As of about Xmas time I thought that my bus wasnt pulling uphill or through the gears as good as it should be.
My suspicions were a fuel related problem as it wasnt as miss as such but a feeling that something was holding me back.
Today I finally got some time to have a look and removed the fuel filter,drained it into a glass jar.
At first the fuel running out looked clear,so I blocked both ends and gave the filter a shake,and you should of seen what came out!
Black thick muddy crap oozed out.
I replaced the filter and took it for a run and I had that new engine feeling again!!
I only replaced that filter just over a year ago,so it goes to show how much work it has to do filtering our crook fuel.
I guess the position of the filter also puts it in the,I will do that next service catergory,but I rekon it should be replaced atleast every year.
I also have a new pump which I keep as a spare as the original is bound to fail one day.
So if you feel that your bus isnt going as good as you remembered,jack up the nsr and check the fuel filter out.
See you at the Nationals.
BenC
