I've just come across the Great Central Road and down the Centre to
Adelaide. About 1000km back I noticed the rear passenger side CV
tinkling and then bit of road noise at 80kmh. This has progressed to a
badly vibrating gear lever - sometimes worse than others - and some
definately unfriendly noise when accerlerating. Especially through the
lower gears - not so bad when up and running at 80kmh.
I've rotated the spare around to make sure it's not a crook tyre and
each time I've changed it the situation seems to improve for a while.
I'm running Kumhos and perhaps they could be the problem after the
corrugations and heat, but it seems more drastic than that.
Anyone around Adelaide can give me an opinion - or else recommend a
good Syncro mechanic here?
Michael.
Thank you heaps for the replies and advice - truly appreciated. I'll
remove the CVs and axle and go for a test run first then, and try the
Tailshaft removal second. I'll start a new Post on the Great Central
Road and give a rundown.
Thanks for the advice Andy. I checked and sure enough, with a lever on
the Uni, it shows up plainly. I'll replace that and then see what
gives.
I rang Hardi-Spicer in Adelaide and they have only one listing for
Volkswagen Unis - with a cup diameter of 27mm and overall dimension
with cups on of 69.8mm. That seems the right figures.
They quoted $190.00 each, with 2 available in Australia - one in
Brisbane and one in Melbourne. I've grabbed the one in Melbourne so
you might be able to grab the Brisbane one. The Part No. was K5-A767.
Michael.
