On 11.10.2009, at 01:14, Les Harris wrote:
> Mine are single hex and there is no functional difference between
> the two heads. I have no way of knowing what was on it originally.
> In terms of having to service something on the road, I prefer the
> single hex because a) I always carry a set of hex keys in the tool
> box and b) I can get replacement good quality hex keys from any
> motor spared outlet.
See, in terms of "service on the road", i would never want to have
single hex, because a) once they are muddy and dirty you f*ck'em up
VERY easily with no way of loosening on-he-fly, except for giving a
goof XZN and a hammer a try - and b) i don't need replacement since i
don't need to f*ck'em up :) XZN is simply the more robust head in
terms of torque (tool2head) and servicability in dirt and (shorter)
intervals. So to sum it up: Whoever has single hex over here, switches
to XZN the first chance he gets.
Ciao,
Martin
P.S.: We had "originally" XZN in front and single hex in rear. Don't
ask why...
Martin Henning, DM5OY
martin@easy2design.de
http://log.tigerbus.de
----- Original Message -----From: Martin HenningSent: Sunday, October 11, 2009 2:00 PMSubject: Re: [Syncro_T3_Australia] Rear Diff Lock cause damage?Hiya,
Ciao,
Martin
ask why...
martin@easy2design. de
http://log.tigerbus .de
You probably have us Aussies intrigued.
What exactly is the plan of attack and process and result for quote:
Date: Sun, 11 Oct 2009 14:42:29 -0700
----- Original Message -----From: Martin HenningSent: Sunday, October 11, 2009 2:00 PMSubject: Re: [Syncro_T3_Australi a] Rear Diff Lock cause damage?Hiya,
Ciao,
Martin
ask why...
Let us find your next place for you! Need a place to rent, buy or share?
bolt, try this. Get a "GOOD" XZN bit (mine's a Hazet), put it on the end
of an old socket extension, and hammer the bit into the socket of the
stripped bolt. You only usually need 3 or 4 mm to get a good grip on the
bolt, and the hammering helps to loosen the thread's grip on the flange.
I've done this a few dozen times, never fails.
Larry Hamm
'82 SyncroWesty
Scott Daniel - Turbovans wrote:
> I get it now,
> in Aussie speak you guys are talking about the CV joint securing
> screws, yes ?
Scott,
There is always a problem with the mixed usage of propriety names and descriptive names. “Allen” and “Torx” are propriety names. “Allen screw” is in very widespread use around the world and understandably so. The descriptive is “hexagonal socket head” and is now more common in catalogues than “Allen”. Using “12 point” socket head as a descriptor makes a lot of sense.
But that is a side issue. Thanks for pointing out the workshop savvy process of applying sharp impacts to break the intimate bond between the screw and what it is screwed into. This works extremely well and is common workshop practice. They key to making this work is, as you say, that the impacts must be sharp impacts.
The hammer and cold chisel process sound a bit alarming!
On Behalf Of Scott Daniel -
Turbovans
Sent: 12 October 2009 08:42
I get it now,
in Aussie speak you guys are talking about the CV joint securing screws, yes ?
I, or we, in the US call the 6-sided ones........ ......'6 mm allen screws'.
the later ones we or at least, I, call 12 point ones.' Not an allen , and not a torx. I call them ' 12 point 'star' types.
For sure, the later 12 point ones are made out of tougher material.
it is very easy to strip out the 6 mm allen screw ones.
Of hundreds of 12 point ones I've removed , I've only ever seen one strip out.
They are deffenitely harder materail.
I have my various tricks for these screws, as does everyone else likely.
some of my tips -
dig out the crude with a small screw driver.
spray penetrating oil in there, to help disolve the crud so it can wash out.
very important - before even attempting to unscrew one, give it a very sharp WHACK with a hammer and good size drift.
or 5 sharp whacks, not 'heavy thuds' .....but very sharp whacks.
If a screw doesn't start to unscrew, and feels like it will strip out where the tool goes into it, give it 10 more sharp whacks.
Sometimes is they won't unscrew, you can try tightenting them a bit first....... .that can help sometimes.
and there is unscrewing one with a hammer and cold chisel. That works really well.
On the outbaord ones in the trailing arms, if I have to use this mehtod on one of those ........I have a cold chisel about 14 inches long that will reach in there.
what fun these beasts are !
On Saturday 24 October, the VW Club of Victoria is holding its Geelong Waterfront morning between 9AM and midday.
This is a casual event, just an annual gathering of VWs on the Geelong waterfront. I will be going down and all Syncro owners are welcome to come along. I don’t have any details of the precise meeting point but Brian might be able to provide details.
Hi Les,
I’m still away up north, but people should find details on the VWCV website, or if not, Doc, who is organising it, has also posted on the Kombi Club site here; http://forums.kombiclub.com/showthread.php?t=24394 Note, there is also the possibility of a cruise down the GOR after the display, and return to Torquay for an overnight camp.
I should be back by then, so I’ll see you there, along with some others, I hope.
I spoke to Hart again today, and he reckons there may be as many as 7 vans (not all Syncro’s) coming from NSW for DotVW.
Brian.
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Les Harris
Sent: Tuesday, 13 October 2009 8:49 PM
Subject: [Syncro_T3_Australia] GEELONG WATERFRONT - VICTORIA
Internal
Virus Database is out of date.
Checked by AVG - www.avg.com
Version: 8.5.421 / Virus Database: 270.14.7/2421 - Release Date: 10/07/09
20:49:00
Brian,
Thanks for that.
The directions are:
“north down Yarra Street , turn left at waters edge”
Looking at Melway, this would translate into travel north along Yarra Street to the intersection with Eastern Beach (no, it doesn’t have ‘road’ or ‘street’ attached to the name) and turn left. Since the “north down Yarra Street” brings you through the heart of the Geelong business/shopping centre, it might be smarter to get off the highway at Mercer, turn left anywhere to get to the waterfront, then drive around from there.
Re the DOTVW, how much space do we have allocated?
On Behalf Of Brian Reed
Sent: 15 October 2009 20:52
VICTORIA
Hi Les,
I’m still away up north, but people should find details on the VWCV website, or if not, Doc, who is organising it, has also posted on the Kombi Club site here; http://forums. kombiclub. com/showthread. php?t=24394 Note, there is also the possibility of a cruise down the GOR after the display, and return to Torquay for an overnight camp.
Brian.
[mailto: Syncro_ T3_Australia@ yahoogroups. com ]
On Behalf Of
Les Harris
8:49 PM
Subject: [Syncro_T3_Australi a]
VICTORIA
Internal
20:49:00
----- Original Message -----From: Brian ReedSent: Thursday, October 15, 2009 8:52 PMSubject: RE: [Syncro_T3_Australia] GEELONG WATERFRONT - VICTORIA
Hi Les,
Im still away up north, but people should find details on the VWCV website, or if not, Doc, who is organising it, has also posted on the Kombi Club site here; http://forums. kombiclub. com/showthread. php?t=24394 Note, there is also the possibility of a cruise down the GOR after the display, and return to Torquay for an overnight camp.
I should be back by then, so Ill see you there, along with some others, I hope.
I spoke to Hart again today, and he reckons there may be as many as 7 vans (not all Syncros) coming from NSW for DotVW.
Brian.
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_ T3_Australia@ yahoogroups. com] On Behalf Of Les Harris
Subject: [Syncro_T3_Australi a] GEELONG WATERFRONT - VICTORIA
This is a casual event, just an annual gathering of VWs on the Geelong waterfront. I will be going down and all Syncro owners are welcome to come along. I dont have any details of the precise meeting point but Brian might be able to provide details.
Internal Virus Database is out of date.
Version: 8.5.421 / Virus Database: 270.14.7/2421 - Release Date: 10/07/09 20:49:00
Version: 8.5.421 / Virus Database: 270.14.17/2436 - Release Date: 10/14/09 18:32:00
Hi Les,
Space and position should be the same as last year, but I, and possibly others, will be parked separately, in the 60 year cavalcade.
Brian
Sent: Thursday, 15 October 2009 9:47 PM
Brian,
Thanks for that.
The directions are:
“north down Yarra Street, turn left at waters edge”
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Brian Reed
Hi Les,
Brian.
20:49:00
Internal
20:49:00
Hi Scott,
Thanks for your concern. Yes the T5 is fixed (about 1000km under the belt now, starting to feel confident of it again). Been further north, then back to Port McQ. last night, and a day/night at Old Bar again today (didn’t feel like I’d seen much of it during the festival). Tomorrow I’ll catch up with Paul N (from the Cape trip) in Newcastle, then on towards home. Then 2 VWCV weekends (Geelong and Swan Hill) before DotVW. Don’t know how I ever used to fit in full time work.
Brian
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Mr Scott
Pitcher
Sent: Thursday, 15 October 2009 9:58 PM
Subject: Re: [Syncro_T3_Australia] GEELONG WATERFRONT - VICTORIA
Brian,
Is the T5 4 Motion all back to health again or are you still in Port Macquarie?
Beware my outlaws live there.
----- Original Message -----From: Brian ReedSent: Friday, October 16, 2009 7:55 PMSubject: RE: [Syncro_T3_Australia] GEELONG WATERFRONT - VICTORIA
Hi Scott,
Thanks for your concern. Yes the T5 is fixed (about 1000km under the belt now, starting to feel confident of it again). Been further north, then back to Port McQ. last night, and a day/night at Old Bar again today (didnt feel like Id seen much of it during the festival). Tomorrow Ill catch up with Paul N (from the Cape trip) in Newcastle, then on towards home. Then 2 VWCV weekends (Geelong and Swan Hill) before DotVW. Dont know how I ever used to fit in full time work.
Brian
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_ T3_Australia@ yahoogroups. com] On Behalf Of Mr Scott Pitcher
Subject: Re: [Syncro_T3_Australi a] GEELONG WATERFRONT - VICTORIA
Brian,
Version: 8.5.421 / Virus Database: 270.14.19/2438 - Release Date: 10/15/09 12:02:00
Brian,
You and I need to do some planning at Geelong . We might have more Syncros than space available for the DOTVW.
Sent: 16 October 2009 19:45
DotVW space allocation
Hi Les,
Brian
WE have four weeks to the Day of the Volkswagen in Victoria , this year celebrating the 60th anniversary of the Kombi, at the Cranbourne Racecourse.
So far we have the following confirmed attendees:
· Mark Kofahl
· Hartmut Kiehn
· Francesca Coles
· Gary Cookson
· Les Harris
· Michael Roberts
· Theo Weiss
We need to know NOW who is coming so that we can plan how to use our allocated space. The last thing we want is to have members scattered around the place.
We also need to know NOW who wants to overnight at Tooradin so that we can get a booking.
----- Original Message -----From: Les HarrisSent: Saturday, October 17, 2009 10:39 AMSubject: [Syncro_T3_Australia] DAY of the VOLKSWAGEN - VICTORIA
· Mark Kofahl
· Hartmut Kiehn
· Francesca Coles
· Gary Cookson
· Les Harris
· Michael Roberts
· Theo Weiss
Version: 8.5.422 / Virus Database: 270.14.20/2441 - Release Date: 10/16/09 18:39:00
Andy,
Bring it along and we will see how much space we have on the day. It will depend on how many Syncros we get.
On Behalf Of Andy Sinclair
Sent: 17 October 2009 19:15
Hi Les and all,
My Syncro is still off the road but I will definately be there hopefully in a 91 Single cab ute (non syncro) which Im presently restoring as my work vehicle. I have never seen one of these at the DOTVW so should be another rarity for the day. Would you mind me lining up with you guys?
Cheers, Andy Sinclair.
Can you please include David and Kahrina for staying on Sat night.
They are v good friends of Hart and I met them at Old Bar. They have
just bought their first Kombi (a camper) and will travel down from
Port Macquarie with Hart and then us from Camden.
On Saturday, October 17, 2009, Les Harris <leslieharris@optusnet.com.au> wrote:
> Volkswagen in Victoria,
> Mark
> Kofahl
> Hartmut
> Kiehn
> Francesca
> Coles
> Gary
> Cookson
> Les Harris
> Michael
> Roberts
> Theo
> Weiss
>can you tell me the cost of a cabin per night at the caravan park and a schedule of events at the meeting i am hoping to get time to attend
> Hi Les
> Mark
> > Mark
> > Kofahl
> > Hartmut
> > Kiehn
> > Francesca
> > Coles
> > Gary
> > Cookson
> > Les Harris
> > Michael
> > Roberts
> > Theo
> > Weiss
> > Les
> >gday les
regards bob dale
Bob,
As a first move, get in touch with Mark Kofahl. There are a number of NSW members coming down and it would make sense to travel together. Mark is organizing that at the NSW end.
In the meanwhile, I will check the Tooradin caravan park to see if they have cabins and get back to you.
On Behalf Of robertdale1945
Sent: 20 October 2009 10:46
gday les
regards bob dale
_,___
----- Original Message -----From: Mark KofahlSent: Saturday, October 17, 2009 9:43 PMSubject: Re: [Syncro_T3_Australia] DAY of the VOLKSWAGEN - VICTORIAHi Les
On Saturday, October 17, 2009, Les Harris <leslieharris@ optusnet. com.au> wrote:
>gday marki would like to know your convoys travel schedule to melbourne as i am going to try to attend if possible and it would be good to join tagalong tours.
regards
robert dale
> Mark
> Kofahl
> Hartmut
> Kiehn
> Francesca
> Coles
> Gary
> Cookson
> Les Harris
> Michael
> Roberts
> Theo
> Weiss
