Long Range Tanks
Les,
Thanks and will have a look.
Leighton
_,___
Scott,
Thanks and I am trying to dowload image but having issues.
Leighton
 Hello Syncro Owners,
I have just returned from a trip to WA and saw two syncros on the road one a white transporter window van heading to Bunbury from Perth and the other one was a white camper in Bussleton heading south on the bussell high way? Just trying to put syncos with people if possible?
Leighton
_,___
 Hello,
Can anyone help with coolant overflow tanks and getting them clean inside and outside/looking white again without buying new ones?
Leighton
Leighton,
You will never get it back to snow white!  All you can do is wash it with very strong detergent (Spray and Wipe works well) and then use bleach to get into the stains.  It won’t be snow white but it will look a whole lot better!
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Leighton Smith
Sent: 12 April 2012 21:34
Subject: RE: [Syncro_T3_Australia] coolant over flow tanks
 Hello,
Leighton
Les,
Thanks and working on them now. May need to do a whole cooling system flush after looking at the over flow bottles. Is is easy and do you have ant tips?
Leighton
Date: Fri, 13 Apr 2012 11:24:29 +1000
Leighton,
 Hello,
Leighton
And remember Snow White found that 6 out of 7 of her little friends were not Happy!
Received: Friday, 13 April, 2012, 9:24 AM
Leighton,
 Hello,
Leighton
 Hello,
Can anyone help with what product I can use for a cooling system flush or procedure I should follow. I have read the workshop manuals and understand what I need to do. I just want to flush any bad stuff out..
Thanks Leighton
I would fill it with tap water, bleed it and drive it for a day. Do this at least twice or untill it comes out clean. Then fill with g11 or g12. Greg E
Sent: Saturday, 14 April 2012 8:50 AM
Subject: RE: [Syncro_T3_Australia] cooling system flush?
 Hello,
Thanks Leighton
I'd just put the garden hose through the radiator, drain it completly, then fill it with distilled water and G11 or G12++. Most of the rubbish will be in the radiator.
> I would fill it with tap water, bleed it and����drive it for a day. Do
> g12. Greg E
> From: Leighton Smith <smith_leighton@hotmail.com>
> ����Hello,
> Thanks Leighton
Ah yes, but would you put Rockhampton tap water through even for a
flush with salt levels 4 times the normal at the moment??????
Solution? Move to Melbourne they bottle the tap water here! Greg E
Sent: Saturday, 14 April 2012 12:22 PM
Subject: Re: [Syncro_T3_Australia] cooling system flush?
Thanks and why do you have to use G11 or G12? what is wrong with Nulon?
Leighton
Date: Fri, 13 Apr 2012 16:51:05 -0700
 Hello,
Thanks Leighton
Hello Phill,
What location do I put the garden hose in the radiator?
Leighton
> Date: Sat, 14 Apr 2012 09:57:29 +1000
> Subject: Re: Re: [Syncro_T3_Australia] cooling system flush?
> > g12. Greg E
> >  Hello,
> > Thanks Leighton
> <*> To visit your group on the web, go to:
> <*> Your email settings:
> <*> To change settings online go to:
> (Yahoo! ID required)
> <*> To change settings via email:
> <*> To unsubscribe from this group, send an email to:
> <*> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
The hoses at the bottom
> Leighton Smith <smith_leighton@hotmail.com> wrote:
> Hello Phill,
> Leighton
> > Phill
> > > I would fill it with tap water, bleed it and�� drive it for a day. Do
> or
> > > g12. Greg E
> > > �� Hello,
> flush
> out..
> > > Thanks Leighton
> > Yahoo! Groups Links
Thanks Phill,
Was just cjecking it was not through the bleeder at the top of radiator. Can you help with the bleeder? does it come off or just turn?
Leighton
> Date: Sat, 14 Apr 2012 13:47:12 +1000
> Subject: Re: RE: [Syncro_T3_Australia] cooling system flush?
> > Hello Phill,
> > Leighton
> > > Phill
> > or
> > > > g12. Greg E
> > > > Â
> > > > Â Hello,
> > > > Â
> > flush
> > out..
> > > > Â
> > > > Thanks Leighton
> > > Yahoo! Groups Links
The types of metal in modern engines require special coolants. There is no one size fits all so Nulon is rubbish. Same with oil filters, do not buy them from Repco, Supercheap etc.
If you have a Holden, you buy parts from a Holden dealer. If you have a VW, you buy VW parts.
> Greg,
> Leighton
> From: gregespo73@yahoo.com
> Greg E
> Hello,
> Thanks Leighton
Just turn
> Thanks Phill,
> Leighton
> > > Hello Phill,
> > > Leighton
> completly,
> rubbish
> > > > Phill
> day. Do
> g11
> > > or
> > > > > g12. Greg E
> > > > > �� Hello,
> > > flush
> and
> > > out..
> > > > > Thanks Leighton
> > > > Yahoo! Groups Links
> > Yahoo! Groups Links
Leighton,
Mechanics with extensive experience with the MV engine all use G12++.  I suggest that you do the same.
What you are protecting the engine against is not freezing but corrosion and the 12++ is known to be very adequate.
Sent: 14 April 2012 13:44
Leighton
,_._,___
so it should only turn and not come off? Iam I correct in turning the bleeder valve in the back to the left to open? does it only turn about half a turn?
Leighton
