I didnt know about your raised suspension,better have a better look next time.(what weekend is old bar?)
Like BenT suggested I think the width of your tyres would have something to do with your scrubbing.
Since I do most of my off-roading on sand,I prefer a slightly narrower tyre,but I was hoping to go up to a 75 series tyre next time.
Still would like to get a little higher though,may have to BenCh test some of those front spacers.(very clever BenT,for someone who lives on 2 hours sleep!)
BenC
--- In Syncro_T3_Australia@yahoogroups.com, Scott Pitcher <spbconsulting@...> wrote:
> Ben,
> As you know, my suspension was raised about 10 years ago by Proven
> Products in Sydney West. But I'm not sure if they are still around. They
> did coil over shocks on the front with an adjustable spring base.
> The rears are re-sent original springs and have lasted well on what has
> been a similar set up to yours interior-wise - ie just a rear bed seat
> and a slightly heavier 6 cyl suby donk. I have 235 x 75 x 15 inch wheels
> and they only minor rub on the plastic flare on the drivers side on
> almost full lock turning right. Nothing else rubs but everything is close.
> I think if you went bigger springs and wanted bigger tyres you would
> need to cut the guards.
> Your existing tyres scrub the same as mine I think and in the same
> single spot.
> Skot
> On 25/07/2011 6:23 PM, Ben wrote:
> > Mark,thanks for your report.My bus is not a camper,so right now am
> > looking at other options to get a bit more height.
> > Re shock extenders,I found a few manufactuers by google and having a read
> > http://www.jcwhitney.com/shocks-and-struts/volkswagen-vanagon/c12548d14387j1s21.jcwx
> > is one.
> > I have 16 inch rims so I think 75 series tyres are out of the question
> > without raising the suspension.
> > I would like to hear from anyone running 16 inch rims with large
> > tyres,to know if there is any scrubbing issues.
> > Thanks
> > BenC
> > <mailto:Syncro_T3_Australia%40yahoogroups.com>, "m.mullet"
> > <m.mullet@> wrote:
> > > Hi Ben,
> > > I run GW springs and OME shocks on a converted and fairly light camper.
> > > I don't mind the ride at all, although I may drop tyre pressure when
> > not fully loaded. Front shocks top out fairly easily. If you come up
> > with some extenders let me know.
> > > Otherwise you may find you eat a few more cv's, especially the rear.
> > > Overall not a bad setup. If I had my time again I would probably
> > stay with standard suspension and run 225/175/15 tyres as a cheaper way to
> > > get more clearance.
> > > Only downside there is increased gearing.
> > > Cheers,
> > > Mark
