----- Original Message -----From: bencroft96Sent: Wednesday, July 07, 2010 9:19 AMSubject: [Syncro_T3_Australia] engineersScott,can you give me the details of the engineer that engineered your bus(is he in Wyong?)
> Ben,
> I haven't done it yet as I need to find a few hours to make my fridge cupboard and install it so that he can engineer the syncro as a camper. Better to do it all at once than pay for 2 reports.
> I understand the reports are around $400 ish, then you need a blue slip, a weigh bridge certificate and then the RTA starts charging you to change over details (in your case engine numbers etc). Sounds like a painful but necessary process.
> Engineers details are as follows:
> Mr Kevin Humphrey
> Lakesedge Engineering
> 4 Willow Tree Road,
> Wyong NSW 2259
> Ph: 4353 0866
> Apparently Kevin is a reasonable bloke to deal with as long as you have all your pollution control hooked up and the work is neat - you shouldn't have any problems with him. He actually did the engineering certificate in an engine swap I did in a Mitsubishi L300 van about 20 years ago.
> Best of luck.
> Scott
> From: bencroft96
----- Original Message -----From: bencroft96Sent: Wednesday, July 07, 2010 9:52 AMSubject: [Syncro_T3_Australia] Re: engineersScott,Kevin is the guy who other guys I know who have put Subaru motors in Beetles used and recomend.The problem is he is up your way.Will give him a call,sus it out.
> Ben,
> Mr Kevin Humphrey
> 4 Willow Tree Road,
> Wyong NSW 2259
> Ph: 4353 0866
> Best of luck.
> Scott
> From: bencroft96
> Ben,
> This is Gods Country up here and unlike many places, we don't charge admission. The F3 is toll free (well at the moment anyway). Well worth a visit. Just watch out for that shady bloke called Ken!
> Scott
> From: bencroft96
> --- In Syncro_T3_Australia@yahoogroups.com, "Mr Scott Pitcher" <spbconsulting@> wrote:
> > Ben,
> > Mr Kevin Humphrey
> > 4 Willow Tree Road,
> > Wyong NSW 2259
> > Ph: 4353 0866
> > Best of luck.
> > Cheers,
> > Scott
> > From: bencroft96
----- Original Message -----From: bencroft96Sent: Wednesday, July 07, 2010 10:18 AMSubject: [Syncro_T3_Australia] Re: engineersScott,Kevin is busy,and told me to find someone in Sydney.
> Ben,
> Scott
> From: bencroft96
> > Ben,
> > Mr Kevin Humphrey
> > 4 Willow Tree Road,
> > Wyong NSW 2259
> > Ph: 4353 0866
> > Best of luck.
> > Cheers,
> > Scott
> > From: bencroft96
> > Ben,
> > Cheers,
> > Scott
> > From: bencroft96
> > > Ben,
> > > Mr Kevin Humphrey
> > > 4 Willow Tree Road,
> > > Wyong NSW 2259
> > > Ph: 4353 0866
> > > Best of luck.
> > > Cheers,
> > > Scott
> > > From: bencroft96
----- Original Message -----From: bencroft96Sent: Wednesday, July 07, 2010 10:46 AMSubject: [Syncro_T3_Australia] Re: engineersTalked to a guy in Canterbury(some fully sic cars down there),told me to put the engine in,use a Subaru cat(not an aftermarket one),make an appointment,drive down and see him.No pre-inspection required,as he has engineered a few sent to him from Wolksberg.
> > Ben,
> > Cheers,
> > Scott
> > From: bencroft96
> > > Ben,
> > > Mr Kevin Humphrey
> > > 4 Willow Tree Road,
> > > Wyong NSW 2259
> > > Ph: 4353 0866
> > > Best of luck.
> > > Cheers,
> > > Scott
> > > From: bencroft96
Had an interesting conversation with one,concearning improved braking with my Syncro/Subaru conversion.
He says that replacing the VW brake booster with a bigger one from another manufacturer improves Syncro brakes by far.This interests me.
It is something that is not needed for the engineers certificate but the engineer gave me the contact and idea.
Has anyone else done this or knows about this.This is something that will interest a few of you with VW or other engines.When I learn more,I will pass it on.
> Sounds good Ben.
> Let me know how it all goes.
> Scott
> From: bencroft96
> --- In Syncro_T3_Australia@yahoogroups.com, "bencroft96" <bencroft96@> wrote:
> > > Ben,
> > > Cheers,
> > > Scott
> > > From: bencroft96
> > > > Ben,
> > > > Mr Kevin Humphrey
> > > > 4 Willow Tree Road,
> > > > Wyong NSW 2259
> > > > Ph: 4353 0866
> > > > Best of luck.
> > > > Cheers,
> > > > Scott
> > > > From: bencroft96
Ben, the booster to use is one from BMW been told it’s an easy swap, but I have not done it yet, slakko me. Hart
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of bencroft96
Sent: Wednesday, 7 July 2010 1:23 PM
Subject: [Syncro_T3_Australia] improved braking
Hey Hey,been on the phone to some interesting
people today.
on.
> Sounds good Ben.
> Scott
> From: bencroft96
> > > Ben,
> > > Cheers,
> > > Scott
> > > From: bencroft96
> > > > Ben,
> > > > Mr Kevin Humphrey
> > > > 4 Willow Tree Road,
> > > > Wyong NSW 2259
> > > > Ph: 4353 0866
> > > > Best of luck.
> > > > Cheers,
> > > > Scott
> > > > From: bencroft96
Ben,
There are several brake conversions, most of which will not fit the 14” wheel and it is necessary to go to 15”. Yurik has done this (using mainly Audi parts from memory) and is very pleased with the results.
Sent: 07 July 2010 13:23
improved braking
Hey Hey,been on the phone to some interesting people today.
on.
----- Original Message -----From: Hartmut KiehnSent: Wednesday, July 07, 2010 1:30 PMSubject: RE: [Syncro_T3_Australia] improved braking
Ben, the booster to use is one from BMW been told its an easy swap, but I have not done it yet, slakko me. Hart
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_ T3_Australia@ yahoogroups. com] On Behalf Of bencroft96
Subject: [Syncro_T3_Australi a] improved braking
--- In Syncro_T3_Australia @yahoogroups. com, "Mr Scott Pitcher" <spbconsulting@ ...> wrote:
> Sounds good Ben.
> Scott
> From: bencroft96
> Subject: [Syncro_T3_Australi a] Re: engineers
> Talked to a guy in Canterbury(some fully sic cars down there),told me to put the engine in,use a Subaru cat(not an aftermarket one),make an appointment, drive down and see him.No pre-inspection required,as he has engineered a few sent to him from Wolksberg.
> --- In Syncro_T3_Australia @yahoogroups. com, "bencroft96" <bencroft96@> wrote:
> > --- In Syncro_T3_Australia @yahoogroups. com, "Mr Scott Pitcher" <spbconsulting@> wrote:
> > > Ben,
> > > Cheers,
> > > Scott
> > > From: bencroft96
> > > > Ben,
> > > > Mr Kevin Humphrey
> > > > 4 Willow Tree Road,
> > > > Wyong NSW 2259
> > > > Ph: 4353 0866
> > > > Best of luck.
> > > > Cheers,
> > > > Scott
> > > > From: bencroft96
> > > > Subject: [Syncro_T3_Australi a] engineers
> Ben, the booster to use is one from BMW been told it's an easy swap, but I
> it on.
> <mailto:Syncro_T3_Australia%40yahoogroups.com> , "Mr Scott Pitcher"
> > Sounds good Ben.
> > Cheers,
> > Scott
> > From: bencroft96
> <mailto:Syncro_T3_Australia%40yahoogroups.com> , "bencroft96" <bencroft96@>
> > > > Ben,
> > > > Cheers,
> > > > Scott
> > > > From: bencroft96
> > > > > Ben,
> > > > > Mr Kevin Humphrey
> > > > > 4 Willow Tree Road,
> > > > > Wyong NSW 2259
> > > > > Ph: 4353 0866
> ago.
> > > > > Best of luck.
> > > > > Cheers,
> > > > > Scott
> > > > > From: bencroft96
> Ben,
> There are several brake conversions, most of which will not fit the 14"
> wheel and it is necessary to go to 15". Yurik has done this (using mainly
> it on.
Hi Les, I have used a Bernd Jaeger Audi assembly and gone to 16” rims, but 15” would do also. Braking has not improved though, in fact just passed the pink slip test with 53%. What is missing is the booster. Will look into that one. Hart
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Les Harris
Sent: Wednesday, 7 July 2010 1:33 PM
Ben,
on.
Hartmut,
From memory, Yurik’s conversion was comprehensive and would have included a matched booster. He has mentioned his conversion previously but probably not in full detail. It will be worth asking him for a detailed description.
Ben,
There are conversions that require some machining and some that are bolt-on. Ben Tan in the US has good knowledge of what is available and might be good enough to share it with us. Ben posted detailed information some time ago but it would take some searching to find it in the archives.
On Behalf Of Hartmut Kiehn
Sent: 07 July 2010 13:47
improved braking
> Hartmut,
> From memory, Yurik's conversion was comprehensive and would have included a
> Ben,
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Hartmut Kiehn
> Hi Les, I have used a Bernd Jaeger Audi assembly and gone to 16" rims, but
> 15" would do also. Braking has not improved though, in fact just passed the
> one. Hart
Les,
Something like these for 15" rims ...
Goto: http://www.gowesty.com/ec_view_details.php?id=23124&category_id=71&category_parent_id=
Goto: http://www.smallcar.com/index.php?dispatch=products.view&product_id=29928
Ok for you Les, you own a gold mine ... damn your good fortune!
Date: Wed, 7 Jul 2010 13:54:20 +1000
Hartmut,
Ben,
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_T3_Australia @yahoogroups. com] On Behalf Of Hartmut Kiehn
Subject: RE: [Syncro_T3_Australi a] improved braking
Ralph
Sent: Wednesday, 7 July 2010 3:31 p.m.
> Sounds good Ben.
> Scott
> From: bencroft96
> > > Ben,
> > > Cheers,
> > > Scott
> > > From: bencroft96
> > > > Ben,
> > > > Mr Kevin Humphrey
> > > > 4 Willow Tree Road,
> > > > Wyong NSW 2259
> > > > Ph: 4353 0866
> > > > Best of luck.
> > > > Cheers,
> > > > Scott
> > > > From: bencroft96
Les do you have any positions vacant in your gold mine?
> Les,
> From: leslieharris@...
> Hartmut,
> From memory, Yurik's conversion was comprehensive and would have included a matched booster. He has mentioned his conversion previously but probably not in full detail. It will be worth asking him for a detailed description.
> Ben,
> Hi Les, I have used a Bernd Jaeger Audi assembly and gone to 16" rims, but 15" would do also. Braking has not improved though, in fact just passed the pink slip test with 53%. What is missing is the booster. Will look into that one. Hart
> If It Exists, You'll Find it on SEEK. Australia's #1 job site
> http://clk.atdmt.com/NMN/go/157639755/direct/01/
