Mark Boys has a set of clip-on headlight protectors on his Doka, which he got many years ago from overseas. Has anyone seen anything similarlocally? Ben T, have you seen these protectors anywhere?
On Nov 10, 2011, at 5:41 PM, "syncroaustralia" <leslieharris@optusnet.com.au> wrote:
Ben,
The Australian protectors were attached to the grille with double sided tape. This was a totally mad concept and appears to have been predicated on the notion that no dust ever got behind them and that the head lights never needed cleaning. The whole grille has to be removed to clean them!! I still have my originals but modified them to a screw on attachment to make for easier cleaning.
Are you referring to the glued-on protector or the snap-on protector in the second paragraph?
On Behalf Of BenT Syncro
Sent: 11 November 2011 13:35
Headlight Protectors
Les,
I have a set of the original OZ VW part. I also got a few aftermarket sets from Bus Depot some years back.
Per Ron Salmon, owner of B.D., they are out of production. I suggested asking Trevor (aka the Skylight Guy) who also bought the tooling for Delta Six (maker of Westfalia utility ports) if he can return these to production. No final yet but should happen. Trevor's specialty is plastics.
sent from my electronic leash
On Nov 10, 2011, at 6:48 PM, "Les Harris" <leslieharris@optusnet.com.au> wrote:
Ben,
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com ] On Behalf Of BenT Syncro
Subject: Re: [Syncro_T3_Australia] Headlight ProtectorsLes,
Ben,
I have learned something there. I wasn’t aware that clip-ons were ever available in Australia and as genuine parts. (Phill will probably know more about that.) I can now reasonably conclude that what is fitted to mine was a Trakka addition. Like most of what Trakka did, it was poorly conceived and poorly executed. If you don’t need the Australian clip-ons that you have, I would certainly like to acquire them.
Sent: 11 November 2011 13:59
Les,
Both units I have are clip-ons. I don't have them handy or will post a pic. The Aussie ones say VW Australia or something like that. Thin lines across the face. The US knockoffs were very similar except no lines and no VW logos. There were several different brand being sold at one time even dark tinted versions. Quality was spotty. Then rather suddenly, the supply dried up. It was unexpected as the units were not identical suggesting there was more than one manufacturer.
As Greg mentioned, all these covers clip on/off and comes off with the grill if so desired. The clip on feature is a necessity in most places in the US where headlight covers are technically illegal unless it was installed by the manufacturer (VW in this case).
On Nov 10, 2011, at 7:06 PM, "Les Harris" <leslieharris@optusnet.com.au> wrote:
Ben,
If it’s not a totally silly question, why are you ‘investing’ in LH drive headlights?
Sent: 11 November 2011 14:31
Hi Les,
I have a substantial amount invested in LHD headlights. This is the reason why I have headlight covers. I would love to accommodate you but the OZ covers are naturalized US citizens (notice all the Z's).
,___
> Ben,
> predicated on
> never
> I
> make
> second paragraph?
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of BenT Syncro
> Les,
> sets
> Delta
> production.
> BenT
The VA prefix and six digit number tends to suggest that this is/was a number specific to Volkswagen Australia ? True?
Sent: 11 November 2011 14:54
Subject: Re: RE:
The original headlight
protectors sold as a Volkswagen accessory were the stick on type. (VA 088 500)
__
On Nov 10, 2011, at 7:34 PM, "Les Harris" <leslieharris@optusnet.com.au> wrote:
Hi Les,
,___
> Phill,
> number specific to Volkswagen Australia? True?
> Subject: Re: RE: [Syncro_T3_Australia] Headlight Protectors
> The original headlight protectors sold as a Volkswagen accessory were
> __
> Les,
> The brain doesn't always connect w/ the fingertips. It should have said,
> "...LHD e-code headlights...". Used examples sell, literally ten times
> US DOT headlights.
> BenT
> wrote:
> > If it��������s not a totally silly question, why are you �������investing�������� in
> > Hi Les,
> > ,___
OK, next question. What are the clip-on protectors that Ben is referring to which he believes are of Australian origin? Would these be the Aunger version?
Sent: 11 November 2011 15:09
Subject: Re: RE: RE:
That is correct.
> Les Harris <leslieharris@optusnet.com.au>wrote:
> Phill,w:st="on">Australia ? True?
> referring
> Aunger
> version?
> Subject: Re: RE: RE: [Syncro_T3_Australia] Headlight Protectors
> That is correct.
> <mailto:leslieharris%40optusnet.com.au> > wrote:
> > Phill,
> > Les
On Nov 10, 2011, at 8:59 PM, plander@optusnet.com.au wrote:
> Probably.
>> referring
>> Aunger
>> version?
>> _____
>> That is correct.
>>> Phill,
>>> Les
On Nov 10, 2011, at 8:10 PM, plander@optusnet.com.au wrote:
> Les,
> US headlights are different from the rest of world. I think that the globes are different also.
>> Les,
>> US DOT headlights.
>> BenT
>>> Hi Les,
>>> ,___
> Les,
>> Les,
>> US DOT headlights.
>> BenT
>>> Hi Les,
>>> ,___
On Nov 10, 2011, at 11:45 PM, greg esposito <gregespo73@yahoo.com> wrote:
Oh well Ben, at least you guys got westys. We just got bath tubs glued to our roofs and flat pack kitchens installed by neanderthals. Greg EFrom: BenT Syncro <syncro@gmail.com>
Sent: Friday, 11 November 2011 5:47 PM
Subject: Re: [Syncro_T3_Australia] Headlight ProtectorsUS headlights are a perfect backdrop for a romantic evening. They are not bright enough to blind your date and lets your Syncro cast a shadow over it's light pattern when other vehicles are behind you. Sexy!
As for road illumination, you'd be better off with beeswax candles.
> Les,
>> Les,
>> US DOT headlights.
>> BenT
>>> Hi Les,
>>> ,___
> Yes, I suppose. But after the beginning of the T4, VW switched to
> Winnebago. It's a close second, but Westies in the US has gone the way
> of the dodo. At least as far as VW is concerned.
> We had Country Homes, ASC, Adventurewagen, and a couple of others which
> aren't better than what you got. With the exception of the AW top, the
> quality of the builds were less than stellar.
> BenT
> > BenT
> > > Les,
> > > Phill
> > >> Les,
> said,
> times
> > >> US DOT headlights.
> > >> BenT
> > >> wrote:
> > >>> If it������������������s not a totally silly question, why are you
> ���������������investing������������������ in
> Syncro
> > >>> Hi Les,
> but
> > >>> ,___
> > > Yahoo! Groups Links
