----- Original Message -----From: Les HarrisSent: Thursday, November 28, 2013 12:40 PMSubject: [Syncro_T3_Australia] VIN NUMBERS
VIN NUMBERS
Over the years, various avenues have been tried but without success. I have an idea that I am going to follow up through one of our German members that might be a lot more productive.
In the meanwhile, we could help ourselves by asking every member to send in his VIN number it has to be on every registration certificate and it is on the Syncro in several places. This would enable us to start building a register and keep track of the few left in Australia and New Zealand .
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Jon Bartlett
Sent: 27 November 2013 15:32
Subject: Re: [Syncro_T3_Australia] Trakka Numbers
Hi Les,
Would VW be able to assist? Presumably they would hold numbers sent to Australia and perhaps those destined for Trakka?
Jon.
Les,
My ex Telecom's is #WV2ZZZ25ZLG109265
Sent: Thursday, 28 November 2013 12:40 PM
VIN NUMBERS
In the meanwhile, we could help ourselves by asking every member to send in his VIN number – it has to be on every registration certificate and it is on the Syncro in several places. This would enable us to start building a register and keep track of the few left in Australia and New Zealand.
Hi Les,
Jon.
Hi Les. Mine was built in August 1988 and on the road in Victoria in January 1989 after a camper conversion by Suncamper in Sydney. Wish I could trace the original owner in Victoria as he did a lot of extra work. It had a very brief time with a second owner in Melbourne before I got the van and did more mods. The second owner claimed he did not get any paperwork from the first owner. Hmmm!!
VIN WV2ZZZ25ZKG027315
Regards, Peter from Port Mac
On Thu, 28/11/13, Graham Adams <g.adams2@bigpond.com> wrote:
Subject: Re: [Syncro_T3_Australia] VIN NUMBERS
Received: Thursday, 28 November, 2013, 10:27 PM
Hi Les
Since new Oct "89 wv2zzz25zkg114047 and from '09 '90 wv2zzz25zlg040022
Paul
Hi Les
VIN
WV2ZZZ25ZMG017932
1991 Syncro de
lux , original
owner
Graham Adams
Harris
Sent: Thursday,
PM
Subject:
NUMBERS
VIN
NUMBERS
Over
the years,
I have an idea that
that might be a lot
more productive.
In
the meanwhile,
his VIN number – it
Zealand .
Bartlett
Sent: 27
November 2013 15:32
To:
Subject: Re:
Numbers
Hi
Les,
Would
Trakka?
Jon.
HI Les,
looks like I started something there
91 Syncro Caravelle Trakka WV 2ZZZ25ZNGO20298
89 Caravelle 7 seater camper conversion WV 2ZZZ25ZKGO48432
Yes one has to go. Probably next year once Trakka gets Subi donk fitted.
---In Syncro_T3_Australia@yahoogroups.com, <geraldandrobyn@...> wrote:Hi Roger Bayley,Mine's a '89 silver Caravelle GL Syncro. What colour is yours?Gerald
Can anyone tell me where the normal coolant temperature gauge gets its reading from? It is no doubt in Bentleys somewhere – just not mentioned in the Cooling section – of course!!
Sent from my iPhone
On 30/11/2013, at 12:04 PM, "Les Harris" <leslieharris@optusnet.com.au> wrote:
Unless I'm mistaken, the temperature gauge sender comes out of the forward side of the housing for the thermostat.
See attached.
--Original Message Text---
Date: Sat, 30 Nov 2013 13:04:35 +1100
Can anyone tell me where the normal coolant temperature gauge gets its reading from? It is no doubt in Bentleys somewhere just not mentioned in the Cooling section of course!!
Hamish,
That is the T2 sensor and might or might not be what goes to the gauge. The T2 is the sensor that tells the ECU what the coolant temperature is so that it can set the ignition and the fuel injection to the right values. Mine malfunctioned a year or so ago and starting was very difficult until I found a new one! Still, it might also send to the gauge; I will have to comb through the wiring diagram until I find it – something that I was hoping to avoid.
Behalf Of HamishD
Sent: 30 November 2013 16:09
To:
Temperature Gauge Sender
From your thermostat
housing bro
Les it is on page 19.11 of the Bentley and is labelled twice. "Temperature Sender coolant display" and is also labelled incorrectly " Temperature Sender for injection".
It is also on page 40 of the genuine VW factory workshop manual 2.1 ltr EFI Engine (Digijet,Digifant) labelled correctly.
Sent from my iPhone
On 30/11/2013, at 3:23 PM, "Les Harris" <leslieharris@optusnet.com.au> wrote:
Hamish,
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of HamishD
Subject: Re: [Syncro_T3_Australia] Temperature Gauge SenderFrom your thermostat housing bro
Thanks for the reply. I thought that the T2 gave the ECU its primary temperature information. If it doesn’t, what does? I would have to unload a heap of building material from my Syncro at the moment to inspect this sender.
Sent: 30 November 2013 16:34
To:
Subject: [Syncro_T3_Australia] RE:
Les it is on page 19.11 of the Bentley and is labelled twice. "Temperature Sender coolant display" and is also labelled incorrectly "Temperature Sender for injection".
there are two temp sensors on the thermostat housing of a syncro vanagon.
one talks to the ecu, commonly called Temp Sensor II ,
the other one..
which is a screw-in single contact metal sender ( assuming you have the aluminum syncro t-stat housing and not the plastic 2WD one ) ........is the one that talks to the stock temp gauge.
I'd want to keep both though ......my stock gauge and my new aftermarket one ..
I would look into drilling and taping another spot in the aluminum t-stat housing.
I have some off the vehicle..
next time I see one I'll look to see how practical that might be.
scott
Oregon
Hamish,
Scott,
That saves me having to unload my Syncro to look at the housing. Now it makes sense – the T2 tells the ECU what’s happening and the other one tells the temp gauge what’s happening.
Lots can be lost in translation and this appears to have happened in this case where page 19.11 says “Temperature Sender coolant display”. Now that we have established that ‘coolant display’ means temperature gauge, all becomes clear.
Joachim is no doubt laughing his head off now!!
Behalf Of Scott Daniel
Sent: 30 November 2013 18:14
To:
You guys have probably got
this figured out by now..
the other one..
one ..
housing.
scott
Oregon
Yes that's correct. The Bentley is wrong. T2 is only for T2.
---In Syncro_T3_Australia@yahoogroups.com, <leslieharris@...> wrote:Phill,
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of plander@...
Subject: [Syncro_T3_Australia] RE: Temperature Gauge SenderLes it is on page 19.11 of the Bentley and is labelled twice. "Temperature Sender coolant display" and is also labelled incorrectly "Temperature Sender for injection".
hi jon sorry took so ,long to repliy yes I have both side and rear annex what area are you if you want to have alook quite welcome im down south Gippsland cheers andy
Hi Les
Paul
Hi Les
VIN
WV2ZZZ25ZMG017932
1991 Syncro de
lux , original
owner
Graham Adams
Harris
Sent: Thursday,
PM
Subject:
NUMBERS
VIN
NUMBERS
Over
the years,
I have an idea that
that might be a lot
more productive.
In
the meanwhile,
his VIN number – it
Zealand .
Bartlett
Sent: 27
November 2013 15:32
To:
Subject: Re:
Numbers
Hi
Les,
Would
Trakka?
Jon.
