Try here;
http://www.justkampersaustralia.com/shop/water-pipe-feed-return-stainless-steel-j15347.html
Give them a call.
The rubber bits are still available.
> Francesca Coles <fcoles6@gmail.com> wrote:
> Hi there,
> I seem to remember a bit of a thread about preventive maintenance and
> coolant hoses, one of the Achilles heels of our beasts.... Anyway, it
> has
> come to our attention that we need to replace the long hoses which run
> to
> and from the radiator. I know these are NLA, and I am looking into other
> options. I think Roger Bayley and Ken did some impressive research into
> locally available replacement parts a while back. Also, some people seem
> to
> have gone the stainless steel pipe replacement route, via GoWesty or Van
> Cafe. This seems a rather expensive option, including postage, but might
> give one long-term peace of mind. Who would recommend this option from
> personal experience? For the locally available plastic/rubber option,
> can
> anyone tell me which part numbers relate to the bits I need, please?
> Thanks a lot,
> Francesca.
> (Syncro taking a vacation while I hunt parts, but bicycle running well.)
----- Original Message -----From: Francesca ColesSent: Tuesday, May 03, 2011 1:51 PMSubject: [Syncro_T3_Australia] coolant hoseHi there,
I seem to remember a bit of a thread about preventive maintenance and coolant hoses, one of the Achilles heels of our beasts.... Anyway, it has come to our attention that we need to replace the long hoses which run to and from the radiator. I know these are NLA, and I am looking into other options. I think Roger Bayley and Ken did some impressive research into locally available replacement parts a while back. Also, some people seem to have gone the stainless steel pipe replacement route, via GoWesty or Van Cafe. This seems a rather expensive option, including postage, but might give one long-term peace of mind. Who would recommend this option from personal experience? For the locally available plastic/rubber option, can anyone tell me which part numbers relate to the bits I need, please?Thanks a lot,Francesca.(Syncro taking a vacation while I hunt parts, but bicycle running well.)
On 4 May 2011 08:10, Scott Daniel - Turbovans <ScottDaniel@turbovans.com> wrote:
Greetings,As built originally, there are no long hoses from engine to radiator of course.( though some people replace those with long runs of marine coolant hose sometimes ) .the original main pipes are plastic, with metal insert ends.'the' weakness about these is that the metal insert ends slide out of place, causing a leak.Two pipes, makes 4 spots this failure can happen.GW sells a repair kit I believe, haven't ever tried one myself.'the hoses' themselves..actually VW T3 vans have just excellent hoses on them.take the two at the front, going to the radiator, I have never seen one of those get tired, or weak, or fail, in any way, ever, on hundreds and hundreds of vanagons.generally ..in automotive coolant hoses, the ones that fail the easiest are the ones with the most heat in them ..which means, in normal cars, the upper radiator hose ( but not in T3 vans ) So watch for hoses that get the most heat, and are higher up on the engine.or *any* plastic cooling system parts. Those ALL get brittle and break on T3 vans eventually.Syncro's are not bad in that regard though.I have seen a small oil cooler hose split and leak.Rear heater cores are notorious for leaking ( the valve on it should be left at least half 'on' all year, so fresh coolant flows through the rear heater core , if you have one, that helps it last longer ) .the coolant pressure bottle ..those are well known for failing eventually.It's always a good idea to get as 'OE' grade of one of those you can find.And the pressure cap that goes on that bottle..should always have a spare or two of those in the van.there is a small bleed hose coming off the right side of the block, to the right of the dipstick some ...early ones may be plastic , the part screwed to the engine block with a small hose nipple in it - those break.Later ones are metal and are not a problem.I have seen upon a few occasions.....the hose in the pipe that goes below the crankshaft pulley ...seen a few of those split . Not fun to deal with either.I've also seen desperate corrosion on the aluminum thermostat housing ..hopefully you don't have anything like that going on.Not to mention badly pitted cylinder heads from not changing coolant.Aluminum can deteriorate very 'nicely' if the coolant/a-frz isn't kept in good condition.and the sheer number of 'cooling system parts' in a Syncro T3 ..there are so many you could hardly ever count them all. And if you trace the route of the heater hoses back there, under the van ..you wonder what on earth they were not thinking when they built that.I'd say there are perhaps 15 chronic weak spots , and the rest is all pretty good.And two section stainless main coolant pipes ..generally, those are better for sure.what fun these vehicles are.Scott----- Original Message -----From: Francesca ColesSent: Tuesday, May 03, 2011 1:51 PMSubject: [Syncro_T3_Australia] coolant hoseHi there,
----- Original Message -----From: plander@optusnet.com.auSent: Wednesday, May 04, 2011 7:55 AMSubject: Re: [Syncro_T3_Australia] coolant hoseA replacement for the plastic pipes may be available locally with free delivery.
Try here;
Give them a call.
> Hi there,
> has
> to
> to
> can
> Thanks a lot,
> Francesca.
Date: Wed, 4 May 2011 09:42:37 +1000
Greetings,As built originally, there are no long hoses from engine to radiator of course.( though some people replace those with long runs of marine coolant hose sometimes ) .the original main pipes are plastic, with metal insert ends.'the' weakness about these is that the metal insert ends slide out of place, causing a leak.Two pipes, makes 4 spots this failure can happen.GW sells a repair kit I believe, haven't ever tried one myself.'the hoses' themselves..actually VW T3 vans have just excellent hoses on them.take the two at the front, going to the radiator, I have never seen one of those get tired, or weak, or fail, in any way, ever, on hundreds and hundreds of vanagons.generally ..in automotive coolant hoses, the ones that fail the easiest are the ones with the most heat in them ..which means, in normal cars, the upper radiator hose ( but not in T3 vans ) So watch for hoses that get the most heat, and are higher up on the engine.or *any* plastic cooling system parts. Those ALL get brittle and break on T3 vans eventually.Syncro's are not bad in that regard though.I have seen a small oil cooler hose split and leak.Rear heater cores are notorious for leaking ( the valve on it should be left at least half 'on' all year, so fresh coolant flows through the rear heater core , if you have one, that helps it last longer ) .the coolant pressure bottle ..those are well known for failing eventually.It's always a good idea to get as 'OE' grade of one of those you can find.And the pressure cap that goes on that bottle..should always have a spare or two of those in the van.there is a small bleed hose coming off the right side of the block, to the right of the dipstick some ...early ones may be plastic , the part screwed to the engine block with a small hose nipple in it - those break.Later ones are metal and are not a problem.I have seen upon a few occasions.....the hose in the pipe that goes below the crankshaft pulley ...seen a few of those split . Not fun to deal with either.I've also seen desperate corrosion on the aluminum thermostat housing ..hopefully you don't have anything like that going on.Not to mention badly pitted cylinder heads from not changing coolant.Aluminum can deteriorate very 'nicely' if the coolant/a-frz isn't kept in good condition.and the sheer number of 'cooling system parts' in a Syncro T3 ..there are so many you could hardly ever count them all. And if you trace the route of the heater hoses back there, under the van ..you wonder what on earth they were not thinking when they built that.I'd say there are perhaps 15 chronic weak spots , and the rest is all pretty good.And two section stainless main coolant pipes ..generally, those are better for sure.what fun these vehicles are.Scott----- Original Message -----From: Francesca ColesSent: Tuesday, May 03, 2011 1:51 PMSubject: [Syncro_T3_Australia] coolant hoseHi there,I seem to remember a bit of a thread about preventive maintenance and coolant hoses, one of the Achilles heels of our beasts.... Anyway, it has come to our attention that we need to replace the long hoses which run to and from the radiator. I know these are NLA, and I am looking into other options. I think Roger Bayley and Ken did some impressive research into locally available replacement parts a while back. Also, some people seem to have gone the stainless steel pipe replacement route, via GoWesty or Van Cafe. This seems a rather expensive option, including postage, but might give one long-term peace of mind. Who would recommend this option from personal experience? For the locally available plastic/rubber option, can anyone tell me which part numbers relate to the bits I need, please?Thanks a lot,Francesca.(Syncro taking a vacation while I hunt parts, but bicycle running well.)
The Tristar i fixed with a go Westy Kit, it worked well. Next was the Telecom bus, here also all 4 ends needed attention. What i did here , i took the pipes out, cleaned it all up,
warmed the plastic pipes with a heat gun, and drove the metal ends into the plastic pipe. Next i checked where the screw clamp would be located , than drilling 4 holes on the
diameter 3.2 mm dia. and used 4 s/s pop rivets to fix the metal end. I then used Sikaflex to cover the pops on the inside of the pipe . I used 2 screw clamps per end, one of them
right over the rivets and one next to it. It just can't leak and it hasn't.
The Trakka received the identical treatment, it also is dry. After Ken, i'm in the market for disused plastic pipes also......
OK com'on let me know that this approach is unprofessionel , however, it could be done in the middle of nowhere and we are not short of those in Oz.............. Hart
Date: Wed, 4 May 2011 12:19:50 +1000
Subject: RE: [Syncro_T3_Australia] coolant hose
Thanks, Hart. Just wish Hart's garage was a wee bit closer!
On 4 May 2011 14:59, Hartmut Kiehn <hartis@live.com.au> wrote:
Hi Francesca, Ken, All,
Francesca,Is it leaking at just one or is it more than one leaking plastic pipe end joint? I discovered just one plastic pipe end joint (of the four) starting to leak in early 2008, so I bought the GoWesty kit and repaired just that one leaking joint, plus added to it an extra (screw up) joint clip for good measure. It hasn't leaked since, nor have the other joints started leaking. I've kept the remaining unused components of the GoWesty kit for future use.Repair kit: http://www.gowesty.com/ec_view_details.php?id=3643&category_id=&category_parent_id=Description of problem: http://www.gowesty.com/library_article.php?id=113There has been in the past some discussion here and elsewhere as to the prudence of adding more metals (dissimilar) to the coolant system. I have no comment either way on that other than to say if this matter has any validity, then it makes sense to me as to why the pipes were (changed back to) plastic. I seem to recall the very early T3's had metal pipes.If you go the replacement S/S route, please don't junk the two plastic pipes. If they have failed at only one or more pipe ends, then I'd love to obtain such a pair, if only because I'm curious enough to experiment with them on my workbench in a quest to find a home-made practical/economical/convenient repair solution.Cheers.Ken
Thanks Scott and Phill. Lots of info there. Only 15 weak spots, eh?? I think I will give Just Kampers a call.
Regards,Francesca.
Hi Francesca,
Over the years that I had my T3 Syncro, I got by for a long time by just double clamping the hoses where they joined the plastic pipes. If I remember, there was one clamp over the metal insert where it had slipped out a bit and one over the plastic end where the insert was still in. This also stopped the insert slipping any further. I eventually replaced them when they were still available, but only because other coolant stuff had let go, so I thought I'd do the lot. (It was through Lloyd, I think he said they were his last stock then. Would have been about 2004/5).
This may have distracted you from the gas conversion research you were doing earlier, but you may want to speak to Pros Amerena at Enhanced Gasworks/Enhanced Motor Works (phone 9486 8444) here in Fairfield. Quite handy to you, and he used to do my gas tuning on the T3 (Lloyd did everything else, but Pros was better on the gas). He does most of my work on my old Porsches, and I've found him quite good.
Brian Reed.
Sent: Wednesday, 4 May 2011 3:14 PM
Francesca,
Regards,
Francesca.
Greetings,
generally ..
Hi there,
Thanks a lot,
Francesca.
Sent: Wed, 4 May, 2011 3:14:24 PM
Regards,Francesca.
Sent: Wed, 4 May, 2011 3:43:37 PM
Regards,Francesca.
I made them in steel,then painted the outside of them with killrust.I would stay away from S/S,there is some opinions that it will rot you radiator.
BenC
> Francesca, the only thing I find odd about the jk ones is that all other
> suppliers have different types for 2wd and 4wd? Greg E
> From: Francesca Coles <fcoles6@...>
> Â
> On 4 May 2011 14:59, Hartmut Kiehn <hartis@...> wrote:
> Â
> >Â
> >out, cleaned it all up,Â
> >Â
> >drilling 4 holes on theÂ
> >Â
> >end, one of them
> >Â
> >Â
> >Â
> >Â
> >From: unclekenz@...
> >Â
> >Francesca,
> >Repair
> >kit:Â http://www.gowesty.com/ec_view_details.php?id=3643&category_id=&category_parent_id=
> >Description of problem:Â http://www.gowesty.com/library_article.php?id=113
> >Cheers.
> >Ken
> >From: fcoles6@...
> >Â
> >Regards,
> >Francesca.
> >On 4 May 2011 08:10, Scott Daniel - Turbovans <ScottDaniel@...>
> wrote:
> >Â
> >>Greetings,
> >>Â As built originally, there are no long hoses from engine to radiator of course.
> >>sometimes ) .
> >>causing a leak.
> >>vanagons.
> >>generally ..
> >>up on the engine.
> >>vans eventually.
> >>Syncro's are not bad in that regard though.Â
> >>should always have a spare or two of those in the van.Â
> >>hose nipple in it -Â those break.
> >>Not to mention badly pitted cylinder heads from not changing coolant.Â
> >>condition.
> >>good.
> >>Scott
> >>www.turbovans.com
> >>>Â
> >>>Hi there,
> >>>Thanks a lot,
> >>>Francesca.Â
Date: Tue, 3 May 2011 22:43:37 -0700
Regards,Francesca.
Sent: Wed, 4 May, 2011 6:54:15 PM
Subject: [Syncro_T3_Australia] Re: coolant hose
Greg,the reason that the coolant hoses(pipes) have different part numbers is because thet are different 2wd and awd.They have different bends.I have made them in steel for both.(and still have the old plastic hoses,incase I need to make more,so I dont need to pull them out to get the right bends).
BenC
> Â
> Â
> >Â
> >Â
> >Â
> >end, one of them
> >Â
> >Â
> >Â
> >Â
> >From: unclekenz@...
> >Â
> >Francesca,
> >Repair
> >Cheers.
> >Ken
> >From: fcoles6@...
> >Â
> >Regards,
> >Francesca.
> wrote:
> >Â
> >>Greetings,
> >>sometimes ) .
> >>causing a leak.
> >>vanagons.
> >>generally ..
> >>up on the engine.
> >>vans eventually.
> >>condition.
> >>good.
> >>Scott
> >>www.turbovans.com
> >>>Â
> >>>Hi there,
> >>>Thanks a lot,
> >>>Francesca.Â
> Hartmut Kiehn <hartis@live.com.au> wrote:I would have used genuine VW sealant.
> Sorry all I read the jk blurb and thought they only had one set for 2wd and
> 4wd. thanks Ken. Greg E
> From: Ben <bencroft96@...>
> Â
> BenC
> --- In Syncro_T3_Australia@yahoogroups.com, greg esposito <gregespo73@>
> > suppliers have different types for 2wd and 4wd?ÃÂ Greg E
> > From: Francesca Coles <fcoles6@>
> > ÃÂ
> > On 4 May 2011 14:59, Hartmut Kiehn <hartis@> wrote:
> > ÃÂ
> > >ÃÂ
> > >out, cleaned it all up,ÃÂ
> > >ÃÂ
> > >warmed the plastic pipes withÃÂ a heat gun, and drove the metal ends into the
> > >drilling 4 holes on theÃÂ
> > >ÃÂ
> >used
> >per
> > >end, one of them
> > >ÃÂ
> > >ÃÂ
> > >The Trakka received the identical treatment, it also is dry.ÃÂ After Ken,
> >i'mÃÂ in
> > >ÃÂ
> > >ÃÂ
> > >From: unclekenz@
> > >ÃÂ
> > >Francesca,
> > >joint?ÃÂ I discovered just one plastic pipe end joint (of the four) starting to
> >measure.
> >the
> > >Repair
> >>kit:ÃÂ http://www.gowesty.com/ec_view_details.php?id=3643&category_id=&category_parent_id=
> > >Description of problem:ÃÂ http://www.gowesty.com/library_article.php?id=113
> >prudence
> >to
> >If
> >workbench
> >solution.
> > >Cheers.
> > >Ken
> > >From: fcoles6@
> > >ÃÂ
> > >Regards,
> > >Francesca.
> > >On 4 May 2011 08:10, Scott Daniel - Turbovans <ScottDaniel@>
> > wrote:
> > >ÃÂ
> > >>Greetings,
> > >>ÃÂ As built originally, there are no long hoses from engine to radiator of
> >course.
> > >>sometimes ) .
> > >>causing a leak.
> >those
> > >>vanagons.
> > >>generally ..
> >higher
> > >>up on the engine.
> > >>or *any* plastic cooling system parts.ÃÂ Those ALL get brittle and break on
> >T3
> > >>vans eventually.
> > >>Syncro's are not bad in that regard though.ÃÂ
> >at
> > >>should always have a spare or two of those in the van.ÃÂ
> >right
> > >>hose nipple in it -ÃÂ those break.
> > >>Not to mention badly pitted cylinder heads from not changing coolant.ÃÂ
> >good
> > >>condition.
> > >>many you could hardly ever count them all.ÃÂ And if you trace the route of
> >the
> > >>good.
> > >>Scott
> > >>www.turbovans.com
> > >>>ÃÂ
> > >>>Hi there,
> >coolant
> >our
> >a
> >peace
> >numbers
> > >>>Thanks a lot,
> > >>>Francesca.ÃÂ
On 4 May 2011 20:06, Ben <bencroft96@yahoo.com> wrote:
I would also cut them in half and join with rubber hose for easy install.
> Sorry all I read the jk blurb and thought they only had one set for 2wd and> 4wd. thanks Ken. Greg E> From: Ben <bencroft96@...>
> ________________________________> Â
>> Greg,the reason that the coolant hoses(pipes) have different part numbers is> > suppliers have different types for 2wd and 4wd? Greg E
> BenC
> wrote:
> > Francesca, the only thing I find odd about the jk ones is that all other> > ÂÂ
> >> >> > ÂÂ
> > >ÂÂ> > >out, cleaned it all up,ÂÂ
> > >ÂÂ
> > >warmed the plastic pipes with a heat gun, and drove the metal ends into the> > >plastic pipe. Next i checked where the screw clamp would be located , than> > >drilling 4 holes on theÂÂ
> > >ÂÂ> > >ÂÂ
> >used
> >per
> > >end, one of them
> > >> > >ÂÂ
> >i'm in> >> > >ÂÂ
> > >the market for disused plastic pipes also......> > >ÂÂ
> > >> > >ÂÂ
> > >From: unclekenz@
> > >> > >Francesca,> > >joint? I discovered just one plastic pipe end joint (of the four) starting to
> > >Is it leaking at just one or is it more than one leaking plastic pipe end> >> >>kit: http://www.gowesty.com/ec_view_details.php?id=3643&category_id=&category_parent_id=
> >measure.
> >the
> > >Repair
> > >Description of problem: http://www.gowesty.com/library_article.php?id=113> > >ÂÂ
> >prudence
> >to
> >If
> >workbench
> >solution.
> > >Cheers.
> > >Ken
> > >From: fcoles6@
> > >> > >Thanks Scott and Phill. Lots of info there. Only 15 weak spots, eh?? I think I> > >ÂÂ
> > >Regards,
> > >Francesca.
> > wrote:
> > >>Greetings,
> > >> As built originally, there are no long hoses from engine to radiator of> >course.> > >>or *any* plastic cooling system parts. Those ALL get brittle and break on
> > >>sometimes ) .
> > >>causing a leak.
> >those
> > >>vanagons.
> > >>generally ..
> >higher
> > >>up on the engine.
> >T3
> > >>vans eventually.
> > >>Syncro's are not bad in that regard though.ÂÂ> > >>should always have a spare or two of those in the van.ÂÂ
> >at
> > >>And the pressure cap that goes on that bottle..> > >>> > >>hose nipple in it - those break.
> >right
> >> > >>Not to mention badly pitted cylinder heads from not changing coolant.ÂÂ
> > >>hopefully you don't have anything like that going on.> > >>Aluminum can deteriorate very 'nicely' if the coolant/a-frz isn't kept in> > >>many you could hardly ever count them all. And if you trace the route of
> >good
> > >>condition.
>> >the> > >>>ÂÂ
> > >>good.
> > >>Scott
> > >>www.turbovans.com
> > >>>> > >>>Hi there,> > >>>Francesca.ÂÂ
> >coolant
> >our
> >a
> >peace
> >numbers
> > >>>Thanks a lot,
Date: Wed, 4 May 2011 20:06:00 +1000
Subject: Re: RE: [Syncro_T3_Australia] coolant hose
I'd like to make a riverside appointment please for (amongst other things haha) your coolant pipes TLC remedy procedure. I happily concede you've beaten me to the punch for a workable solution!
By way of bartering, I'd be happy to mow the lawn on the JD and lower the 3 seater lounge from the mezzanine floor!
Sent: Wednesday, 4 May 2011 2:59 PM
