----- Original Message -----From: KenSent: Saturday, November 22, 2008 11:44 AMSubject: [Syncro_T3_Australia] Re: EUREKA! Trakka WiringLes, yes I did ... Tom Goddard. As I said, he "may". Trouble is he
isn't computer literate but his wife is, so may be a long shot. I'll
contact him privately anyway..![]()
On Fri, Nov 21, 2008 at 4:53 PM, Les Harris <leslieharris@optushome.com.au> wrote:
Ken,Hartmut wasn't computer literate either until Elke drew the line and made him get into it!Hope he joins, because we probably have only one other double cab, Mark Boys with the Australian Safari 16".Was this 14" or 16"?LesLes,There's so far only two Syncro 16's in Australia that I have been able to track. Yurick has one of them. If I had mySyncro 16 Registry here I might be able to tell you who the other one belongs to. I believe the other fellow is on thisforum as well. I'm thinking Mark(?) something. My mind is a bit foggy about details right now but a third one wascoming to Perth last year.It seems the likelihood of of a 4th 16 coming to OZ is not very high especially a Doublecab. Less than half of the 30016" Doublecabs are supposedly still on the road. Even the Germans are trying to keep thier hands on most that cometo market.Cheers,BenT
----- Original Message -----From: BenT SyncroSent: Saturday, November 22, 2008 2:57 PMSubject: Re: [Syncro_T3_Australia] Double Cab Syncro
On Fri, Nov 21, 2008 at 4:53 PM, Les Harris <leslieharris@ optushome. com.au> wrote:
> Now that I have had time to think, I have remembered that Hartmut KeihnHartmut has a TriStar 14"
> has a red double cab Syncro; that has previously been on the home page.
----- Original Message -----From: plander@optusnet.com.auSent: Saturday, November 22, 2008 3:30 PMSubject: Re: Re: [Syncro_T3_Australia] Double Cab Syncro
On Fri, Nov 21, 2008 at 8:36 PM, Les Harris <leslieharris@optushome.com.au> wrote:
Yes, I should have made that clear when I answered Ben. Sorry, Ben. One 16" and one 14" on the list.Ken found one in his local area (not a list member) in the last day or so and undoubtedly another 14"LesLes,To answer your question from the previous email, there were no Syncro 16's made in RHD. I'll double check with VWfan archivist Christophe in Germany and vendor/Syncro fan Mike Plompen in Belgium. Pretty sure it's zero though. I can'trecall about Yurik and Mark Boy's 16's. I'm using someone else's laptop right now so none of my own files to refresh myrecollection (I learned that line from watching the OJ Simpson trials.) =)There is another 16 in Perth (besides Yurik's) which was being converted to RHD last time I spoke with the owner. I didmention this group to him if you will recall. Not sure if he ever got onboard. I'll keep checking.IIRC the Tristars are a rare animal in thier own regard. If it's an original Tristar Syncro RHD, it is one of a very small handful.I don't think you can even count the numbers in existence in one hand.BenT
> To answer your question from the previous email, there were no SyncroThe two Australia Safari syncros were factory 16" RHD.
> 16's made in RHD.
From Simon Holloway;
Syncro 16� (Option M855) 2138 Produced
Of the above vehicles, some were heavy duty special�s fitted with 16� Wheels. These were not generally available as export models but used by the service section within Germany. No 16� Wheeled vehicles were exported to the UK or US. Many different options were available on these vehicles. Most had different gear ratio�s, even heavier duty suspension & uprated brakes
Only a handful (if that!) of Tristars were sold in the UK. Where are they all now?
Only one TriStar came to Australia.
>> 16's made inRHD.
>factory 16" RHD.
>16" (Option M855) 2138 Produced
> Syncro
> Of the above vehicles, some were heavyduty special's fitted with 16" Wheels. These were not generally available as export models but used by the service section within Germany. No 16" Wheeled vehicles were exported to the UK or US. Many different options were available on these vehicles. Most had different gear ratio's, even heavier duty suspension & uprated brakes
> Only one
> So is that Hartmut's TriStar? Would have to be from what Holloway says.Yes
>No, just off the shelf ordered by TKM then taken to VW Motorsport for a bit of upgrading.
> I presume that is excepting the two Australian Safari vehicles.
> If I have it correct, they were purpose built for the Safari by VAG.
----- Original Message -----From: plander@optusnet.com.auSent: Saturday, November 22, 2008 5:52 PMSubject: Re: Re: Re: Re: [Syncro_T3_Australia] Double Cab Syncro
Yes
> Les Harris <leslieharris@optushome.com.au> wrote:8 Bilstein shock absorbers per car.
> Phill,
> Ah, more history. Do you have any details of the upgrading?
Extra body protection
Seikl springs
Extra fuel tanks.
Engines were standard MV
Some info which I received in 2006 from Peter Seikel himself by email. He remembers both
vehicles well his words were 'the front spring and shock system we used very short, no
idea about spring rate' 'this car built at Steyr and my chief mechanic flow over to weld the
brackets in the chassis before painting I remember well. We used double shocks at rear,
one original (still fitted in) and one Bilstein additional. on my own double cab we built for
African rallies we had double shocks in front to at my car I'm pretty sure we used spring
rate 180kg/cm front and 140kg/cm rear.
He did say all documentation is gone.
Rear tyre carrier I think was done in Sydney.
And yes it is a original RHD 16'' dual cab code 248GCA
Bus man did send me some pics a while back of a 16'' dual cab RHD that was located in
germany I think so by what he has researched and had as stock he would know the details
there. There is bound to be more though?
> Phill,
> From: plander@...
> Yes
upgrading.
Sent: Saturday, November 22, 2008 6:41 PM
> Phill,
Seikl springs
Extra fuel tanks.
> 16's made in RHD.
Syncro 16" (Option M855) 2138 Produced
Of the above vehicles, some were heavy duty special's fitted with 16" Wheels. These were not generally available as export models but used by the service section within Germany. No 16" Wheeled vehicles were exported to the UK or US. Many different options were available on these vehicles. Most had different gear ratio's, even heavier duty suspension & uprated brakes
PhillWell, those two were technically not production vehicles. If we are going to be nitpicking, the 16" package is technically just an option package. There were no special badging or paintjobs. They just showed up on your M-code options. Which makes me wonder how accurate some of these production figures really. I'm seen some very convincing conversions done-up with real Syncro 16 parts. In fact at least one vendor here in the Republik of Kalifornya has taken to modifying Syncro 14 rear swingarms to the exact specification as the real 16 arms.Want to know what happened to one of those rare RHD Tristar Syncros? There is fellow in San Francisco who imported one here and converted everything over to LHD. I heard he wasn't too happy that I said he may have ruined the collector value of the vehicle. I am equally guilty of a similar crime in my 16" Doublecab for changing things that weren't even broken for the sake of upgrading. Dimishing returns indeed. Maybe that fella had the right idea. He made the Tristar into a vehicle he was happy with. Likewise I am doing that to my Syncro. In the end, you only really need to please yourself.Cheers,BenT
These were not generally available as export models but used by the service section within Germany. No 16" Wheeled vehicles were exported to the UK or US.Again a technicality. Not "officially" imported by VW. Individuals imported them just as the mystery Syncro 16 in Perth.It may be noteworthy that the later South African Syncros had the bigger CV's like the 16's.BenT
(the only syncro to be converted!) its got an audi 2.5 5cyl diesel
lump, (it might be 2.2??) its a "proper" south african conversion,
complete with 240v sump heater (useful in aus? NOT!) cant wait to
get it on the dunes here! ..."
made in RHD. I'll double check with VWfan archivist Christophe in Germany and vendor/Syncro fan Mike Plompen in Belgium. Pretty sure it's zero though. I can'tare losing pounds.
On Sat, Nov 22, 2008 at 4:35 PM, Mark Kofahl <markkofahl@gmail.com> wrote:
Hi Ben,I seem to recall Christoophe Boltze had a website with many of the Brochures / Prospekte scanned, including some Australian material...Do you have the URL for this if it is still up and running?RegardsMark.made in RHD. I'll double check with VWfan archivist Christophe in Germany and vendor/Syncro fan Mike Plompen in Belgium. Pretty sure it's zero though. I can'tare losing pounds.
> BenTI have just checked through my documentation and yes the 16" was not
classed as a seperate model, althought they had a different body to the
14". Yet the TriStar is classed as a seperate model and the body is no
different to any other dual cab. Same thing with the Caravelle CL & GL.
The syncro 16" club in Munich have most of their production figures
from Graz not Hanover, so they would be more accurate.
On Mon, Nov 24, 2008 at 2:11 PM, Phill <plander@optusnet.com.au> wrote:
>> BenT
PhillPhill,To confuse some folks even more, some Syncro 16's and 14's came with 4 doors like the Tristars.BenT
