suspension lift
Hi,
I'm new to the group. I run an 89 syncro with a few mods. Camper fitout, large brakes,15'' wheels
de coupler and a lot of fun. Can anyone advise on the problems of raised suspension ?
I recently fitted springs giving about 45mm lift but now experience a heavy knock when the front suspension tops out ( ie dropping into a pothole ) OME shocks fitted front.
Regards,
Make the switch to the world's best email. Get Yahoo!7 Mail.
mate, sounds like the assembly is wrong.
i have esikel springs and i just fitted my 2nd OME struts after 35K km of hard 4wd
and ive never experrienced a problem like you speak of
----- Original Message ----
Sent: Tuesday, 9 September, 2008 1:59:06 PM
Subject: [Syncro_T3_Australia] suspension lift
Hi,
Regards,
Sounds a bit like dodgy springs to me, can you confirm the springs you
fitted are designed/manufactured/approved for a syncro?
--- In Syncro_T3_Australia@yahoogroups.com, hamish dobson
of hard 4wd
> From: mark hallett m.mullet@...
> Hi,
raised suspension ?
> Regards,
> Mark
> Make the switch to the world's best email. Get Yahoo!7 Mail!
http://au.yahoo.com/y7mail
springs are definitely syncro spec from gowesty in usa. bought them
when the exchange rate was good. they say many have been fitted
without problems. Could it be my shocks were rooted but not obvious
until new springs were fitted ? 40,000 k's with some rough stuff
included ?
km of hard 4wd
> From: mark hallett <m.mullet@...>
> Hi,
raised suspension ?
> Regards,
> Mark
Mail! http://au.yahoo.com/y7mail
Gday Mark,
Interesting dilemma then eh. Just from memory, I don't recall Oz syncro
owners discussing here about spring mods, but they have talked about
shocks.
Reading up on the mod springs at the GoWesty site, they appear to have
made a big effort to get it right, especially sourcing from a German
manufacturer.
You would need to satisfy in your own mind whether or not there are any
other mods done or worn components in your syncro that may play some
part as well in this issue.
In answer to your comment, I would have thought, when shocks are shot,
regardless of new or old springs, you can usually tell by the way the
vehicle behaves badly, especially over bumps and offroad. So if it
wasn't a problem when you had the old springs in, then by deduction,
brings into question the performance matching of your new springs and
the existing OME shocks. At least verify that.
--- In Syncro_T3_Australia@yahoogroups.com, "m.mullet" <m.mullet@...>
> included ?
> km of hard 4wd
> > Hi,
> raised suspension ?
> > Regards,
> > Mark
Gday Ken,
yeah it's a bit tricky to decide to spend the bucks on the new shocks
only to discover that wasn't it. By rocking the vehicle as hard as I
can the front doesn't seem as firm as the back. But otherwise it
handles fine. Except for the issue mentioned. Go westy have never had
an issue like this - or so they keep saying.
By the way I'm in Perth.
> Gday Mark,
> shocks.
> manufacturer.
> --- In Syncro_T3_Australia@yahoogroups.com, "m.mullet" <m.mullet@>
> > included ?
> > km of hard 4wd
> > > Hi,
> > raised suspension ?
> > > Regards,
> > > Mark
The suspension will top out if you have lifted it by 45mm , i fitted a 10 mm spacer under the front springs and it now tops out on heavy rebound ,it needs longer shockers.
regards
Alf
Sent: Tuesday, 9 September, 2008 1:29:06 PM
Hi,
Regards,
Gday Mark,
I think Alf has just confirmed your worst fears. Unlucky the exchange
rate has fallen so far eh.
You probably would do well to also join a couple of the US Yahoo syncro
forums and glean info from members there because they are right into
suspension mods and would most likely be able to suggest a brand and
model of shocks that marry well with your mod springs. Then again,
GoWesty should be able to tell you this info.
Good luck and start saving your cents. Maybe your existing OME shocks
are still a saleable item too, to help offset the new purchase.
wrote:
> Gday Ken,
> Cheers
> Mark
> --- In Syncro_T3_Australia@yahoogroups.com, "Ken" unclekenz@ wrote:
> > Gday Mark,
syncro
> > shocks.
have
> > manufacturer.
any
shot,
the
and
> > Cheers.
them
obvious
> > > included ?
35K
> > > km of hard 4wd
> > > > Hi,
of
> > > raised suspension ?
experience
into a
> > > > Regards,
> > > > Mark
Is it really a problem?
I know that the rears clunked from new as the suspension topped out. Maybe the OMEs have a harder suspension stop. How are the condition of the shock rubbers/suspension bushes etc?
> m.mullet <m.mullet@yahoo.com.au> wrote:
> Gday Ken,
> Cheers
> Mark
On Mon, Sep 8, 2008 at 8:59 PM, mark hallett <m.mullet@yahoo.com.au> wrote:
Hi,
Regards,
Mark,
It almost sounds like you do not have the shock bolted down completely on the top bushing. Can you put the van on a lift or jackstands and try to cycle the suspension?
I have heard of people having trouble with the cheap KYB shocks when the top bushing (bushes) get damaged easily resulting in a clunk as one drives over potholes. This has happened in newly installed shocks. The fix was re-use of the stock washer and bushings. Of course, that was in 2wd. The Syncro with it's Macpherson syle strut arrangement could be likewise afflicted.
There has been news of lifted Syncros "blowing out" the tops of their rear shocks when they drop into a deep pothole. The trouble there was resolved with inexpensive suspension limiting straps. To my knowledge these occured in the custom-built rebuildable South African shocks. They are supposedly designed for lifted suspensions. It's the guys using them on stock height Syncros who had this problem.
Have not heard of anyone having problems with the GoWesty springs with OME shocks. IIRC the GoWesty is similar to the ground breaking syncro.org springs. No knocking on the suspenson there either.
Here's another possibility. Is it possible that your suspension is lifted so high that the upper control arm (a-arm) is making contact with the spring on the downward movement? Balljoint spacers or custom dropped a-arms can solve that problem.
Regards,
Gday Mark,
There is an interesting ... perhaps expensive site you should at least view concerning syncro mods, including suspension lift ...............
goto: http://burleymotorsportsdirect.com/
> Gday Mark,
> --- In Syncro_T3_Australia@yahoogroups.com, "m.mullet" m.mullet@
> wrote:
> > Gday Ken,
> > Cheers
> > Mark
> > > Gday Mark,
> syncro
> > > shocks.
> have
> > > manufacturer.
> any
> shot,
> and
> > > Cheers.
> > > Ken
> them
> obvious
> > > > included ?
> 35K
> > > > km of hard 4wd
> > > > > Hi,
> of
> > > > raised suspension ?
> experience
> into a
> > > > > Regards,
> > > > > Mark
> > > > > Make the switch to the world&#39;s best email. Get Yahoo!7
I would not feel comfortable with a vendor insists a certain part is backyard engineering when it is in competition with a part he offers. Then a couple of weeks later offer the same parts for sale. Guessing is "engineering" opinion is colored by his need to make a profit. Said example had to do with balljoint spacers which has been in use in SA and UK. Said vendor does not seem to have any patience to answer questions challenging his design. In that incidence said vendor got annoyed by forum questions regarding his custom A-arms and announced that as a consequence he will raise the price and only offer it for sale if he got paid to install the part.
I am but a couple of hundred miles away from this guy's shop. Relative to Oz, that's a skip in the puddle. I would hate to try to resolve issues with such a vendor from such a distance. In all fairness, I have heard the quality his products are decent. It's just the attitude I refuse to deal with.
YMMV,
On Tue, Sep 16, 2008 at 4:35 PM, Ken <unclekenz@yahoo.com> wrote:
Gday Mark,
Gday BenT,
Interesting observations. With just a few exceptions, Mark being one of
them, I have the view most Oz syncro owners don't get involved in these
sorts of mods anyway, so where the truth lies and the politics of it all
that you talk about is most probably like water off a ducks back for us
here. Interesting though and I'm sure we do appreciate your input here.
From 15+ hours flying time away from your shores, I think what we do
value is being aware of and having access to T3 syncro focussed websites
supporting a range of replacement parts, maintenance information and
links, virtually all of it being offshore. In the English language as
well! It reassures us our beloved transporters are not dead yet.
Having a local website T3 focussed parts supplier, setup like Van-Cafe
or GoWesty would be an unbelievable dream come true, let alone a site
specialising in syncro mods. Never ever going to happen.
But heh BenT, life in Australia .... now that IS a dream come true!
Please don't tell anyone ok.
--- In Syncro_T3_Australia@yahoogroups.com, "BenT Syncro" <syncro@...>
wrote:
> Ken,
Then a
example
challenging
questions
will
the
> part.
to
with
deal
> with.
> YMMV,
> BenT
> On Tue, Sep 16, 2008 at 4:35 PM, Ken unclekenz@... wrote:
> > Gday Mark,
least view
> > Cheers.
Hello Ken,
I haven't been to the AAA of Continents -- Africa, Antartica, and Australia. I hope to make it there one of these days.
Fifteen hours in the air is no problem for me. I once flew 17 hours to have dinner. Then flew back another 17 hours
less than 9 hours. I grew-up in one continent have adopted this one. Think about it as Oz in summer and Europe in the
winter. But the real reason I love it here is because the car is still king in California. Both Van-Cafe and GoWesty are
practically in my backyard. In fact the company which imports parts for both of those places is even closer. The builder
of the infamous SyncroMog is just a few mnutes away from that place. Talk about Syncro specialists, John Wessels is
unrivaled in California, IMHO. T3 parts funnel their way here from no less han 5 continents -- including Australia (ARB,
OME, etc.). We are lucky that way.
On Tue, Sep 16, 2008 at 8:05 PM, Ken <unclekenz@yahoo.com> wrote:
Gday BenT,
Hi All
The upper ball joint spacer is a very good idear, i have been looking for some thing like that so i can get the wheel alinment back again, after lifting front .
Alf
Sent: Wednesday, 17 September, 2008 10:13:04 AM
Subject: Re: [Syncro_T3_Australia] Re: suspension lift
I would not feel comfortable with a vendor insists a certain part is backyard engineering when it is in competition with a part he offers.. Then a couple of weeks later offer the same parts for sale. Guessing is "engineering" opinion is colored by his need to make a profit. Said example had to do with balljoint spacers which has been in use in SA and UK. Said vendor does not seem to have any patience to answer questions challenging his design. In that incidence said vendor got annoyed by forum questions regarding his custom A-arms and announced that as a consequence he will raise the price and only offer it for sale if he got paid to install the part.
YMMV,
On Tue, Sep 16, 2008 at 4:35 PM, Ken <unclekenz@yahoo. com> wrote:
Gday Mark,
There is an interesting ... perhaps expensive site you should at least view concerning syncro mods, including suspension lift ............ ...
goto: http://burleymotors portsdirect. com/
Gday BenT,
AAA continents eh. Nah, in my minds eye, I picture you as somewhat of a
visionary mover and shaker. Why hold back?
I see you bending Sir Richard Bransons arm and piggy-backing yourself
and 16" syncro on his Virgin Galactic tour of the moon. Rich will hang
about while you navigate the syncro around the outline of the bunny
rabbit, streaming video and commentary all the while of a truly
historical and unique syncro experience.
Sir Richard, I think you've met your match ..........
wrote:
> Hello Ken,
have
Think
king
for both
Talk
less
> BenT
> www.vanagoncafe.com
> On Tue, Sep 16, 2008 at 8:05 PM, Ken unclekenz@... wrote:
> > Gday BenT,
of
these
all
us
here.
websites
as
Van-Cafe
site
> > Cheers.
Hello Ken,
The moon would be a cool place to tool around in a Syncro. Afterall a VW Buggy inspired
vehicle is still out there, isn't it? Do you think Hugh Hefner will sponsor me if I promise to
do the bunny outline? Or maybe VW? Nah...
We speak eYou call your money is called a dollar.
On Thu, Sep 18, 2008 at 12:58 AM, Ken <unclekenz@yahoo.com> wrote:
Gday BenT,
wrote:
> Hello Ken,
have
Think
king
for both
Talk
less
> BenT
> www.vanagoncafe.com
> > Gday BenT,
of
these
all
us
here.
websites
as
Van-Cafe
site
> > Cheers.
Gee, how did that get there? Sorry folks. That's what happens when you try to type two different emails at the same time.
Damned cut & paste finger slipped again.
Hi Alf,
The bushing spacers has been available for some time from SA and European Syncro parst vendors. Most recently, some have experimented with adding and angle on the spacer to correct the geometry even better. The jury is still out on that one though.
I do understand that custom A-arms with dropped balljoint seats as pioneered on T3 Syncros by John Wessels on the infamous
SyncroMog. (BTW, SyncroMog is currently for sale). It's just they are too expensive for most people. Besides the majority of Syncro owners are not likely modifying their
suspension to the point where such a devise is necessary.
Stuart on the SyncroSA Yahoo Forum was offering balljoint spacers not too long ago. IIRC, Simon Baxter at the Brickworks in the
UK had these before too. I would try Russel at syncronutz also in the UK as well.
Regards,
On Wed, Sep 17, 2008 at 3:38 AM, alf ando <dansk53bus@yahoo.com.au> wrote:
Hi All
Alf
YMMV,
Gday Mark,
Hi BenT
Thank you very much for that information.
Alf
To: Syncro_T3_Australia@yahoogroups.com; dansk53bus@yahoo.com.au
Sent: Thursday, 18 September, 2008 6:34:06 PM
Hi Alf,
Regards,
On Wed, Sep 17, 2008 at 3:38 AM, alf ando <dansk53bus@yahoo. com.au> wrote:
Hi All
Alf
Subject: Re: [Syncro_T3_Australi a] Re: suspension lift
YMMV,
Gday Mark,
