PICS of Vanagon factory AC bracket
Hello Les,
Sorry for getting this to you so late. I hope it isn't too difficult to see the bracket.
Shown here after the compressor has been removed. I hope to take better shots
after the longblock has been stripped and hopefully one of the bracket completely
off the engine. For now, this is the best I could get.
Happy Holidays!
Ben,
That’s great and I now have a clear idea of the mount.  Just for the hell of it, I will tomorrow send you a pic of the monstrosity that was fitted here by Prestige.
Sent: 24 December 2009 20:12
Subject: [Syncro_T3_Australia] PICS of Vanagon factory AC bracket
Hello Les,
Happy Holidays!
Ben,
Attached are pics of the (local) Prestige air conditioner compressor mount. It weighs 4.1 kg – that’s 9 pounds!! – plus there is a flat brace made from 1” X ¼” mild steel, plus the compressor.
Hello Les,
Happy Holidays!
Thanks, Les. I see it has a similar weak spot to the Tiico bracket for inline4 engine conversions from SA. They have a small outboard tab welded on which breaks on a regular basis. Best fix was found to be retrofit of a factory part.
I'll take some pics of the factory AC bracket once I get one off an engine.
Ben T
Sent from my mobile device
On Dec 25, 2009, at 3:50 PM, "Les Harris" <leslieharris@optusnet.com.au> wrote:
Ben,
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com ] On Behalf Of BenT Syncro
Hello Les,
Happy Holidays!
<IMG_0162.jpg>
<IMG_0163.jpg>
Ben,
Every aspect of this bracket is wrong.  Apart from the sheer mass, it is fraught with many problems.  To achieve the different mounting face levels, spacers have been tacked onto the m/s plate.  The welds are so shoddy that they stand above the mounting faces by up to 2+ mm, which mean that they bite into the crankcase mounting points when the bracket is bolted in place.   It is like NASA building a space shuttle out of used bridge girders.  There is no way anything on this bracket will break because it is so massive.  What breaks is the crankcase that it is bolted to!
What would be the availability of used genuine brackets in the US ?
Sent: 26 December 2009 11:29
Subject: Re: [Syncro_T3_Australia] PICS of Vanagon factory AC bracket
Ben T
Les,
I have never investigated availability yet. They should be relatively plentiful here in California. AC was almost a dealer mandated option as it was used to increase their profit margin.
My local parts place turned out to be a poor source because he resells almost al his engines rebuilt and complete. I will find a place that breaks up engines and report back my findings.
On Dec 25, 2009, at 4:54 PM, "Les Harris" <leslieharris@optusnet.com.au> wrote:
Ben,
Ben T
<IMG_0167.jpg>
<IMG_0168.jpg>
Ben,
Interesting that you mention the air conditioning option.  Yesterday, I was reading a publication issued by Volkswagen of United States Inc, titled “1986 Vanagon and Vanagon Syncro Service Training”.  I noted that they devoted ten pages out of sixty five just to the air conditioning and assumed that this was an indicator of the importance of air conditioning on the US market.  Your comment tends to confirm that.
If you can find a genuine bracket at some stage, it would be helpful.  I know someone who would make a pattern for me and it shouldn’t be a problem to get a few cast.  The machining is something that I could do for myself using a colleague’s machine shop.
Sent: 26 December 2009 12:08
Les,
I have never investigated availability yet. They should be relatively plentiful here in California . AC was almost a dealer mandated option as it was used to increase their profit margin.
On Dec 25, 2009, at 4:54 PM, "Les Harris" <leslieharris@ optusnet. com.au> wrote:
Les,
Now you can see why I was told not to get Aussie a/c.
It may be cheaper to source US brackets as they do not have to be syncro there should be easily obtainable. Maybe a source of pocket money for someone!
> Ben,
> was
> "1986 Vanagon and Vanagon Syncro Service Training". I noted that they
> assumed
> US
> know someone who would make a pattern for me and it shouldn't be a
> problem
> myself
> using a colleague's machine shop.
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of BenT Syncro
> Les,
> it
> breaks
> BenT
> <mailto:leslieharris@optusnet.com.au> optusnet.com.au> wrote:
That was certainly good advice.
If Ben Tan makes a sideline of it, I am sure that everyone with a Prestige monstrosity would be a ready customer.  But, as Ben has mentioned, it could be a matter of availability, which is why I was thinking in terms of pattern, casting and machining.
Sent: 26 December 2009 12:39
Subject: Re: RE: [Syncro_T3_Australia] PICS of Vanagon factory AC bracket
Les,
Les,
I now see what you mean. To me, this bracket looks like Prestige a/c bracket version 1 made very very late on a Friday afternoon, knock off bell imminent.
Mine must be version 2. I can visualise the 1st year apprentice being given the task to tack and fillet weld a batch of a 100 of these to practice welding skills. Also has the same m.s. brace but the rest of it seems to be re-designed so it looks stronger and the baseplate is one whole piece, no tacked on outrigger for the fourth bolt. This means my plate looks stronger than yours but I suspect even heavier. I have no reason though to suspect my case is damaged even though the case is probably the weakest link if ever things went awry. But I really do like what I see in BenT's photos ... looks a superior, integrated, lighter design solution.
Still begs the unanswered question though .... will our Prestige installed compressor be an exact bolt-in fit to the mounts and achieve correct pulley alignment on the vanagon a/c bracket?
Date: Sat, 26 Dec 2009 10:50:11 +1100
Subject: RE: [Syncro_T3_Australia] PICS of Vanagon factory AC bracket
Ben,
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_T3_Australia @yahoogroups. com] On Behalf Of BenT Syncro
Subject: [Syncro_T3_Australi a] PICS of Vanagon factory AC bracket
Hello Les,
Happy Holidays!
The danger point is the left rear corner of the crankcase and you have to remove the bracket to see it.  If the Mk II is stronger than the Mk I, it would then be 500% too strong instead of 300%.
We would need to see a genuine bracket to assess how the compressor will fit and that comes down to the lugs on the compressor body.  My compressor is a Sanden SD-510.  If any member has a genuine VAG cast aluminium bracket in Victoria , I would like to have a look at it.
Sent: 26 December 2009 18:07
Les,
Meant to mention that the compressor (with pulley) weight 7.6 kg, which is about 16.8 pounds, so there is 11.7 kg (nearly 26 pounds) sitting on the crankcase.  It only needs one loose bolt and the whole thing starts bouncing.
Les,
  ,___
Les,
I know many if the late model Vanagons got Sanden compressors. I don't
have the specifics at this time & no way to check until tomorrow.
It's still Christmas here for another 22 minutes. Someone won't be
happy if I go outside and start playing T3 detective.;-)
Ah, now that’s very interesting indeed.  This is a Japanese made compressor, so it looks like they had the US market as well.  You had better make wise use of the 22 minutes.  I would feel responsible if you were found impaled on a reindeer’s horns!
Sent: 26 December 2009 18:38
Les,
happy if I go outside and start playing T3 detective.;- )
BenT,
Any progress on vanagon factory brackets yet?
--- In Syncro_T3_Australia@yahoogroups.com, BenT Syncro <syncro@...>
wrote:
> Les,
> BenT
> leslieharris@... wrote:
> > Ben,
> > What would be the availability of used genuine brackets in the US?
> > Les
Syncro
bracket
> > engine.
> > Ben T
> > <IMG_0167.jpg>
> > <IMG_0168.jpg>
On Jan 12, 2010, at 6:36 PM, "Ken" <unclekenz@hotmail.com> wrote:
> BenT,
Haven't asked lately. Thanks for the reminder. I'll ask my T3 breaker/
killer tomorrow.
Ben,
Thanks.  I haven’t been putting anything in to the group latterly because I am up to my armpits in sorting out a couple of cranky computers but I am reading what is coming in.
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of BenT Syncro
Sent: 13 January 2010 13:44
Subject: Re: [Syncro_T3_Australia] Re: PICS of Vanagon factory AC bracket
On Jan 12, 2010, at 6:36 PM, "Ken" <unclekenz@hotmail. com> wrote:
> BenT,
killer tomorrow.
We better stop saying nasty things about Les if he is still listening in!
Ha!
Sent: Wednesday, January 13, 2010 1:47 PM
Subject: RE: [Syncro_T3_Australia] Re: PICS of Vanagon factory AC bracket
Ben,
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_ T3_Australia@ yahoogroups. com] On Behalf Of BenT Syncro
Subject: Re: [Syncro_T3_Australi a] Re: PICS of Vanagon factory AC bracket
> BenT,
killer tomorrow.
You are all safe.  I have pulled the plug on just a few people and that was because their actions were contrary to the interests of the group.  (It is some time since I have felt the urge to pull the plug on the entire group.)
Sent: 13 January 2010 13:54
Ha!
Les,
Only 3 PC's? Piece of cake  haha. Bloke I know here has a room full ... every variety and vintage. Needless to say he doesn't do much else. Oh dear.
Right now I'm busy doing what seems to be a PHD on syncro coolant hoses. Present count (ignoring lineal metre rubber hose cut to length) is 16 (and ignoring heater circus!) I see your fellow forum owner, Jim Davis, did a coolant hose exercise a while back where he went out and sought equivalent hoses from US auto part stores for much cheaper. From a post of his findings, he found replacements for at least 7 of them. Maybe he now has a more current list somewhere.
Armed with his found equivalent part nos., I may get down to a local parts supplier and see if they have similar. Could be a lot simpler, cheaper and available around Oz parts suppliers for at least some of them.
Anyone else done work on this sort of thing? I don't want to reinvent the wheel if you have ok.
Date: Wed, 13 Jan 2010 13:47:49 +1100
Ben,
> BenT,
killer tomorrow.
If It Exists, You'll Find it on SEEK Shopping Trolley Mechanic
