Instrument Cluster
Bent;
Isn't that the same as warped or twisted?
> Gliders, feathers, Les in OZ, Les my ex-wife...
> It's all losT in TranslaTion to me, LesT you explain it in
> Volkswagenspeak. NoTice that there is no T in Volkswagen.
> Here I was Thinking feathers meant springs per Phill's sTaTemenT. See
> there's no T in Phill.
Warped must be Australian for Twisted and BenT because it doesn'T have a T.
I noTiced there's no T in Phill eiTher.
On Dec 30, 2010, at 4:29 PM, plander@optusnet.com.au wrote:
> Bent;
No wonder this is called the Silly Season!!
Sent: 31 December 2010 12:11
Subject: Re: [Syncro_T3_Australia] Instrument Cluster
> Bent;
Well if you feel even with 16" wheels you won't achieve an accurate speedo, then for arguments sake, that may bring into question the accuracy of GPS technology, given my speedo reads the same speed as the GPS digital readout running 15" wheels with a worn diameter of 706mm.
My original 14" Michelin X tyres are 676mm worn, an exact diameter difference of 30mm from the above 15" wheels. I accept the speedo would read fast with the 14" wheels and my 15" wheels appear to attain a correct speedo reading ... or else the speedo is still wrong if one can't believe the GPS readout.
Begs the question ... if one accepts that GPS readout is accurate, how come you are having difficulty getting accuracy even with 16" wheels (assuming the O/A diameter is larger)? What's so different about your syncro setup to cause this dilemma?
Date: Thu, 30 Dec 2010 14:10:13 -0800
Subject: RE: [Syncro_T3_Australia] Instrument Cluster
Ken as has already been pointed out a manufacturer will always make there speedos read high to avoid litigation. I do not know the VW equation of the top of my head but the BMW one is @ 100kmh minus 7kmh then plus or minus 4kmh. So your speedo is good if at 100kmh true your speedo reads 89kmh to 97kmh. Japanese cars tend to be more accurate at around 3 to 4kmh low. My bus reads a whole 10kmh fast with tyres slightly larger than stock. Even when I fit 16"s I wont bridge this gap, unless of course I cut out the guards, fit BIG tyres and a 3.0L tdi!!! Greg E
Received: Thursday, 30 December, 2010, 10:43 PM
Les,
Just love opening cans of worms  .....
re: "This further means that anyone who has fitted a larger wheel/tyre size can get a correct speedo reading by fitting the gear appropriate to the wheel/tyre size."
Case in point, my present tyres are a slightly larger diameter than the BFG T/A 215 75 R15s.
So from what you say above I can only assume but find it very hard to believe, that a previous owner of my syncro had the speedo drive gearing changed to suit 15" wheels and tyres, given it is my experience that my GPS readout and the speedo read exactly the same whilst travelling.
So given I find it hard to believe the gearing was changed and knowing the syncro originally had 14" wheels and michelin tyres, why is my speedo reading correctly?
A happy new year conundrum.
Ken, All of your hypothesis rely on one assumption, that our speedometers read the same at a given speed. Mine is way out and needs calibrating. With the tyres it would have been delivered with the cluster would have shown about 88kmh at 100kmh. No new car buyer would have accepted this. In reference to GPS, trust it they are very accurate. I have had customers with $350,000 cars complain about speedo inaccuracy and driven the car with no less than three GPS units, they all read the same. Greg E
Received: Friday, 31 December, 2010, 3:11 PM
Les,
As well as there being 8 different drive ratios there are also 3 different drive gears on the pinion shaft that need to be matched up for a specific crown wheel and pinion ratio and tyre size.
I think it would be much easier if all the mechanical gears were one standard size and the different configurations could be selected by a system of replaceable plastic gears in the speedo – perhaps this is too simple for VW!
Yurik
Sent: Thursday, 30 December 2010 4:57 PM
Ben, Greg,
It has all come together with these replies.
The drive gear (Ben’s picture) fitted to the front diff comes in eight different ratios and each ratio is matched to tyre sizes.   This answers the original question.  The Syncro speedo is the same as for all T3’s and the correct reading is achieved via the drive gear in the front diff being matched to the tyre size.
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of BenT Syncro
Sent: 30 December 2010 19:13
Les,
No need to dismantle your instrument cluster. This drive gear is attached to front differential. I am quite quite familiar with the NoOxBoxForOZ fact.
Ok thanks for that, you've answered my query. Happy recalibrating and Happy New Year!
Date: Thu, 30 Dec 2010 21:05:02 -0800
Les,
Found this on the net Les. Interestingly this mph speedo I have is loose on the metal gear! Greg E
Received: Friday, 31 December, 2010, 7:59 PM
Yurik
Ben, Greg,
Les,
Sorry forgot link
http://www.twistedlimbpaper.com/brian/vanagon/Odometer.htm
Received: Sunday, 2 January, 2011, 9:55 AM
Yurik
Ben, Greg,
Les,
What did you find?   There is no further reference in you email.
Thanks, got it.  It never ceases to amaze me just how much time and effort some people will put into something like this to help others.
He came to the same conclusion as I did – Loctite.  Applying a knurl won’t helping my case because of the hairline crack through the nylon gear but the load is light and I might get away with stud grade Loctite.  I will go down to the local Repco shortly and see what hey have on the shelf.
Sent: 02 January 2011 09:57
