----- Original Message -----From: BenSent: Monday, July 25, 2011 3:03 AMSubject: [Syncro_T3_Australia] Re: suspension upgradesHi Andy, I run 215/65/16 and have no scrubbing issues.
Thats amazing how that extra 5mm can be the difference.
Is there any tyre damage or any damage to the vehicle from this scrubbing?
BenC
--- In Syncro_T3_Australia@yahoogroups.com, Ruth Phillips <rafear@...> wrote:
> Hi,
> I have 215/70 BFG All Terrain tyres on 16" rims.
> The front tyres scrub a little only on suspension compression, on the left side when turning left and on the right side when turning right.
> There are no other scrubbing issues with this (otherwise standard suspension) set up.
> Andy.
----- Original Message -----From: BenSent: Monday, July 25, 2011 11:06 PMSubject: [Syncro_T3_Australia] Re: suspension upgradesGreg,thanks for all of that.
I will measure that clearance next I am under the bus.
I dont run spacers,could if needed.
There is a few spring manufacturers up here,will sus them out.
BenC
> Ben, standard rubber OEÂ castor bushes(jk) and stainless sleeves(go w).
> Spacer goes between top control arm and ball joint(go w).
> Porsche cv's are too expensive for my wallet. If you stay under 52cm hub to fender standards are o.k.
> Spring man - I am in Melbourne, there must be a good one in Sydney. Anyone?
> And of course a four wheel alignment when all is done.
> Eddie has a good point how much room do you have with the 65's on the rear?
> At worst longer studs and a 5-8mm spacer or differant rims.
> Greg E
> From: Ben <bencroft96@...>
> Sent: Monday, 25 July 2011 9:46 PM
> Â
> Thankyou Greg now THAT was the inspiration that Ive been looking for!I do want to do this!I have been working hard and saving my money(stashing it).I will go up to 70 series when I next need tyres,my Yokis havent worn much in two years.
> I will order new castor bushes tommorrow,are you using standard or poly?
> Do you know of a spring manufacturer?
> How soon are you doing this?,this year?
> A arm spacers??are you talking about ball joint spacers?
> Are you thinking about Porsche CVs?
> Thanks heaps Greg.
> BenC
> --- In Syncro_T3_Australia@yahoogroups.com, "gregespo73" <gregespo73@> wrote:
> > Ben, don't get me wrong I would definatly raise the old girl. I am just saying shock extenders are not needed. I am running 2wd springs which are too soft but the static hieght is perfect(51-52mm). My advise is this, 215/70 16 bf's, new castor bushes (and sleeves), a arm spacers and have some springs made for the front. The rear just make some spacers (two 12mm should be about right with a subi). Making the front springs correctly is the hard part. I will be doing this soon myself. I am going to take in the original spring as a guide. These are purported to be 75kg/cm in tension. If you tell the spring maker to increase the ride hieght by 5cms and tell them how much the van weighs they should be able to make it close to spot on. I will be also increasing the tension as I have a camper. You could go standard or slightly higher - say 85kg/cms. Greg E
> > --- In Syncro_T3_Australia@yahoogroups.com, "Ben" <bencroft96@> wrote:
> > > Gday Greg(and BenT),thanks for the correction,should get some of my old tech books out one day,(if time ever permits).
> > > Greg thanks for the tips,seems like raising the suspension is not worth the headaches.
> > > Are you running the standard springs?
> > > BenC
> > > --- In Syncro_T3_Australia@yahoogroups.com, greg esposito <gregespo73@> wrote:
> > > > Hey Ben, I am running 225/70 16. I would have gone 215/70 16 if I had known how closeÃÂ they would be to the front fender. I have increased my positive castor above the factory specs to stop the tyre rubbing on the rhf mud spat.ÃÂ This did not cause any drivability issues.ÃÂ If you have not already, I would recommend replacing castor bushes before starting the whole measuring process. Tyre size is more about guard clearance than ride height on the front of a t3. I have also fitted the go westyÃÂ A arm spacer to keep the camber right. This causes the need for a slightly bigger full compression stop.ÃÂ Shock extenders will cause a pandoras box of other issues. They will increase the amount of sag or rebound travel you have, which is great, only if your arm geometry and cv jointÃÂ can cope with the increased angle. They may or may not reduce the compression travel depending on the type used.ÃÂ What ever mod you do a good acid test is to bolt
> the front end up minus
> > > > the spring you can then fully extend and compress the suspension whilst turning the hub and operating the steering lock to lock. Try it first without the wheel than with. As far as the rear goes my 225/70's are as big as you can go with 14" trailing arms and the square profile of bfg all terrains. Just by fitting ome rear shocks you will have increased your rear suspension travel as far as standard cv's can go. Greg E
> > > > From: Ben <bencroft96@>
> > > > Sent: Monday, 25 July 2011 6:23 PM
> > > > ÃÂ
> > > > Mark,thanks for your report.My bus is not a camper,so right now am looking at other options to get a bit more height.
> > > > Re shock extenders,I found a few manufactuers by google and having a read
> > > > http://www.jcwhitney.com/shocks-and-struts/volkswagen-vanagon/c12548d14387j1s21.jcwx
> > > > is one.
> > > > I have 16 inch rims so I think 75 series tyres are out of the question without raising the suspension.
> > > > I would like to hear from anyone running 16 inch rims with large tyres,to know if there is any scrubbing issues.
> > > > Thanks
> > > > BenC
> > > > --- In Syncro_T3_Australia@yahoogroups.com, "m.mullet" <m.mullet@> wrote:
> > > > > Hi Ben,
> > > > > I run GW springs and OME shocks on a converted and fairly light camper.
> > > > > I don't mind the ride at all, although I may drop tyre pressure when not fully loaded. Front shocks top out fairly easily. If you come up with some extenders let me know.
> > > > > Otherwise you may find you eat a few more cv's, especially the rear.
> > > > > Overall not a bad setup. If I had my time again I would probably stay with standard suspension and run 225/175/15 tyres as a cheaper way to
> > > > > get more clearance.
> > > > > Only downside there is increased gearing.
> > > > > Cheers,
> > > > > Mark
There is no damage evident from the scrubbing on my bus.
It doesn't happen very often though - the amount of steering turn and suspension required are both considerable, to the point where one is usually travelling at a fairly slow speed at the time of scrubbing.
My wheels have an ET of +25mm (yes, I know this is not the factory dimension! :-) )
Ben T, what ever happened to your project of sourcing (relatively) cheap 16" wheel arch covers?
Andy.
If you mean the copies I was having done on GRP, I had some prototypes made and was awaiting details. Then somewhere along the way, the financing for the project had some interruption. My proxy ran afoul of regulators. I have been working on getting my funds released for more than 3 years. It's been one delay after another through the courts. I wasn't about to bring in more cash until the previous funding problems were resolved. At some point along the way, others took to producing similar products. With VW Classic Parts returning the original arches to production, it did not appear to me that there will be a strong enough demand to warrant a production volume that could break even.
In other words, "blah, blah, blah" for now. Mike Plompen started to get some made on Europe. Now Pat from Thailand is in the prototype stage to make GRP knockoffs of the Tristar arches.
sent from my electronic leash
On Jul 26, 2011, at 1:39 AM, Ruth Phillips <rafear@internode.on.net> wrote:
> H Ben,
> Andy.
arches.
The Tristar ones would not be suitable for 16" wheels.
http://members.ozemail.com.au/~pjlander/Flares.htm
Suitability is a relative term. The Tristar arches could work on 16" and 17" wheels with low profile tyres. IMO, Tristar arches are more suitable to the boulevardier set. The upper portion of the arches reduce the size of the opening such that the space above the tyre is less visible. There is added benefit that they keep your trousers clean.;-)
> arches.
> BenT
--- In Syncro_T3_Australia@yahoogroups.com, "Ben" <bencroft96@...> wrote:
> Thanks Eddie,good points there and some big tyres you have there also.
> What rims do you use?
> My rears do run close,but still with sufficient clearance.
> My rims are ET 42.(cant argue with that,hey Greg).
> Very interesting.
> BenC
> --- In Syncro_T3_Australia@yahoogroups.com, "eddie" <bergodaz@> wrote:
> > Hi Ben I am running 235 70 16's and have no issues with rubbing any where with just standard suspension. I did , however cut back the rear part of the front fender behind the little plastic thing. One thing that could influence the clearence of tyres is the offset of your wheels. I reckon the more they stick out, the more likely they are to rub on fenders when the fronts are at full lock.
> > > is one.
> > > Thanks
> > > BenC
> > > > Hi Ben,
> > > > get more clearance.
> > > > Cheers,
> > > > Mark
Sent: Monday, 25 July 2011 10:54 PM
Subject: Re: [Syncro_T3_Australia] Re: suspension upgrades
Thanks heaps Greg.
BenC
> > BenC
> > > Hey Ben, I am running 225/70 16. I would have gone 215/70 16 if I had known how close they would be to the front fender. I have increased my positive castor above the factory specs to stop the tyre rubbing on the rhf mud spat. This did not cause any drivability issues. If you have not already, I would recommend replacing castor bushes before starting the whole measuring process. Tyre size is more about guard clearance than ride height on the front of a t3. I have also fitted the go westy A arm spacer to keep the camber right. This causes the need for a slightly bigger full compression stop. Shock extenders will cause a pandoras box of other issues. They will increase the amount of sag or rebound travel you have, which is great, only if your arm geometry and cv joint can cope with the increased angle. They may or may not reduce the compression travel depending on the type used. What ever mod you do a good acid test is to bolt the front end up minus
> > > Â
> > > is one.
> > > Thanks
> > > BenC
> > > > Hi Ben,
> > > > get more clearance.
> > > > Cheers,
> > > > Mark
The new spring looks just right.You should get good lift and nice firm ride(better than the 2wd springs).
Are these new springs progressive?
Look foward to seeing some photos and a report on how they go when they are fitted.
I have put lifting mine off till next year as I am running out of time this year(again).
BenC
> Hey Ben, hope this thread is not too old to resurrect. I have finally had enough time to get my springs made. I thought you might like to see how small the difference is pre installation.
> The middle spring is a 2wd std spring, the spring on the right is the original syncro spring. Obviously the spring on the left is the new spring. Its wire is 18mm thick as opposed to the other springs both being 16.5mm. As you can see it is slightly longer than the syncro spring and slightly shorter than the 2wd spring. I don't know how much help this will be considering yours is a tin top. I suppose the big decision is whether you want to go up the wire thickness and have a firmer ride. If not try the 2wd springs, they lifted even my heavy camper. I will let you know how my new ones work out once I fit them. I am doing the whole front end up in one hit so it won't be too soon. Greg E
> From: greg esposito <gregespo73@...>
> Greg E
> Â
> Thanks heaps Greg.
> BenC
> > > BenC
> > > > ÃÂ
> > > > is one.
> > > > Thanks
> > > > BenC
> > > > > Hi Ben,
> > > > > get more clearance.
> > > > > Cheers,
> > > > > Mark
Sent: Wednesday, 31 August 2011 9:45 PM
BenC
> Greg E
> Â
> Thanks heaps Greg.
> BenC
> > > BenC
> > > > ÂÂ
> > > > is one.
> > > > Thanks
> > > > BenC
> > > > > Hi Ben,
> > > > > get more clearance.
> > > > > Cheers,
> > > > > Mark
Did you give the manufacturers the 2wd and the Syncro springs,to go off?
What is the name of the company you used?
BenC
> Ben, not progressive. Progressive springs for the front of a synco would have tighter coils at one end. I don't think these buses need progressive springs. Will let you know final ride height. The spring guys I used knew thier stuff. I suppose you have the added need to compensate for the heavier donk, so stiff rears would be a good idea. Are you think about a set from America? Greg E
> Â
> Thank Greg,good comparison.
> BenC
> > The middle spring is a 2wd std spring, the spring on the right is the original syncro spring.ÃÂ Obviously the spring on the left is the new spring. Its wire is 18mmÃÂ thick as opposed to the other springs both being 16.5mm. As you can see it is slightly longer than the syncro spring and slightly shorter than the 2wd spring. IÃÂ don't know how much help this will be considering yours is a tin top. I suppose the big decision is whether you want to go up the wire thickness and have a firmer ride. If not try the 2wd springs, they lifted even my heavy camper. I will let you know how my new ones work out once I fit them. I am doing the whole front end up in one hit so it won't be too soon. Greg E
> > From: greg esposito <gregespo73@>
> > Ben, standard rubber OEÃÂ castor bushes(jk) and stainless sleeves(go w).
> > Greg E
> > ÃÂ
> > Thanks heaps Greg.
> > BenC
> > > > BenC
> > > > > Hey Ben, I am running 225/70 16. I would have gone 215/70 16 if I had known how closeÃâàthey would be to the front fender. I have increased my positive castor above the factory specs to stop the tyre rubbing on the rhf mud spat.ÃâàThis did not cause any drivability issues.ÃâàIf you have not already, I would recommend replacing castor bushes before starting the whole measuring process. Tyre size is more about guard clearance than ride height on the front of a t3. I have also fitted the go westyÃâàA arm spacer to keep the camber right. This causes the need for a slightly bigger full compression stop.ÃâàShock extenders will cause a pandoras box of other issues. They will increase the amount of sag or rebound travel you have, which is great, only if your arm geometry and cv jointÃâàcan cope with the increased angle. They may or may not reduce the compression travel depending on the type used.ÃâàWhat ever mod
> > > > > ÃâÃÂ
> > > > > is one.
> > > > > Thanks
> > > > > BenC
> > > > > > Hi Ben,
> > > > > > get more clearance.
> > > > > > Cheers,
> > > > > > Mark
Sent: Thursday, 1 September 2011 8:01 AM
BenC
> Â
> BenC
> > Ben, standard rubber OE castor bushes(jk) and stainless sleeves(go w).
> > Greg E
> > ÂÂ
> > Thanks heaps Greg.
> > BenC
> > > > BenC
> > > > > ÂÂÂ
> > > > > is one.
> > > > > Thanks
> > > > > BenC
> > > > > > Hi Ben,
> > > > > > get more clearance.
> > > > > > Cheers,
> > > > > > Mark
----- Original Message -----From: greg espositoSent: Thursday, September 01, 2011 8:06 AMSubject: Re: [Syncro_T3_Australia] Re: suspension upgrades
Ben, I used Brown spring works in Thomastown. Cost $160 and took a week. David is the guy you want to speak too. No luck finding a local guy?From: Ben <bencroft96@yahoo.com>
Greg,no, I think getting some made here is the go.
BenC
> Â
> BenC
> > Greg E
> > ÂÂ
> > Thanks heaps Greg.
> > BenC
> > > > BenC
> > > > > ÂÂÂ
> > > > > is one.
> > > > > Thanks
> > > > > BenC
> > > > > > Hi Ben,
> > > > > > get more clearance.
> > > > > > Cheers,
> > > > > > Mark
Sent: Thursday, 1 September 2011 8:06 AM
BenC
> Â
> BenC
> > Greg E
> > ÂÂ
> > Thanks heaps Greg.
> > BenC
> > > > BenC
> > > > > ÂÂÂ
> > > > > is one.
> > > > > Thanks
> > > > > BenC
> > > > > > Hi Ben,
> > > > > > get more clearance.
> > > > > > Cheers,
> > > > > > Mark
BenC
> Oh and I only gave him the syncro spring. The only other info he wanted was that the bus was heavier and that i wanted a 50mm lift. I am guessing you would need a spring of about the same length as standard with 18mm wire? Let the supplier do the math. He has offered me free resizing if it does not sit right. Greg E
> Â
> Â
> BenC
> > Ben, not progressive. Progressive springs for the front of a synco would have tighter coils at one end. I don't think these busesÃÂ need progressive springs. Will let you know final ride height. The spring guys I used knew thier stuff. I suppose you have the added need to compensate for the heavier donk, so stiff rears would be a good idea. Are you think about a set from America? Greg E
> > ÃÂ
> > BenC
> > > The middle spring is a 2wd std spring, the spring on the right is the original syncro spring.ÃâàObviously the spring on the left is the new spring. Its wire is 18mmÃâàthick as opposed to the other springs both being 16.5mm. As you can see it is slightly longer than the syncro spring and slightly shorter than the 2wd spring. IÃâàdon't know how much help this will be considering yours is a tin top. I suppose the big decision is whether you want to go up the wire thickness and have a firmer ride. If not try the 2wd springs, they lifted even my heavy camper. I will let you know how my new ones work out once I fit them. I am doing the whole front end up in one hit so it won't be too soon. Greg E
> > > Ben, standard rubber OEÃâàcastor bushes(jk) and stainless sleeves(go w).
> > > Greg E
> > > ÃâÃÂ
> > > Thanks heaps Greg.
> > > BenC
> > > > > BenC
> > > > > > Hey Ben, I am running 225/70 16. I would have gone 215/70 16 if I had known how closeÃÆ'ââ¬Å¡Ãâàthey would be to the front fender. I have increased my positive castor above the factory specs to stop the tyre rubbing on the rhf mud spat.ÃÆ'ââ¬Å¡ÃâàThis did not cause any drivability issues.ÃÆ'ââ¬Å¡ÃâàIf you have not already, I would recommend replacing castor bushes before starting the whole measuring process. Tyre size is more about guard clearance than ride height on the front of a t3. I have also fitted the go westyÃÆ'ââ¬Å¡ÃâàA arm spacer to keep the camber right. This causes the need for a slightly bigger full compression stop.ÃÆ'ââ¬Å¡ÃâàShock extenders will cause a pandoras box of other issues. They will increase the amount of sag or rebound travel you have, which is great, only if your arm geometry and cv jointÃÆ'ââ¬Å¡Ãâàcan cope with the increased
> angle. They may or may not reduce the compression travel depending on the type used.ÃÆ'ââ¬Å¡ÃâàWhat ever mod
> > > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > is one.
> > > > > > Thanks
> > > > > > BenC
> > > > > > > Hi Ben,
> > > > > > > get more clearance.
> > > > > > > Cheers,
> > > > > > > Mark
BenC
--- In Syncro_T3_Australia@yahoogroups.com, "Bob Dale" <rcdale@...> wrote:
> ring universal springs 96064682.
> 4/12 power drill rd hoxten park. he supplied me with front units happy with them
> bob dale
> From: greg esposito
> BenC
> > Ben, not progressive. Progressive springs for the front of a synco would have tighter coils at one end. I don't think these busesà need progressive springs. Will let you know final ride height. The spring guys I used knew thier stuff. I suppose you have the added need to compensate for the heavier donk, so stiff rears would be a good idea. Are you think about a set from America? Greg E
> > Ã
> > BenC
> > > The middle spring is a 2wd std spring, the spring on the right is the original syncro spring.Ãâà Obviously the spring on the left is the new spring. Its wire is 18mmÃâà thick as opposed to the other springs both being 16.5mm. As you can see it is slightly longer than the syncro spring and slightly shorter than the 2wd spring. IÃâà don't know how much help this will be considering yours is a tin top. I suppose the big decision is whether you want to go up the wire thickness and have a firmer ride. If not try the 2wd springs, they lifted even my heavy camper. I will let you know how my new ones work out once I fit them. I am doing the whole front end up in one hit so it won't be too soon. Greg E
> > > Ben, standard rubber OEÃâà castor bushes(jk) and stainless sleeves(go w).
> > > Greg E
> > > ÃâÃ
> > > Thanks heaps Greg.
> > > BenC
> > > > > BenC
> > > > > > Hey Ben, I am running 225/70 16. I would have gone 215/70 16 if I had known how closeÃÆ'ââ¬Å¡Ãâà they would be to the front fender. I have increased my positive castor above the factory specs to stop the tyre rubbing on the rhf mud spat.ÃÆ'ââ¬Å¡Ãâà This did not cause any drivability issues.ÃÆ'ââ¬Å¡Ãâà If you have not already, I would recommend replacing castor bushes before starting the whole measuring process. Tyre size is more about guard clearance than ride height on the front of a t3. I have also fitted the go westyÃÆ'ââ¬Å¡Ãâà A arm spacer to keep the camber right. This causes the need for a slightly bigger full compression stop.ÃÆ'ââ¬Å¡Ãâà Shock extenders will cause a pandoras box of other issues. They will increase the amount of sag or rebound travel you have, which is great, only if your arm geometry and cv jointÃÆ'ââ¬Å¡Ãâà can cope with the increased angle. They may or may not reduce the compression travel depending on the type used.ÃÆ'ââ¬Å¡Ãâà What ever mod
> > > > > > ÃÆ'ââ¬Å¡ÃâÃ
> > > > > > is one.
> > > > > > Thanks
> > > > > > BenC
> > > > > > > Hi Ben,
> > > > > > > get more clearance.
> > > > > > > Cheers,
> > > > > > > Mark
Great info on springs Greg. Many thanks. Mine has a 40mm extra spacer at the back and I think it has 2WD springs at the front to give it the extra height. I only think this because the front is so soft that when I go over a culvert for example the front compresses and then bounces more than I like. Phill said this was a common change that people did. The rear is fine so it has original springs I reckon.
Check out the photo of mine next to Harts. I actually would like to go back to standard and assume the best way is to put original Syncro springs back in the front. I am not sure where to source them so will be doing some research. I also put OME’s in all round when I first got the van.
I do not intend doing such tough off road work that the extra height will be needed plus I have new wheels as well that a re a little bit higher.
Cheers, Peter from Port
----- Original Message -----From: Peter CoeSent: Wednesday, August 31, 2011 3:57 PMSubject: RE: [Syncro_T3_Australia] Re: suspension upgrades
Check out the photo of mine next to Harts. I actually would like to go back to standard and assume the best way is to put original Syncro springs back in the front. I am not sure where to source them so will be doing some research. I also put OMEs in all round when I first got the van.
