to suit various diff ratios, but I would check and see how accurate the speedo is with the particular diff ratio/tyre combination before altering it.
BRIAN REED
FAIRFIELD NATURAL THERAPIES
185 Wingrove St
Fairfield, Vic. 3078
03 9481 5673   0407 319 521
Sent: Friday, 9 February 2007 9:38 AM
Subject: Re: [Syncro_T3_Australia] Re: 4.86 ratio
Subject: [Syncro_T3_Australi a] Re: 4.86 ratio
To Victorian members,
I’ve just booked for the VWCV Kennett River weekend away. (March 2,3,4. Bookings direct with Kennett River Caravan Park  1300 664 417)  Any-one else likely to be there?  If there are a few of us, it might be possible to explore some tracks back up in the Otways (probably Saturday afternoon).  Does any-one have local knowledge of the area that they can pass on.
BRIAN REED
185 Wingrove St
Hi les,
Or when one wants more power but wants to keep it a volkswagen and not a vw-subaru mixture one ha sfour options :
1)Add a turbo and intercooler, a german company does so (Schick), giving the DJ 163 hp and 280Nm torque, a south african company also did it (turbovans I think they were called).
2) Add a compressor (supercharger), e.g. from a new Mini, but then start from an MV engine or, when starting from the DJ bring down the compression ratio in the car first
3) Put in a 3.2 oettinger, it’s basically the same as the DJ but with two extra cylinders. (or the tuned version, the 3.7 oettinger
4) Last possibility, still VW original : put in an audi 2.5 or 2.6 like they did in the T3’s they build till about a year or two ago. They also stopped production of the Syncro in 1992 so that only two syncro’s came originally with this engine. But in the later T3’s it became the standard thus replacing the waterboxer. There’s an OEM bellhousing that makes you bolt the audi engine right onto your gearbox
For those who also see their cars as collectors items, changing it into Subaru is not an option. It’s also not that easy but I agree it’s a great engine. But the other options are often forgotten, don’t know why but according to me they are the way to go
Van: Syncro_T3_Australia@yahoogroups.com [mailto: Syncro_T3_Australia@yahoogroups.com ] Namens Les Harris
Verzonden: donderdag 8 februari 2007 23:38
Onderwerp: Re: [Syncro_T3_Australia] Re: 4.86 ratio
Mike,
I agree with all that but there is one significant difference in Australia.
The Subaru is very common here and has been on the scene for a very long time.  There are many dealers and there are many on the roads, there is a good pool of dealer knowledge (workshop knowledge), and spares are adequately represented, probably far better than Volkswagen.
Volkswagen has had an on and off relationship with Australia over 40 or more years.  They have gone for extreme to extreme.  They have gone from having a big factory at Clayton in Melbourne to having no presence in Australia whatsoever.  During these latter times, they appointed Australian distributors, with varying results.
Whenever a company blows hot and cold, they inevitably erode the confidence base of their customers.  Many have done it and many have paid the price.  It's not confined to the automotive market; it happens in other fields.  Suzuki did it recently with outboard motors and they are now struggling to regain their once good market share.  Subaru have had a constant presence in Australia and have built up a strong reputation as a result.
The matter of keeping to the original spec is up to the individual owner.  I happen to have a good 2.1 MV but would not hesitate to go the Subaru path if it got to be a problem.
Conversely, Audi does not have a big presence in Australia, with the commensurate problems with sourcing spares.  Oettingers do not exist in Australia, so forget about spares.  Adding turbos or superchargers falls into the same field - you would need to be very sure of spares support before going that path.
So, in summary, this is not a question of alternatives being "forgotten" in Australia, it is simply a matter of pragmatics.  If such alternatives do not exist in Australia or have no support or spares in Australia, you would need to be very brave (or very rich) to choose to go that way.
Sent: Friday, February 09, 2007 5:25 PM
Subject: [Syncro_T3_Australia] adding power
Hi les,
2) Add a compressor (supercharger) , e.g. from a new Mini, but then start from an MV engine or, when starting from the DJ bring down the compression ratio in the car first
Van: Syncro_T3_Australia @yahoogroups. com [mailto: Syncro_T3_Australia @yahoogroups. com ] Namens Les Harris
Onderwerp: Re: [Syncro_T3_Australi a] Re: 4.86 ratio
Hey Mike i think u forgot Go Westy, these guys are still making the
wasserboxer style engine with options of 2.3, 2.5, and 2.7(?) not
quite sure on the last and they do a bloody good job, if only it
werent so pricey one may consider it. Oh and they also do the amped up
version of each motor, of course u can still rebuild the stock 2.1 or
other.
I think here in Aus Subaru option is taken because cost of rebuild vs
straight swap out.
If my motor goes Bang and throws a piston through case or other
terminal death.
I dont want to opt for the Subaru option kinda cheating, but then
again it all comes down to the dollars we have to spend here in
Australia so as to get our Wasserboxer engines rebuiilt.
Why rebuild something if you can obtain more power for less and swap
to something that is still in mas production, I hate to say it but it
kinda makes sense.
Still throwing a Japanese Motor in a German Car???????????
> Hi les,
giving the
(turbovans I
compression
> 3) Put in a 3.2 oettinger, it's basically the same as the DJ but
with two
like they
> did in the T3's they build till about a year or two ago. They also
stopped
> production of the Syncro in 1992 so that only two syncro's came
originally
> with this engine. But in the later T3's it became the standard thus
> replacing the waterboxer. There's an OEM bellhousing that makes you
bolt the
> Subaru is not an option. It's also not that easy but I agree it's a
great
> engine. But the other options are often forgotten, don't know why but
> [mailto:Syncro_T3_Australia@yahoogroups.com] Namens Les Harris
not a
ratio is
well on
size that
travelled, not
driver.
roads, they
consider
front
> diff ratio.
> From: syncrosity4now <mailto:syncrosity4now@...>
> To: Syncro_T3_Australia <mailto:Syncro_T3_Australia@yahoogroups.com>
> @yahoogroups.com
<http://geo.yahoo.com/serv?s=97359714/grpId=13267315/grpspId=1709926240/msgI
> d=1366/stime=1170935991/nc1=3848610/nc2=4025325/nc3=3>
Same problem.  Where do you get Go Westy spares in Australia?
If you averse to putting a rice burner into you Syncro, then a Porsche motor is the only alternative.
As I said, if you have unlimited money, then you have unlimited choices.  I don't have unlimited money so a Subaru is the only choice that represents value for money.
Sent: Friday, February 09, 2007 6:48 PM
Subject: [Syncro_T3_Australia] Re: adding power
other.
straight swap out.
terminal death.
kinda makes sense.
Still throwing a Japanese Motor in a German Car????????? ??
Yeh it goes without saying that the dollar shall dictate what happens
with replacement/rebuild...
As to the go westy option, i can tell u they use, i think it is a
Mexican cast block and cylinders. And produce their pistons and cams.
I know of a few T3's getting about with a subi motor, and at least
they are horizontally oppossed, in the same family.
Oh and who wouldnt love a porsche motor, i have thought the 944 option
if things west south and thats as far as i got. havent got any specs
or anything else and as for higher up the Porsche chain obviously
higher up the money.
I have said it before and will say it again, VW stuffed up as soon as
they went from T3-T4 and changed the whole thing. As if u were rivh
enough to burn money, why wouldnt have the T3 pfactory presses
re-established and start to pump them out again. Bloody idiots, for
as soon as they(VW) gave in and followed trends, a great breed was
squished and stamped out.....
Andrew
> other.
> straight swap out.
> terminal death.
> kinda makes sense.
> Recent Activity
> a.. 2New Members
> b.. 9New Photos
> Visit Your Group
> Give Back
> Yahoo! for Good
> Get inspired
> by a good cause.
> Y! Toolbar
> Get it Free!
> easy 1-click access
> to your groups.
> Yahoo! Groups
> Start a group
> in 3 easy steps.
Sorry, yes i forgot the gowesty option. Very sorry about that as I think they make a very nice product which keeps the car still “vw original”. In fact I ordered a gowesty 2.4 to fit in my doka and already paid for it, including shipping from the us to Europe . There was just one little problem and that’s that I wanted guarantee on a setup they had no experience with : a 2.1 DJ to start with instead of an MV (they don’t know the 2.1DJ in the us, they only know the 1.9 as a DJ) and secondly I wanted to run it on LPG (liquefied petrol gas), as I was driving that before in my 2.1DJ. As they had no experience with this setup, very understandably they couldn’t give me any guarantee on the engine, although they thought it would do just fine. But I didn’t want to spend such an amount of money on an engine with no guarantee.
The guys from Gowesty were very understanding and very nice to deal with. They made no problem with paying me back my money.
Then a 3.2 six cylinder with 165HP and 260 Nm came up for sale in germany . This engine was only build for T3’s, developed by VW to a certain degree and then finished by Oettinger who commercialised it. I fell in love with this engine and put in my car ( www.wbx6.com ) . In my heavy 2.5 tonnes doka (when empty) which is lifted and runs on heavy profile tires it burns a lot of petrol, but on the other hand only 1 litre more per 100 km then when I had the 2.1 in it. But I don’t really mind since my orange doka is not a daily driver. Nevertheless I’d like to put it back on LPG later this year, which is very environment friendly and costs one third of the price of petrol here in Belgium .
But, again, there are more options to keep it a real vw (if one wants to). I like to look at what setup was produced by vw or one could order through vw. But don’t get me wrong, I love to read testimonials of all kinds of modifications and engine conversions.
Porsche does sound great too, and so does golf gti conversions (I have a 2wd doka gti for the moment), or a Syncro with a VR6 engine in it, also great J
So, putting a Japanese engine in a german car ? For me : no,  For other people : if it makes you happy you should do it, never mind what others say or think. But I guess most of us don’t care a lot of what the neighbours are thinking, right ?  J Hehehe
Mike plompen
Verzonden: vrijdag 9 februari 2007 8:49
Onderwerp: [Syncro_T3_Australia] Re: adding power
other.
straight swap out.
terminal death.
kinda makes sense.
> Hi les,
giving the
(turbovans I
start
compression
with two
like they
stopped
originally
bolt the
great
Namens Les Harris
not a
ratio is
well on
size that
travelled, not
driver.
roads, they
consider
front
> diff ratio.
> From: syncrosity4now <mailto:syncrosity4 now@...>
href="mailto:Syncro_T3_Australia%40yahoogroups.com">Syncro_T3_Australia @yahoogroups. com>
> @yahoogroups. com
> @yahoogroups. com, "Mike" <borzeken@> wrote:
<http://geo.yahoo. com/serv? s=97359714/ grpId=13267315/ grpspId=17099262 40/msgI
> d=1366/stime= 1170935991/ nc1=3848610/ nc2=4025325/ nc3=3>
