Hi Andy,
Your trouble shooting technique is sound and auto electricians would employ a similar approach. There may be a circuit that is not fused which could have a fault causing discharge. See if there are any other wires attached to the +ve battery terminal and remove them one by one and observe your test light. There are 2 other circuits that have no fuses; 1st the alternator cables – test by removing these (there could be a short in the regulator diodes) and the 2nd the starter motor cables including the solenoid. It’s a systematic process of elimination as you are doing.
Yurik
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Andrew Johns
and Ruth Phillips
Sent: Tuesday, 9 February 2010 8:29 PM
To: Syncro_T3_Australia@yahoogroups.com; subaruvanagon@yahoogroups.com;
Syncro@yahoogroups.com
Subject: [Syncro_T3_Australia] Electrical Shorting Problem - Help
Needed. PLEASE!
Hi folks,
firstly, to those list members who receive this message more than once, my apologies for the cross posting. I have a frustrating problem with our bus and am in need of help............
The Problem and Attempts to Track the Fault:
About 11 or 12 months ago, our bus started to have a flat battery every 10 to 12 or so days. The battery gets progressively flatter over this time ie. it does not suddenly lose charge. After months of charging the battery or changing batteries over every week or so I have now started to try to attempt to resolve the issue.
I believe I have concluded that an electrical short is the problem as when I disconnect the negative terminal on the battery (small spark) and connect a test light between the cable and the terminal, the test light bulb glows.
In order to track the fault, I have removed all the fuses I can find hoping that the test light will go out when a particular fuse is removed thus identifying the circuit with the problem. Fuses I have removed are: all those at the fuse box behind the glove box, the 2 air con. fuses at the rear of the bus and 2 in the engine bay. I think(?) one of these is fuse S51 and the other is a fuse from the Subaru harness. I have found one fuse related to the LPG system and removed that too.
The test light does not go at at any time one of these fuses is removed.
Unfortunately, I live many hundreds of kilometres from an auto electrician
The Bus:
Is a British spec (ie right hand drive) 1990 Syncro Caravelle GL. To compound the difficulty in tracking down the fault, it has a 2003 EJ25 Subaru power plant running on petrol and injected LPG (ie lots of non factory wiring). It was running without fault for over 3 years with this engine before the fault raised it's head. It has factory fitted air conditioning, central locking, power steering and power mirrors.
My Conclusions So Far:
None really! I imagine the fault is more likely to be related to the wiring associated with the engine conversion though even that is a guess and no more.
My Questions:
Can someone please direct me to the location of the fuse on the central locking system (S52, page 97-227 or the Bently manual) so I can test this circuit?
Also, on that schematic, what does the number 23 mean that is next to the S52 symbol?
Is fuse S51 the one that that was located in the wiring junction box in the LHS of engine compartment with the original engine set up?
Are there any other fuses located in odd spots around the van that I can remove to check a circuit?
If I can not find the fault by removing fuses, how on earth do I go about tracking the fault?
And lastly, if I can not resolve the issue, how would an auto electrician go about doing so?
Many thanks,
Andy,
Ceduna
South Australia
Your approach to finding the fault is correct.
Have a look around your stereo/amp etc. Try disconnecting it at the plug.
> Andrew Johns and Ruth Phillips <rafear@internode.on.net> wrote:Hi folks,
The Bus:
My Questions:
circuit?
fault?
Many thanks,
Andy,
Ceduna
South Australia
I would suggest that this may not be a short, but excessive current draw on the battery(ie ignition off). Start by checking all circuits that do not require the key to be turned on. Also pay particular attention to non genuine accessories that have been added, especially directly to the battery. You need to disconnect the positive terminal and put an amp meter between the battery and lead (don't turn on the ignition or any other high current draws ie high beam, this will blow the amp meter fuse). This will show you how much current draw you have and as you disconnect things you can see which is the offender. Greg
P.S. Car alarms and gps are notorious for causing such problems.
--- On Tue, 9/2/10, Andrew Johns and Ruth Phillips <rafear@internode.on.net> wrote:
Send instant messages to your online friends http://au.messenger.yahoo.com
Thanks for the prod. I've long suspected I have a short in my Trakka van due to similar perceived battery drain over a number of years now, but masked by my having a smart charger always connected, so I've been procrastinating.
So inspired by you, I've just done your testlight procedure and came up with the test light coming on at the disconnected negative cable and negative battery pole of the starting AND camping batteries. Is that your case as well .. both batteries affected?
Looks then like we're the founding members of the SESSIG (Syncro Electrical Short Special Interest Group). Can't say I'm looking forward to sussing this one out ...
To: Syncro_T3_Australia@yahoogroups.com; subaruvanagon@yahoogroups.com; Syncro@yahoogroups.com
Date: Tue, 9 Feb 2010 22:58:48 +1030
Subject: [Syncro_T3_Australia] Electrical Shorting Problem - Help Needed. PLEASE!
Find out now Link all your email accounts and social updates with Hotmail.
Andy/Ken,
Make me a member of ESSIG too , I have this phenomena too , it must be T3 specific !! It normally takes about 3 weeks of non use to flatten the battery sufficiently to make the starting procedure a non event.
In my case, I don’t bother because it draws only milli amps and I have connected a tiny solar charger which I plug into the plug outlet in the dash (mine has always power, even with ignition off) and this does the trick for me.
Now , if you draw more current Andy, you times that current with the battery voltage and will get the wattage i.e. draw 0.8 amps x 12 volts = 9.6 watts, (Ohm’s Law)
this could be just enough to slightly warm up a component which you could possibly detect with a laser thermometer. Hartis
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Ken Garratt
Sent: Thursday, 11 February 2010 1:06 AM
Subject: RE: [Syncro_T3_Australia] Electrical Shorting Problem - Help
Needed. PLEASE!
Andy,
PLEASE!
Hi folks,
The Bus:
My Questions:
Many thanks,
Andy,
Ceduna
South Australia
> Hartmut Kiehn <hartis@live.com.au> wrote:
> Andy/Ken,
> T3
> In my case, I don't bother because it draws only milli amps and I
> have
> trick
> for me.
> battery
> 9.6
> watts, (Ohm's Law)
> could
> Needed. PLEASE!
> Andy,
> due
> masked by
> procrastinating.
> with
> Electrical
> this
> one out ...
> From: rafear@internode.on.net
> Needed.
> PLEASE!
> Hi folks,
> my
> bus
> 10
> ie.
> or
> when I
> connect a
> glows.
> hoping
> rear
> and
> related
> electrician
> The Bus:
> wiring
> more.
> My Questions:
> this
> circuit?
> S52 symbol?
> about
> tracking the fault?
> electrician go
> about doing so?
> Many thanks,
> Andy,
> Ceduna
> South Australia
> Hotmail.
> <http://windowslive.ninemsn.com.au/oneinbox?ocid=T162MSN05A0710G>
> Phil the problem appeared gradually over a number of weeks, when nothingMaybe the minor problem was there all of the time and now your battery is getting older.
> else on the van had changed.
>The test light or ammeter should not register at all when everything is turned off.
> What can I determine by using an amp meter rather than a test light.
> I understand that this will indicte the current being drawn but what
> does this tell me?
That’s correct, if you haven’t got a timepiece in your dash that is, so don’t forget to turn that one off before you measure. hartis
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of plander@optusnet.com.au
Sent: Thursday, 11 February 2010 7:31 AM
Subject: Re: [Syncro_T3_Australia] Re: Electrical Shorting Problem -
> does this tell me?
Andy, The ampmeter is going to save you chasing your tail if there is more than one current draw. The test light will be fine if there is one large current draw.If there is two you will pull the fuse of a circuit with a draw on it and the other circuit with draw will keep the test light illuminated. The other issue is the spec for current draw on the t3 is 1-3 mA which is next to nothing (probably just the clock running). If you had 50 mA you may not be able to see this on your test light. Here is a couple of tips which you have probably already thought of. 1-Has the radio been wired to battery and ignition voltage. On Volkswagens people often incorrectly wire the accessory terminal of the radio to battery voltage. 2-Did you say this is a import from GB, if so they often had a time delay interior light circuit located in the drivers courtesy
light that could cause this fault. 3-Does anything stay on i.e. lights, l.e.ds, l.c.ds . 4-In my experience it is usually what is done post production that causes these kinds of faults, disconnect all these additions first. Greg--- On Wed, 10/2/10, Andrew Johns and Ruth Phillips <rafear@internode.on.net> wrote: |
Yahoo!7: Catch-up on your favourite Channel 7 TV shows easily, legally, and for free at PLUS7. Check it out.
> with a draw on it and the other circuit with draw will keep the����test
> light illuminated.����The other issue is the spec for current draw on the
> radio to battery voltage.����2-Did you say this is a import from GB, if so
> drivers courtesy light that could cause this fault. 3-Does anything stay
> From: Andrew Johns and Ruth Phillips <rafear@internode.on.net>
> Subject: [Syncro_T3_Australia] Re: Electrical Shorting Problem - Help
> Needed. PLEASE!
> Received: Wednesday, 10 February, 2010, 10:44 PM
> Thank for your replies.
> I understand that this will����indicte the current being drawn but what
> does this tell me?
> Andy.
> _________________________________________________________________________
> _________
> and for free at PLUS7. www.tv.yahoo.com.au/plus7
Ben,
For vehicles that have very low use and/or have a persistent drain problem, there is a battery maintenance charger on the market made by CTEK. It is an “intelligent” charger that monitors battery state and charges accordingly, then goes to float. The float is also monitored. They also make a 6 volt version, which is good for 6V Beetle owners or anyone who has a (low use) vintage motorcycle. They aren’t cheap but all reports that I read say that they do an excellent job.
I mention this as a solution to your brother’s Ferrari problem, not a solution to Andy’s current loss problem. I must say that I am impressed with the responses that have come through to Andy’s plea for help. The responses have reminded me of several things that I would not have thought of.
On Behalf Of BenT Syncro
Sent: 11 February 2010 09:13
[Syncro] Electrical Shorting Problem - Help Needed. PLEASE!
Compare that to newer vehicles. My brother's Ferrari sucks it's battery completely flat after about 14 days. On-all-the-time GPS locating system makes quick work of destroying the US$755 battery unless you use a tender. As Phill has pointed, there is little if any draw on components on T3's besides possibly the factory radio and clock.
----- Original Message -----From: BenT SyncroSent: Thursday, February 11, 2010 9:13 AMSubject: [Syncro_T3_Australia] Re: [Syncro] Electrical Shorting Problem - Help Needed. PLEASE!
Andy,As Jim Davis (worldwide Syncro forum) pointed out, the fuse for the powerlocks are an add-on module on top of the main fuse block. At least that is how it's installed on the LHD.Yours truly has gained some notoriety in his part of the world for driving his Syncros often enough. Some get driven maybe twice a year. Rarely do the vehicle drain their battery in less than 5-6 months of just sitting. Even then, there is still enough to spin the starter once or twice.Compare that to newer vehicles. My brother's Ferrari sucks it's battery completely flat after about 14 days. On-all-the-time GPS locating system makes quick work of destroying the US$755 battery unless you use a tender. As Phill has pointed, there is little if any draw on components on T3's besides possibly the factory radio and clock.I don't know if this helps as I did not perform the conversion myself. My 2wd T3 with a 2.2 EJT Subaru engine conversion does drain it's battery if not driven or started every 6-8 weeks. It might be coincidental as the previous owner also installed a host of other aftermarket parts. It might be worth throwing the question to the Subaru conversion in Yahoogroups if you are unable to track down the parasitic battery drain.--
----- Original Message -----From: Hartmut KiehnSent: Wednesday, February 10, 2010 12:41 PMSubject: RE: [Syncro_T3_Australia] Re: Electrical Shorting Problem - Help Needed. PLEASE!
Thats correct, if you havent got a timepiece in your dash that is, so dont forget to turn that one off before you measure. hartis
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_ T3_Australia@ yahoogroups. com] On Behalf Of plander@optusnet. com.au
Subject: Re: [Syncro_T3_Australi a] Re: Electrical Shorting Problem - Help Needed. PLEASE!
> does this tell me?
Les I have a ctek they are great! greg--- On Thu, 11/2/10, Les Harris <leslieharris@optusnet.com.au> wrote: |
Which one – they make a range of 12V. Some of them have a truly astonishing initial recovery time.
On Behalf Of greg esposito
Sent: 11 February 2010 10:08
On Feb 10, 2010, at 2:36 PM, "Les Harris" <leslieharris@optusnet.com.au> wrote:
Ben,
> From: Les Harris <leslieharris@optusnet.com.au>
> Subject: [Syncro_T3_Australia] [Syncro] Electrical Shorting Problem -
> Received: Thursday, 11 February, 2010, 9:36 AM
> Ben,
> CTEK.���� It is an �������intelligent�������� charger that monitors battery state
> and charges accordingly, then goes to float. ����The float is also
> monitored.���� They also make a 6 volt version, which is good for 6V
> Beetle owners or anyone who has a (low use) vintage motorcycle.���� They
> aren��������t cheap but all reports that I read say that they do an excellent
> job.
> I mention this as a solution to your brother��������s Ferrari problem, not a
> solution to Andy��������s current loss problem.���� I must say that I am
> impressed with the responses that have come through to Andy��������s plea for
> help.���� The responses have reminded me of several things that I would
> From: Syncro_T3_Australia @yahoogroups. com [mailto: Syncro_T3_Australia
> @yahoogroups. com ] On Behalf Of BenT Syncro
> Subject: [Syncro_T3_Australi a] Re: [Syncro] Electrical Shorting Problem
> tender. As Phill has pointed, there is little if any draw on����components
> on T3's besides possibly the factory����radio and clock.
> _________
