Hello all,I would like to improve the ride height and suspension of my bus.
Is any one using aftermarket springs,where are they from,what do you think of them?
Anyone have any experience with GoWestys 2inch progressive springs?(BenT or Turbovans)
I am using old man emu shocks now,what shocks do people recomend with taller springs.
Its only early days of research on this topic for me,any comments or links would be appreciated.
BenC
Hi Ben,
I run GW springs and OME shocks on a converted and fairly light camper.
I don't mind the ride at all, although I may drop tyre pressure when not fully loaded. Front shocks top out fairly easily. If you come up with some extenders let me know.
Otherwise you may find you eat a few more cv's, especially the rear.
Overall not a bad setup. If I had my time again I would probably stay with standard suspension and run 225/175/15 tyres as a cheaper way to
get more clearance.
Only downside there is increased gearing.
Hi,
I have 215/70 BFG All Terrain tyres on 16" rims.
The front tyres scrub a little only on suspension compression, on the left side when turning left and on the right side when turning right.
There are no other scrubbing issues with this (otherwise standard suspension) set up.
Andy.
