Having now got the correct name was able to Google this.Seems may even help with corrosion problems. Now thinking of putting in under floor heating in my Syncro for cold Melbourne nights. Roger
Uponor Multi-layer Composite Pipe Uponor multi-layer composite pipe systems, now offers the most comprehensive range of plumbing and heating systems available. Used extensively throughout Europe, Uponor MLC pipe is both flexible and formstable. Its enclosed aluminium pipe ensures that Uponor MLC pipe is 100% oxygen diffusion proof while maintaining very low expansion rates, similar to other metal pipes.
The inner and outer polyethylene pipes prevent scaling and corrosion and its unique combination of overlapped aluminium and raised-temperature polyethylene (PE-RT) ensures that Uponor MLC pipe is the only full strength plastic alternative to copper and now gives the installer the advantages of both metal and plastic, but with the disadvantages of neither.
Offered with fittings ranging from standard compression to the superb “Press-fit” system, Uponor MLC pipe brings new and genuine improved standards to installation techniques. Currently available in 12 sizes, Uponor MLC pipe is now the first genuine pipe for all applications, be it plumbing, heating or underfloor heating.
Ideally an alternate pipe would have an OD of 38mm so as to allow the already present rubber hoses at both ends to fit over. Also to provide the same flow volume as presently exists, the pipe ID should be 32mm. So using the Uponer MLCP pipe, most likely it will be OD & ID dimensionally different, at the very least making the MLCP pipe/rubber hose end joins problematic.
Gates (and probably Mackay also) standard EPDM synthetic rubber automotive coolant hose is heat rated to +135 deg C. The Uponer MLCP pipe spec I googled shows it tops out at +90 deg C. It also states a maximum continuous operating pressure of 10 bar at 70 deg C. Maybe your brother can comment further on this issue.
Someone may know whether the above heat and pressure ratings are compatible with Syncro coolant system specs.
I remain curious as to the potential of Bruce's previous comment re the Gates green stripe coolant hose. However, even if there is a dimensionally compatible green stripe hose, I believe (subject to confirmation) it only comes in 1 metre lengths, therefore requiring multiple end joins. Gets messier and messier.
May the saga continue.
Date: Sat, 24 Jul 2010 06:28:10 -0700
Subject: Re: [Syncro_T3_Australia] Coolant Pipes,
Looking for a hot date? View photos of singles in your area!
On 24/07/2010, at 11:13 PM, Roger Bell wrote:
Dear Everyone,Lots of things to reply to here, some of which complement each other.Les first -sorry have looked through all my T4 and miscellaneous stuff and don't seem to have kept the razorback brochure (1 page from memory). Will contact you if I ever come across it.Coolant Pipes.BruceMy brother rang me from Gove and I was able to ascertain and ring the local (Victorian distributor Hunt Heating 1300 001 800 (Still no reply from UK manufacturer) They(Mick in sales) told me they can supply from stock Multilayer composite (MLC) pipe in 5 metre lengths of 32mm or 40mm o/d.($66 and $122 respectively plus gst.) He could not immediately verify it but he thought the wall thickness was about 3mm. They have an aluminium core which allows them to bend to the curve needed but this is best done with a spring insert as when bending copper pipe.. My brother said the advantage of this MLC pipe is that if you kink it on bending you can take it back to the original shape with a heat gun.Ralph supplied the following on the go Westy brass insert kit which confirms a one and half inch size which would need the 40mm pipe. The kit would probably be the best way of joining to the rubber connecting pipes but it would add to the cost (USD49 + freight.Coolant Pipe Repair Kit
Part # 251-121-399KIT Works with: 1986 - 1991 Weight: 3.00 lbs Our Price: $49.95 Get $2.50 GoBucks
upon purchase!My brother said he would be happy to facilitate things for you Bruce including providing a sample once he gets home early Sept. but I would imagine you want to get back on the road before that. I take it the Go Westy kit wouldn't solve the problem by itself?RepoweringGary, Bruce of coolant pipe fame installed an inline VW (1.8??) in his Petrol Syncro and could probably add something for your consideration. What about the twin cab power and transmission below supplied by Andy?I've been driving around lately thinking the 2.1 wasserboxer engine in my car with my 70 profile x 16" tyres really isn't too bad in the way it performs around town and on the highway. Perhaps its the denser air of winter in Melbourne or perhaps they finally got them right by the end of '92. If you would like to borrow it for a couple of days to think about whether the relatively more simple alternative of a sound 2.1 petrol engine might fit the bill then you would be welcome as long as it doesn't come back with a clapped out diesel engine in it!.On why the price of diesel doesn't fluctuate like petrol I was told that the major users like Linfox and Toll put their not inconsiderable requirements out to tender whereas the likes of you and me have insufficient buying power even in aggregate to warrant the competition reflected in petrol prices. As remarked before govt. excise also makes a difference according to useage eg on farm.
Here ended the 1st lesson. I'm going away to write out 500 times I must be more succinct.
Subject: Re: [Syncro_T3_Australi a] Coolant Pipes, Down Under, T3twincab
Received: Friday, 23 July, 2010, 5:41 AM
Hi Roger and all,The T3 twin cab belongs to a friend of mine. It has a Subaru SVX 3.3 litre engine running on LPG with an auto transmission. Its not a Syncro but he wishes it was. I have driven this car a few times and its awesome, so much power. He has also upgraded the rear brakes with the rear disc brake kit from Queensland. Nice car!Cheers, Andy.From: Roger BellSent: Friday, July 23, 2010 2:34 AMSubject: Re: [Syncro_T3_Australi a] Coolant Pipes, Down Under, T3twincab
Dear Bruce,Sorry haven't been back on the coolant pipe substitutes. My Hydonic Heating brother is out of contact off in the "Nothing" part of the country on Ben's map in his Hilux and I have lost the name of the local distributor. I sent a request for this to the UK manufacturer and asked them for advice on our problem with the prospect of regular sales but to date have had a stoney silence. If you wanted additions to Ben's map obviously you would need to include Collingwood supporters and those offering free home roofing installation. They were filming "Underbelly" further down my street last week so I suppose you should also include my suburb and I should double chain my syncro to the nearest lampost.Does anyone have the name of the Australian distributor from an earlier posting of mine and/or the internal and external diameter of the coolant pipes. I'm not keen to disturb mine to measure them internally.Les I'm still raking through my hoard to see if I retained a brochure of the razorback. Will post it to the group and snail mail it to you if I locate it.On another tack pulled up alongside a nicely preserved white T3 twincab ute at traffic lights the other day noting a small enamel plate on the rear and side door with "twin cam boxer" on it . I was in my Camry and the driver looked across at me with that self satisfied "if you owned one you would understand" look on his face. It had a decker plate cover over the rear but I don't think it was a Syncro. Anyone in Victoria seen it and know what engine it runs?
Received: Thursday, 15 July, 2010, 6:24 AM
Hello Roger
Good to have you back. Thanks for the info. I am
still mobile just need to do something about it reasonably soon.
Pity about the stash of cash Ken was talking about, as that day one
of my daughter's had just cost me a few thousand. Still that what a
family is all about, no complaints. On second thoughts that money
could have done wonders for the syncro!!!!!
Roger, been waiting for you to add a few extra bits to BenT's Down
Under map.
Bruce
----- Original Message -----From: Gary CooksonSent: Saturday, July 24, 2010 3:15 PMSubject: Re: [Syncro_T3_Australia]repowering, Coolant Pipes, Down Under,Razorback, T3twincabHi Roger, thanks for the info and offer of trying out your beastie. Converting mine to a wasserboxer would be quite difficult though, i've spent hours reading about fitting an aaz which seems the most straightforward but still not that easy. I'm still waiting to hear the verdict on the state of my current engine. The diesel chap promised to ring on Friday so i expect i'll find out about Wednesday.
Weirdly enough one of my clients here is the daughter of Mr Hunt of Hunt Heating and she and her husband run a heating company here in Melbourne. I'm happy to try and find out more about the pipes if that would help.CheersGary
Hello Roger
Under map.
Bruce
Thanks for the info. Haven't done anything about
them yet.
As Phil says original pipes are available from classic parts de for
€116 each.
Stainless steel from quite a few places for around the US$350 mark.
Ken the local dealer told me he could get that hose in 10 foot
lengths. Haven't asked the cost yet.
My mechanic told me with hose you have to support it very well or you
could get air locks in it. Hence I guess the reason VW used pipes in
the first place, although there seem to be quite a few people in the
US using hose successfully. If I went that way one of my hoses could
be just one piece from radiator to engine. Not sure about the other.
Bruce
On 25/07/2010, at 10:35 AM, Scott Daniel - Turbovans wrote:re"Converting mine to a wasserboxer would be quite difficult though"don't know if you know this about me or not ..but 'what I do' is engine conversions to vanagons and syncro's ..full time..as long as you are not thinking about changing gearing in the differentials. ..I think a waterboxer engine will fall right in, more or less.syncro petrol and diesel tanks are different ..but I think the diesel tank will clear a waterboxer starter just fine ( going the other way it will not though )that would be my only question ...about fuel tank and starter clearance with a waterboxer engine and diesel syncro fuel tank.swapping the tank to run on gasoline ..shouldn't be a problem. ..just need the various bits and some patience and a good working space .and since you already have in inline four ..and might prefer petrol..that makes one think of various inline four petrol engines that might work nicely ..and VW ones are a pure-bolt in, pretty much.Given the uh...'challenges' that waterboxer engines have, namely joke 'head gaskets'...a cast iron block, aluminum OHC inline four petrol VW engine looks fairly attractive.i have an 87 jetta 1.8 16 valve DOHC inline four petrol engine I hope to find time to put in one of my vans one of these days... 123 hp at 5,000-something rpm.not a torque monster though, like you most likely would prefer for a Syncro.what fun these fine machines are !Scott----- Original Message -----From: Gary CooksonSent: Saturday, July 24, 2010 3:15 PMSubject: Re: [Syncro_T3_Australi a]repowering, Coolant Pipes, Down Under,Razorback, T3twincabHi Roger, thanks for the info and offer of trying out your beastie. Converting mine to a wasserboxer would be quite difficult though, i've spent hours reading about fitting an aaz which seems the most straightforward but still not that easy. I'm still waiting to hear the verdict on the state of my current engine. The diesel chap promised to ring on Friday so i expect i'll find out about Wednesday.
Hello Roger
Under map.
Bruce
----- Original Message -----From: Gary CooksonSent: Saturday, July 24, 2010 8:38 PMSubject: Re: [Syncro_T3_Australia]repowering, Coolant Pipes, Down Under,Razorback, T3twincabHi Scott thanks appreciate the info. I don't see any point putting in a wasserboxer as the chances of finding a good one seem slim. I'm leaning towards an AAZ diesel.
It seems i can run my existing turbo which is fairly new and so keep my 1.6 exhaust manifold (which i reground flat at Christmas) and also use the Bosch pump on my 1.6.So if i get that rebuilt (at great expense) it will keep me going while i hunt for an aaz and can then be reused on the aaz even.I think i'd prefer to stick with diesel but i'm not ruling out a 4 pot petrol.They sure do keep you busy these syncros!Gary
Hello Roger
Under map.
Bruce
On 25/07/2010, at 1:47 PM, Scott Daniel - Turbovans wrote:hi,reThey sure do keep you busy these syncrosman you can say that again ..talk about a 'labor intensive' vehicle..the engine part is the easy part even ...syncro's have things so packed there around the fuel tank, in the front suspension etc.do you guys have much rust down there ? Probalby not.not much rust in Oregon where I am ..but some syncro's from Canada, Alaska, and other northern climes are just desperately rusted from one end to the other. Like almost 'not repairable.'Scott----- Original Message -----From: Gary CooksonSent: Saturday, July 24, 2010 8:38 PMSubject: Re: [Syncro_T3_Australi a]repowering, Coolant Pipes, Down Under,Razorback, T3twincabHi Scott thanks appreciate the info. I don't see any point putting in a wasserboxer as the chances of finding a good one seem slim. I'm leaning towards an AAZ diesel.
Hello Roger
Under map.
Bruce
Sent: Sun, 25 July, 2010 1:17:18 PM
Hello Roger
Under map.
Bruce
----- Original Message -----From: Gary CooksonSent: Saturday, July 24, 2010 10:57 PMSubject: Re: [Syncro_T3_Australia]repowering, Coolant Pipes, Down Under,Razorback, T3twincabNot too much rust here, climate is fairly dry but i'm from the UK originally where they put salt on the roads in winter and it is damp so i'm always amazed at the rust free undersides of Australian vehicles.
Gary
Hello Roger
Under map.
Bruce
Gates Greenstripe in 10 foot lengths is a whole lot better than 1 metre lengths eh and being one of the alternatives to consider, a bonus for this alternative is that it is in fact actual coolant hose anyway. Also it's possibly heavier duty than Gates standard grade coolant hose. Any chance of getting further detailed spec info from a Gates Rep? Also, whether it's available in a 32mmID / 38mm OD size? I ask all this because I haven't yet found detailed specs/size range about it with Google.
Gates in Oz are based at 1-15 Hydrive Close Dandenong South Vic 3175. Phone: 9797 9666. The problem then is they don't publicise a 1800 phone number for interstate callers. Anyone down that way can help and follow this up for the group please?
Eyeballing my plastic coolant pipes, I see they are bundled with other pipes as well anyway and lots of zip ties holding them all together for support, also there are enough changes of direction and ups & downs along the lineal length, I doubt air locks would be a problem anyway. What might also need clarification though with a Gates Rep is whether or not this Gates Greenstripe in the size and lengths we need will in fact resist vacuum collapse.
Not sure what is different, if anything, with the coolant hose reticulation with your diesel motor. For example, a very rough lineal length check of my stock setup suggests 2 x 10 lineal foot lengths may only be enough to replace each plastic pipe only ... so in my case, probably need to leave the existing rubber hoses in place at each end and figure out how to join them ..... could be where the GoWesty hose repair kit comes into play.
Should all the above issues raised get the green light, it'd be handy to then get a short Greenstripe length and a GoWesty kit to experiment with first.
> From: royalb@aapt.net.au
> Date: Sun, 25 Jul 2010 12:39:21 +1000
> Hello Roger
> them yet.
> €116 each.
> Bruce
> <*> To visit your group on the web, go to:
> <*> Your email settings:
> <*> To change settings online go to:
> (Yahoo! ID required)
> <*> To change settings via email:
> <*> To unsubscribe from this group, send an email to:
> <*> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
--- In Syncro_T3_Australia@yahoogroups.com, alf ando <dansk53bus@...> wrote:
> HIÂ Scott. How hard is it to find a 1,9 TDIÂ at your end , must have ECU and
> wiring loom, 1,9 TDI has been on my wish list for along time.
> Regards
> Alf
> From: Scott Daniel - Turbovans <ScottDaniel@...>
> Â
> hi,
> re
> suspension etc.
> Scott
> www.turbovans. com
> >From: Gary Cookson
> >Â
> >an AAZ diesel.
> >pump on my 1.6.
> >for an aaz and can then be reused on the aaz even.Â
> >Gary
> >Â
> >>re
> >>but 'what I do' is engine conversions to vanagons and syncro's ..full time..Â
> >>nicely ..
> >>gaskets'...
> >>attractive.
> >>rpm.
> >>Scott
> >>www.turbovans. com
> >>>From: Gary Cookson
> >>>Â
> >>>Wednesday.
> >>>try and find out more about the pipes if that would help.Â
> >>>Cheers
> >>>Gary
> >>>Â
> >>>>Dear Everyone,
> >>>>Coolant Pipes.
> >>>>Bruce
> >>>>composite (MLC) pipe in 5Â metre lengths of 32mm or 40mm o/d.($66 and $122
> >>>>respectively plus gst.)Â He could not immediately verify it but he thought the
> >>>>gun.
> >>>>Click To Enlarge
> >>>>Weight: 3.00 lbs
> >>>>Our Price: $49.95
> >>>> Get $2.50 GoBucks
> >>>>upon purchase!
> >>>>providing a sample once he gets home early Sept. but IÂ would imagine you want
> >>>>Repowering
> >>>>around town and on the highway. Â Perhaps its the denser air of winter in
> >>>>Â
> >>>>succinct.
> >>>>Cheers
> >>>>Roger
> >>>>--- On Fri, 23/7/10, Andy Sinclair <andy@...> wrote:
> >>>>>From: Andy Sinclair <andy@...>
> >>>>>Â
> >>>>>Hi Roger and all,
> >>>>>Cheers, Andy.Â
> >>>>>Â
> >>>>>From: Roger Bell
> >>>>>Â
> >>>>>Dear Bruce,
> >>>>>lampost.
> >>>>>Cheers
> >>>>>Roger
> >>>>>--- On Thu, 15/7/10, Alison & Bruce Black <royalb@aapt. net.au> wrote:
> >>>>>>From: Alison & Bruce Black <royalb@aapt. net.au>
> >>>>>>Â
> >>>>>>Hello Roger
> >>>>>>Under map.
> >>>>>>Bruce
> >>>>>Â
> >>>>Â
I've been dealing with Richard from Tooley Imports Aust parts@tooley.com.au You could try him?tooleyparts@gmail.com; on behalf of; Tooley Imports [parts@tooley.com.au]Ralph-----Original Message-----
Sent: Sunday, 25 July 2010 10:21 p.m.
Subject: RE: [Syncro_T3_Australia] Coolant PipesBruce,
> From: royalb@aapt. net.au
> Hello Roger
> them yet.
> €116 each.
> Bruce
> http://groups. yahoo.com/ group/Syncro_ T3_Australia/
> http://groups. yahoo.com/ group/Syncro_ T3_Australia/ join
> Syncro_T3_Australia -digest@yahoogro ups.com
> Syncro_T3_Australia -fullfeatured@ yahoogroups. com
> Syncro_T3_Australia -unsubscribe@ yahoogroups. com
> http://docs. yahoo.com/ info/terms/
Thanks for the offer. If they have even longer than 10 feet lengths, and if they have some brilliant end joiners that don't compromise the internal dimension and volume flow, even better.
I actually have here the Gates Hoses Cattledog but nowhere in it is anything on their Greenstripe range. Nor costings.
Date: Sun, 25 Jul 2010 05:27:10 -0700
Subject: RE: [Syncro_T3_Australia] Coolant Pipes and vanilla slices
----- Original Message -----From: bencroft96Sent: Sunday, July 25, 2010 4:09 AMSubject: Re: [Syncro_T3_Australia]repowering, Coolant Pipes, Down Under,Razorback, T3twincabAlf,Ebay,There is heaps of Golf engines etc.You can even buy a brand new WBX long motor.1900 US
> Regards
> Alf
> Â
> hi,
> re
> suspension etc.
> Scott
> www.turbovans. com
> >From: Gary Cookson
> >Â
> >an AAZ diesel.
> >pump on my 1.6.
> >Gary
> >Â
> >>re
> >>nicely ..
> >>gaskets'...
> >>attractive.
> >>rpm.
> >>Scott
> >>www.turbovans. com
> >>>From: Gary Cookson
> >>>Â
> >>>Wednesday.
> >>>Cheers
> >>>Gary
> >>>Â
> >>>>Dear Everyone,
> >>>>Coolant Pipes.
> >>>>Bruce
> >>>>gun.
> >>>>Click To Enlarge
> >>>>Weight: 3.00 lbs
> >>>>Our Price: $49.95
> >>>> Get $2.50 GoBucks
> >>>>upon purchase!
> >>>>Repowering
> >>>>Â
> >>>>succinct.
> >>>>Cheers
> >>>>Roger
> >>>>>Â
> >>>>>Hi Roger and all,
> >>>>>Cheers, Andy.Â
> >>>>>Â
> >>>>>From: Roger Bell
> >>>>>Â
> >>>>>Dear Bruce,
> >>>>>lampost.
> >>>>>Cheers
> >>>>>Roger
> >>>>>>Â
> >>>>>>Hello Roger
> >>>>>>Under map.
> >>>>>>Bruce
> >>>>>Â
> >>>>Â
On Sun, Jul 25, 2010 at 10:58 PM, Ken Garratt <unclekenz@hotmail.com> wrote:Roger,
Ken,So they don't get phone calls from the entire Victorian register I'll undertake to give Gates a (local) call Monday and post the result. Didn't the 1.9 wasserboxer have rubber coolant pipes rather than the 2.1's plastic?Francesca,Pleased you are enjoying your Syncro again but then your engine does know the school holidays are over.Smilarly stopped at Woodend bakery on Saturday and sampled their equally delicious coffee scrolls before going on to Trentham and doing part of the walk along their old railway track. Unfortunately having trouble getting my wife Heather out in the Syncro as she prefers our other car. She reckons the Syncro is too "blokey". Guess I'll have to paint it pink.GaryWhat a coincidence on Hunts. Seems I don't need to persevere with them due to the other alternatives and problems with matching the size differences.Bruce let me drive his diesel on the first Shallow River Crossing get together and I can understand the appeal for you to stay with the oil burner.CheersRogerBruce,
I checked with the local Repco shop ( Gates suppliers).
The Wire-Inserted Green Stripe Coolant Hose 1.5"I.D. $255.00 !! per 10 foot
Sent: Mon, 26 July, 2010 8:28:34 AM
----- Original Message -----From: bencroft96Sent: Sunday, July 25, 2010 4:09 AMSubject: Re: [Syncro_T3_Australi a]repowering, Coolant Pipes, Down Under,Razorback, T3twincabAlf,Ebay,There is heaps of Golf engines etc.You can even buy a brand new WBX long motor.1900 US
--- In Syncro_T3_Australia @yahoogroups. com, alf ando <dansk53bus@. ..> wrote:
> Regards
> Alf
> ____________ _________ _________ __
> From: Scott Daniel - Turbovans <ScottDaniel@ ...>
> Â
> hi,
> re
> suspension etc.
> Scott
> www.turbovans. com
> >From: Gary Cookson
> >Â
> >an AAZ diesel.
> >pump on my 1.6.
> >Gary
> >Â
> >>re
> >>nicely ..
> >>gaskets'...
> >>attractive.
> >>rpm.
> >>Scott
> >>www.turbovans. com
> >>>From: Gary Cookson
> >>>Â
> >>>Wednesday.
> >>>Cheers
> >>>Gary
> >>>Â
> >>>>Dear Everyone,
> >>>>Coolant Pipes.
> >>>>Bruce
> >>>>gun.
> >>>>Click To Enlarge
> >>>>Weight: 3.00 lbs
> >>>>Our Price: $49.95
> >>>> Get $2.50 GoBucks
> >>>>upon purchase!
> >>>>Repowering
> >>>>Â
> >>>>succinct.
> >>>>Cheers
> >>>>Roger
> >>>>>Â
> >>>>>Hi Roger and all,
> >>>>>Cheers, Andy.Â
> >>>>>Â
> >>>>>From: Roger Bell
> >>>>>Â
> >>>>>Dear Bruce,
> >>>>>lampost.
> >>>>>Cheers
> >>>>>Roger
> >>>>>>Â
> >>>>>>Hello Roger
> >>>>>>Under map.
> >>>>>>Bruce
> >>>>>Â
> >>>>Â
Get $2.50 GoBucks
Get $2.50 GoBucks
Get $2.50 GoBucks
Get $2.50 GoBucks
Get $2.50 GoBucks
Get $2.50 GoBucks
