Pics attached--- On Mon, 21/2/11, gregespo73 <gregespo73@yahoo.com> wrote: |
On Mon, Feb 21, 2011 at 9:53 PM, greg esposito <gregespo73@yahoo.com> wrote:
Pics attached
Subject: [Syncro_T3_Australia] Tiguan rims
Received: Monday, 21 February, 2011, 9:33 PM
Just in case anyone was wondering about Tiguan rims, yes they fit. Sixteen inch and et33. The gvm of the Tiguan is only 200kg off the syncros. Had Ajax machine the centre bore to a depth of ten mm and bought a set of the right radius ball seat lug nuts from www.t3technique.com . Chris there is a real gent and knows more about fitting any rim to t3's than anyone. Photos to follow. Greg E
On 22/02/2011, at 7:32 AM, greg esposito wrote:
Hey Mark, Running 225/70/16. I have a fingers width clearance on the rear arms. As far as the fronts go, I jacked up the rear left to compress the rhf and found a very small amount of clearance. This clearance would disappear during offroading. I am replacing the castor bushes this week and when I do the alignment I will go as positive on the castor adjustment as possible. I also need to get the front springs made and will lengthen the bump stop. Have you swapped the camper canopy off the blue 2wd yet? Greg E
--- On Mon, 21/2/11, Mark Kofahl <markkofahl@gmail.com> wrote:
Subject: Re: [Syncro_T3_Australia] Tiguan rims
Received: Monday, 21 February, 2011, 10:22 PM
GregBrilliant - they look very smart.What tyre size are you running?Mark.
Pics attached
Hey Gary, Only have 4 at this stage. The Tiguans have a space saver spare so only 4 come up for sale at any one time. If anyone else goes this way I would be interested in spliting a set.I do have a decoupler (Florians) and 14" spare up front. I carry emergency bungs and a good 12v compressor. The long term goal is to build a rear swing out tyre carrier and tube front bar. Also want to replace that rediculously heavy tyre tray with a skid plate. Got those Mefros and siekels on yet Gary? Greg E
Received: Tuesday, 22 February, 2011, 9:26 AM
They look very smart Greg. Did you get 5? Just wondering what you are doing for a spare?Gary
Pics attached
On 22 February 2011 10:15, Gary Cookson <gary@twentytwentyone.net> wrote:Hi Greg
Yes the decoupler would make that a bit easier.No, van is languishing at the moment. The diesel pump i sourced from the UK started leaking from the high pressure head so I had to r&r that and put a set of new seals in it. Just need to tweak the smoke levels now but at least no more leaks, the tarmac was suffering.Next job is the seikels on the front and OMEs then the Mefros, then the rear carrier, then the rear bumper, then the front, then the roof, then the fridge...Maybe a group build of tube bumpers and rear carriers is in order? Do you know any fabricators?GaryOn 22/02/2011, at 10:02 AM, greg esposito wrote:
Pics attached
On 22/02/2011, at 10:31 AM, Francesca Coles wrote:Sounds like we need to book your Syncro in for a working bee, Gary! Sorry to hear it's still in the doldrums.
Francesca.PS Like the snappy new look, Greg. Yours is going to be a Monster Truck of a Syncro.
Pics attached
On 22 February 2011 10:39, Gary Cookson <gary@twentytwentyone.net> wrote:I like that idea Francesca, might be an alternative to creating the rat look syncro it is trying to achieve by itself...
GOn 22/02/2011, at 10:31 AM, Francesca Coles wrote:Sounds like we need to book your Syncro in for a working bee, Gary! Sorry to hear it's still in the doldrums.
Pics attached
Yeh I feel the pain re the long list Gary. The tube bumper is a hard one. I want to do it myself but I need to find someone (in Melb) who can mandrel bend large diametre (65-75mm) pipe with up to a two mm wall. The rear carrier is easy rectanguar section cut and weld. My metal work front and rear is going to be one off work because of the winch and the tow bar. Does your guy in hiedleberg do mandrel bending? Greg E--- On Tue, 22/2/11, Gary Cookson <gary@twentytwentyone.net> wrote: |
Received: Tuesday, 22 February, 2011, 10:15 AM
Hi GregYes the decoupler would make that a bit easier.No, van is languishing at the moment. The diesel pump i sourced from the UK started leaking from the high pressure head so I had to r&r that and put a set of new seals in it. Just need to tweak the smoke levels now but at least no more leaks, the tarmac was suffering.Next job is the seikels on the front and OMEs then the Mefros, then the rear carrier, then the rear bumper, then the front, then the roof, then the fridge...Maybe a group build of tube bumpers and rear carriers is in order? Do you know any fabricators?Gary
Pics attached
--- In Syncro_T3_Australia@yahoogroups.com, Gary Cookson <gary@...> wrote:
> Do you mean Castagna steel on Nicholson St? That's the only steel place I know. I wish I knew another for my bike business. Everyone I talk to is too busy with architectural stuff to tackle small jobs.
> Castagna are really heavy duty welders, they can't do anything thinner than about 5mm plate from my last chat.
> What about one of these and do it yourself
> http://cgi.ebay.com.au/NEW-16-TON-HYDRAULIC-PIPE-BENDER-PORTABLE-BENDING-/220716945543?pt=LH_DefaultDomain_15&hash=item3363c15087
> Gary
> > --- On Tue, 22/2/11, Gary Cookson <gary@...> wrote:
> > From: Gary Cookson <gary@...>
> > Hi Greg
> > Gary
> >> Gary
> >>> --- On Mon, 21/2/11, Mark Kofahl <markkofahl@...> wrote:
> >>> From: Mark Kofahl <markkofahl@...>
> >>> Greg
> >>> Mark.
> >>> On Mon, Feb 21, 2011 at 9:53 PM, greg esposito <gregespo73@...> wrote:
> >>> Pics attached
> >>> --- On Mon, 21/2/11, gregespo73 <gregespo73@...> wrote:
> >>> From: gregespo73 <gregespo73@...>
> Â
> Greg
> Mark.
> Â
> Pics attached
> Â
> Â
Date: Tue, 22 Feb 2011 10:35:47 +0000
Subject: [Syncro_T3_Australia] Re: Tiguan rims
> Â
> Greg
> Mark.
> Â
> Pics attached
> Â
> Â
Exactly the same as mine Hart. 10km over at 100kmh on 14" and 5kmh on the new rubber.--- On Tue, 22/2/11, Hartmut Kiehn <hartis@live.com.au> wrote: |
Date: Tue, 22 Feb 2011 03:14:50 -0800
Subject: RE: [Syncro_T3_Australia] Re: Tiguan rims
Hi Eddie. Have only driven around town so far and it actually feels o.k. I think because the gearing is better for city use. Considering I was down to 2nd gear on some of those long steep climbs in Tassie, I can,t imagine how bad it will be now. Re power I am thinking two options. One is the obvious higher compression and bigger bore and stroke. The other is loose the a/c compressor and fit a small supercharger and megasquirt efi. No time or money for any of that at this stage. Greg E --- On Tue, 22/2/11, bergodaz <bergodaz@ozemail.com.au> wrote: |
On 22/02/2011, at 7:33 PM, gregespo73 wrote:I have been eyeing those off too Gary. The only thing is with a standard bender like that you get dishing on the inside of the bend. Mandrel bending keeps the bend concentric. The idea of paying off my own pipe bender in one job is attractive though. Greg E
> Gary
> > Hi Greg
> > Gary
> >> Gary
> >>> Greg
> >>> Mark.
> >>> Pics attached
On 23 February 2011 09:28, Gary Cookson <gary@twentytwentyone.net> wrote:Yes I imagine the quality of the forms probably isn't brilliant on those but if you've got the welding gear it would be a satisfying thing to build and the dishing might not be too noticeable. I think the forms are all imperial so the metric tubing might not fit so well either. Not sure about that though.
> Gary
> > Hi Greg
> > Gary
> >> Gary
> >>> Greg
> >>> Mark.
> >>> Pics attached
