It seems like you never get to see snowy and icy roads over there :))
I changed back to an extra stiff VC to be able keeping the decoupler
enganged in winter, when roads constantly change from tar to ice to
mud to snow and whatever else. "Best modification I ever..." harhar :)
I guess for a trip to Africa I might throw in that solid shaft again -
for every day use: NO WAY!
.martin
On 10.07.2009, at 04:11, hamish dobson wrote:
> For me i installed a decoupler and i pulled appart my VC which was
> slipping and usless, cleaned out the silicon fluid and washed the
> clutch packs and filled it full of fiberglass resin to lock it up
> and re fitted it
> Its been in there for 10 years now and appart from fitting the
> esikel springs it is on par with being the best modification i ever
> did - in particular if you go off road whether it be dirt or sand.
> When on the tar you completly unload the front end by disengauging
> it which is a good thing in australia.
> From: "
plander@optusnet.com.au" <
plander@optusnet.com.au>
> To:
Syncro_T3_Australia @yahoogroups. com> Sent: Friday, 10 July, 2009 7:06:39 AM
> Subject: Re: RE: [Syncro_T3_Australi a] Re: Solid Shaft
> Each system has their place.
> With VC
> On road safety and handling
> Able to use G and Reverse gear without strain on the gears.
> With solid shaft
> Better off road with 100% power to all wheels
> Driver is in control
> Simple and
reliable
> Whatever suits your needs!
> > Ken Garratt <unclekenz@hotmail. com> wrote:
> > Gday Erik,
> > Concerning VC v Solid Shaft alternatives, clearly each of us have
> our
> > own and varying priorities when it comes to how and where we drive
> our
> > syncros, which determines how we configure them. Obviously what
> suits
> > Les doesn't gel with my needs nor I suspect, yours.
> > Opting for a solid shaft is the best change I have made in my
> syncro,
> > for many reasons.
> > Anyone wanting to argue the toss against solid shafts, feel free to
> > raise the topic with Rudi. Good luck is all I can say.
> > To: Syncro_T3_Australia @yahoogroups. com
> > From: erikhoeflinger@
hotmail.com> > Date: Thu, 9 Jul 2009 07:29:10 +0000
> > Subject: [Syncro_T3_Australi a] Re: Solid Shaft
> > Cheers for the input les. I understand you can no longer drive in
> 4wd on
> > the road as with the vc but that does not only go for the syncro.
> Never
> > had a problem disengaging the system in past 4wds and it's not too
> > difficult to feel the drive difference from 2wd/4wd if it were
> > accidentally left engaged for a second.. I guess that depends on
> easily
> > drive train
damage occrus on a syncro?
> > My offroad driving is made up largely of sand as I often plan
> > fishing/surfing trips along the coast. I understand the syncro's
> with
> > solid shafts seen performing at syncro de-mayo were more sure-footed
> > than those running a vc in the more extreme offroad conditions.
> > Seeing as solid shafts are relatively cheap I don't see a good
> reason
> > why i shouldn't buy one and test it myself. Be happy to hear some
> more
> > opinions from people who are running them though.
> > Has anyone ever considered free wheeling hubs on a syncro?
> > > -----Original Message-----
> > > From: Syncro_T3_Australia @yahoogroups. com
[mailto:Syncro_ T3_Australia @yahoogroups. com] On Behalf Of Les
> Harris
> > > Sent: Thursday, 9 July 2009 3:38 PM
> > > Subject: [Syncro_T3_Australi a] Solid Shaft
> > > I posted a reply to Erik's message many hours ago but it appears
> to
> > have
> > > been munched up by the Yahoo server - again!
> > > A solid shaft is suitable for sand AND ONLY FOR SAND.
> > > A Syncro fitted with a solid shaft cannot be driven on any other
> > surface
> > > without imposing an intolerable load on the gearbox and will
> result in
> > > premature (and horribly expensive) gearbox
failure.
> > > It also means that the vehicle can be driven only in 2WD on all
> other
> > > surfaces, thus losing the many significant advantages of the
> native
> > Syncro
> > > drive system.
> > > Les
> > ____________ _________ _________ _________ _________ _________ _
> > Looking for a new car this winter? Let us help with car news,
> reviews
> > and more
http://a.ninemsn.
com.au/b. aspx?URL= http%3A%2F% 2Fsecure% 2Dau
> %2Eimrworldw id
> > e%2Ecom%2Fcgi% 2Dbin%2Fa% 2Fci%5F450304% 2Fet%5F2% 2Fcg%5F801459%
> 2Fpi%5F10048
13%2Fai%5F859641& _t=762955845& _r=tig_OCT07& _m=EXT
> Access Yahoo!7 Mail on your mobile. Anytime. Anywhere. Show me how.
Martin Henning, DM5OY
martin@easy2design. dehttp://log.tigerbus .de
