Starter Motor Faulty
Hi Les, disagree,
Having the st/motor on the test bench it ran beautifully stop/start—stop/start – when I put it back in it worked.........once....... I had it out 3 times . In the end I inspected the armature and discovered hairline cracks in the connection between commutator (pls help, took the word from german) and armature windings. My auto electrician (lives next door) said it was a rather common occurrence.
To see the cracks it helps to use a magnifier . This might not be wrong with Dave’s starter but believe me, if the starter is out I would check this item too.
Hartmut
Sent: Sunday, 15 January 2012 11:51 AM
Subject: RE: [Syncro_T3_Australia] Re: Starter Motor Faulty
David,
Intermittent starter function is almost always a result of bad electrical contacts, either in the starter switch or along the way to the solenoid.  When I pulled mine out and bench tested it, it ran perfectly, this confirming that it was in the wiring, not the starter or the solenoid.  Starter/solenoids can fail, of course, but never in the intermittent mode.  If it doesn’t run on the bench, then the problem is internal to the starter/solenoid.
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of David
Sent: 15 January 2012 11:38
Subject: [Syncro_T3_Australia] Re: Starter Motor Faulty
Thanks Les,
Ill check the ignition switch out first but I have the gut feeling the starter motor is at fault. Auto Electrician visit tomorrow on the to do list. Thanks for the excellent advice
Dave
_,_._,___
How do you run it out of the car as it doesn,t have a bearing at the business end?
> Hartmut Kiehn <hartis@live.com.au> wrote:
> Hi Les, disagree,
> stop/start-stop/start - when I put it back in it
> discovered
> with
> Dave's starter but believe me, if the starter is out I would check this
> item
> too.
> Hartmut
> David,
> electrical
> mode.
> If it doesn't run on the bench, then the problem is internal to the
> starter/solenoid.
> Thanks Les,
> Dave
> _,_._,___
Out of the thousands of DC motors that I have serviced, I have never seen a problem with a hairline crack in the comutator. Then again 1500 volts DC doesn't worry about cracks. ;)
> > Hi Les, disagree,
> > discovered
> next
> wrong
> > with
> this
> > item
> > too.
> > Hartmut
Made up a simple jig, few pieces of form ply, works a treat. Helps having been a farmer for a fair few years.....Ha
Sent: Sunday, 15 January 2012 12:15 PM
Subject: Re: RE: [Syncro_T3_Australia] Re: Starter Motor Faulty
> Hi Les, disagree,
> discovered
> with
> item
> too.
> Hartmut
> David,
> electrical
> mode.
> starter/solenoid.
> Thanks Les,
> Dave
> _,_._,___
Phill, my whiteboard has the caption : Next time Phill/Joanne show up for coffee, show him the Bosch armature...   Ha.
Sent: Sunday, 15 January 2012 12:20 PM
Subject: Re: Re: RE: [Syncro_T3_Australia] Re: Starter Motor Faulty
> > Hi Les, disagree,
> > discovered
> next
> wrong
> > with
> this
> > item
> > too.
> > Hartmut
Hartmut,
Point taken.
Sent: 15 January 2012 12:10
Hi Les, disagree, Having the st/motor on the test bench it ran beautifully stop/start—stop/start – when I put it back in it worked.........once....... I had it out 3 times . In the end I inspected the armature and discovered hairline cracks in the connection between commutator (pls help, took the word from german) and armature windings. My auto electrician (lives next door) said it was a rather common occurrence. To see the cracks it helps to use a magnifier . This might not be wrong with Dave’s starter but believe me, if the starter is out I would check this item too.
Hartmut
Hi Dave, the sensor you mention is very often overlooked. For months on end I had those problem with the Tristar , when I rang Steve Muller he said , Hardee it sounds like the temp sensor to me ...He put one in the mail, it never gave any problems since. I do carry a spare also. Ha.
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Robert Dale
Sent: Sunday, 15 January 2012 11:59 AM
Subject: RE: Re: [Syncro_T3_Australia] Starter Motor Faulty
Dave
If your motor sounds like it has full choke applied regarding the rough
running it can be caused by the temperature sensor that interfaces with the
emc unit the resistant values change with the sensed heat which then tells
the emc unit what air/fuel mix is required, if the unit goes us the problems
start
bob
Sent: Sunday, 15 January 2012 10:11 AM
Subject: Re: Re: [Syncro_T3_Australia] Starter Motor Faulty
Shouldn't matter. Fuel injected.
> Greg esposito <gregespo73@yahoo.com> wrote:
> How did you turn it off. Timing to far advanced?
> From: greg esposito <gregespo73@yahoo.com>
> To: "Syncro_T3_Australia@yahoogroups.com"
> <Syncro_T3_Australia@yahoogroups.com>
> Sent: Sunday, 15 January 2012 10:06 AM
> Subject: Re: [Syncro_T3_Australia] Starter Motor Faulty
> ÂÂ
> Ignition switch for starters. Pardon the pun. Greg E
> From: David <davidleibmann@yahoo.com.au>
> Sent: Sunday, 15 January 2012 9:30 AM
> Subject: [Syncro_T3_Australia] Starter Motor Faulty
> ÂÂ
> Hi All,
> Went for a great drive to Diamond Beach, great beach, camping ground,
> nature, etc. On leaving engine wont start. Battery good, clicking
> sounds around motor when ignition turned on. Push jump started easily.
> I think this points to faulty stater motor or solonoid. Anyone had to
> replace/ recondition their Syncro stater motor? I tried taping starter
> with a shifter, checked all wiring however not sure if there is wiring
> on the starter motor I should check.
> Also unable to stop motor on way home and motor developed a miss what
> I believe is known as Vanagon Syndrome. I still love my Syncro. Any
> tips Cheers Dave
Yahoo! Groups Links
Bob,
Where does this sensor read from?
Dave
start
bob
_,___
Les,  you find it also in Bentley  19.11  Ha.
Sent: Sunday, 15 January 2012 12:46 PM
Bob,
Dave
start
bob
_,___
Hartmut,
I was looking in the wrong place!  Thanks.
Sent: 15 January 2012 12:59
_,_._,___
Hi Hatmut,
What was the price for the modified air flow sensor?
Dave
> Dave
> start
> bob
> <mailto:Syncro_T3_Australia%40yahoogroups.com>
> <mailto:Syncro_T3_Australia%40yahoogroups.com> ] On Behalf Of
> plander@... <mailto:plander%40optusnet.com.au>
> > Greg esposito <gregespo73@... <mailto:gregespo73%40yahoo.com> >
> > From: greg esposito <gregespo73@... <mailto:gregespo73%40yahoo.com>
> <mailto:Syncro_T3_Australia%40yahoogroups.com> "
> <mailto:Syncro_T3_Australia%40yahoogroups.com> >
> > ÂÂ
> > From: David <davidleibmann@...
> <mailto:davidleibmann%40yahoo.com.au> >
> > ÂÂ
> > Hi All,
> > tips Cheers Dave
you're right..
the starter will run without support from a front bushing..
but it's not good for it.
Ideally ..run it in another bell housing, with bushing,  or section of said bell housing.
Sent: Saturday, January 14, 2012 5:15 PM
> Hi Les, disagree,
> discovered
> with
> item
> too.
> Hartmut
> David,
> electrical
> mode.
> starter/solenoid.
> Thanks Les,
> Dave
> _,_._,___
Dave, can’t really remember it’s too long ago, maybe $ +- 50.00 Hart
Sent: Sunday, 15 January 2012 1:12 PM
Hi Hatmut,
Dave
> Dave
> start
> bob
> > ÂÂ
> > ÂÂ
> > Hi All,
> > tips Cheers Dave
Hi Hartmut,
Sorry about my bad spelling. Yes we decided to head home yesterday to Coffs. Where do you live? We will definitely be heading down to Crowdy Bay NP again, matbe Easter. Do you know where I can buy a Vanagon Syndrome cable from? Many thanks for the offer to help out.
Dave
> Dave are you gone home ? I do have a switch (you should have a spare too)
> AND I do have a Vanagon Syndrome cable for you to test or borrow until you
> can find one. At the time it helped Francesca.
> Hartmut ( with a "r" it's what my ASUS l/top doesn't like to activate ,
> wouldn't recommend that brand )
> Sent: Sunday, 15 January 2012 10:47 AM
> Hi Hartmut
> It was Diamond Beach on the Mid N/C. Indian Head, Kylies all magical spots
> to take the Syncro. Unfortunately I don't have a spare ignition switch.
> Dave
> <mailto:Syncro_T3_Australia%40yahoogroups.com> , "Hartmut Kiehn"
> <hartis@> wrote:
> > Hi Dave , if it is not the ign switch or the connections at the starter,
> > from experience I can only suggeset to take the starter out and have it
> > overhauled or if you do it yourself, fit a new solenoid and check the
> > armature very carefully especially the brushes touch on (is it called
> > commutator Phill ?) check the solder of the copper bits with a 1in 10
> > magnifier for hairline cracks. I can show you 2 which look perfect and
> > that's why I re installed them , only to learn the hard way that both are
> > riddled with cracks in the solder.
> > Diamond Beach ? the one at the Mid North Coast ? You could have visited.
> > Hatmut
> <mailto:Syncro_T3_Australia%40yahoogroups.com> ] On Behalf Of David
> > Sent: Sunday, 15 January 2012 9:31 AM
> > Hi All,
> > nature, etc. On leaving engine wont start. Battery good, clicking sounds
> > around motor when ignition turned on. Push jump started easily. I think
> this
> > points to faulty stater motor or solonoid. Anyone had to replace/
> > recondition their Syncro stater motor? I tried taping starter with a
> > shifter, checked all wiring however not sure if there is wiring on the
> > Also unable to stop motor on way home and motor developed a miss what I
> > believe is known as Vanagon Syndrome. I still love my Syncro. Any tips
> > Cheers Dave
Give Steve Muller a call at Kombi Rescue.
> David <davidleibmann@yahoo.com.au> wrote:
> Hi Hartmut,
> Dave
> too)
> until you
> > Hi Hartmut
> spots
> switch.
> > Dave
> starter,
> it
> called
> 10
> and
> both are
> visited.
> > > Hatmut
> > > Hi All,
> ground,
> sounds
> think
> > this
> what I
> tips
> > > Cheers Dave
Dave,  when coming from North you x the Hastings River, turn left into Hastings River Drive Go 400m turn left into Oakes crescent to the end through the gate towards the shed   and that’s where we are hiding.
Cable, it’s like Phill has described it. It can fix itself. You could ask BenT to look out for one or watch eBay in the US in the meantime you can try mine if you like. I would need you postal. Up to you.
And don’t bother about my name, my fault, I have about 6 different ones, don’t care a hoot what I’m called. When I give my name over the phone, people say  Oh, Hardwood, What an unusual name !
I leave it at that........ Hartis, Hardee, Hatti, Hartmut, Hardwood or whatever
Sent: Sunday, 15 January 2012 6:11 PM
Hi Hartmut,
Dave
> Hi Hartmut
> Dave
> > Hatmut
> > Hi All,
> this
> > Cheers Dave
Steve’s ph #  0400 356 057
Sent: Sunday, 15 January 2012 6:23 PM
Subject: Re: [Syncro_T3_Australia] Re: Starter Motor Faulty
> Hi Hartmut,
> Dave
> too)
> until you
> > Hi Hartmut
> spots
> switch.
> > Dave
> starter,
> it
> called
> 10
> and
> both are
> visited.
> > > Hatmut
> > > Hi All,
> ground,
> sounds
> think
> > this
> what I
> tips
> > > Cheers Dave
How about Hard Nut?
Sent: 15 January 2012 19:38
_._,___
Xzellent ! Let’s write it Hardnut, thanks Les.
Sent: Sunday, 15 January 2012 8:03 PM
How about Hard Nut?
_._,___
Only kidding!  I have always used your full name.
Sent: 15 January 2012 20:06
